| by Michael "SKYMTL" Hoenig | February 24, 2010 | ||
| ATI’s Eyefinity Technology ATI’s Eyefinity Technology![]() The term Surround Gaming may not mean much to many of you who are reading this article but with the advent of ATI’s new Eyefinity technology, now is a good time to educate yourself. Basically, Eyefinity will give users the ability to use multiple monitors all running from the same graphics card. In the past, simple dual monitor setups have been used by many graphics, CAD or other industry professionals in order to increase their productivity but gaming on more than one monitor was always a bit of a clunky affair. Granted, some products like Matrox’s TripleHead2Go were able to move multi monitor setups into the public’s perception but there were always limitations (resolution and otherwise) associated with them. ATI is aiming to make the implementation of two or even more monitors as seamless as possible within games and productivity environments while offering the ability to use extreme resolutions. ![]() While the price of two or even three new monitors may be a bit daunting at first for many of you, but good 20” and even 22” LCDs have come down in price to the point where some are retailing below the $200 mark. ATI figures that less than $600 for three monitors will allow plenty of people to make the jump into a true surround gaming setup. Indeed, with three or even six monitors, the level of immersion could be out of this world. ![]() The reason that main in the professional field are familiar with multi monitor setups is for one simple matter: they increase productivity exponentially. Imagine watching a dozen stocks without having to minimize windows all the time or using Photoshop on one screen while watching a sports broadcast on another and using the third screen for Photoshop’s tooltips. The possibilities are virtually limitless if it is implemented properly. ![]() When it comes to a purely gaming perspective, the thought of a massive view of the battlefield or the ability to see additional enemies in your peripheral vision is enough to make most gamers go weak in the knees. Unfortunately, the additional monitors will naturally mean decreased performance considering the massive amount of real-estate that would need rendering. This will mean tradeoffs may have to be made in terms of image quality if you want to use Eyefinity. According to ATI, all of the new HD 5800-series graphics cards will have the ability to run up to three monitors simultaneously. This is done by having a pair of DVI connectors as well as a DisplayPort and HDMI connector located on the back of the card. It should be noted that ATI will be releasing a special Eyefinity version of the HD 5870 in the coming months which features six DisplayPort connectors for those of you who want to drive six monitors from a single card. ![]() This technology is all made possible through the use of DisplayPort connectors but this also provides a bit of a limitation as well. Above we can see that a number of 3-screen output combinations which the current HD5800-series support and one thing is constant: you will need at least one monitor which supports DisplayPort. Unfortunately, at this time DP-supporting monitors tend to carry a price premium over standard screens which will increase the overall cost of an Eyefinity setup. Luckily the other two monitors can either use DVI or a combination of DVI and HDMI for connectivity. | ||
