SilverStone HDDBoost Review
by AkG     |     February 25, 2010
Testing Methodology
Testing a device such as this is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes.
Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the XP load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being a WD 320 single platter drive.
For real world benchmarks we timed how long XP startup took, Adobe CS3 (w/ enormous amounts of custom brushes installed) took, how long a single 4GB rar file took to copy to and then from the drives, then copy to itself. We also used 1GB of small files (from 1kb to 20MB) with a total 2108 files in 49 subfolders.
Please note to reduce variables the same XP OS image was used for all the hard drives.
All tests were run 4 times and average results are represented.
Processor: Q6600 @ 2.4 GHZ
Motherboard: Gigabyte p35 DS4
Memory: 4GB G.Skill PC2-6400
Graphics card: Asus 8800GT TOP
Hard Drive: 1x WD 320
Power Supply: Seasonic S12 600W
SSD FIRMWARE (unless otherwise noted):
Kingston SSDNow V 40GB: 02G9
Drives Used for HDDBoost:
Hard Drive: Western Digital 320GB WD3200AAKS-00B3A0 Single Platter Drive
Solid State Drive: Kingston SSDNOW V 40GB
Latest Reviews in Storage
February 6, 2012
We've been hearing about and anticipating new Intel's Cherryville SSDs for some time now they are finally being released in the guise of the 520 series.  They are built around the same SandForce SF228...
January 23, 2012
Seagate's new Barracuda 3TB is one of the fastest hard drives currently available and it come with plenty of storage space for a reasonable price.   What it can't do is compete on a level performance ...
January 12, 2012
Corsair's Performance 3 256GB SSD showed many enthusiasts that an SSD didn’t need to have “SandForce” in the same sentence as “performance” and that the new Marvell controller was a force to be reckon...
