| by AkG | March 15, 2010 | ||
| Sound Level Testing / Value Sound Level TestingWhile everyone "hears" noise differently there is one easy way to remove all subjectivness and easily compare different fans: use a sound level meter. This way you can easily compare the various fans noise envelopes without us colouring the results and see what fans fit within your personal comfort level. Of course, we will endeavour to try and explain the various results (which are taken at a 30 inch distance) to help you our readers get an even better understanding of how loud a cooler's stock fan is, but even if you discount our personal opinions, the fact remains numbers don't lie. All fans are tested with both voltage regulation / PWM turned off. As we suspected and mused about in the NF-P12-1300 tests, the Gelid Tranquillo’s stock fan is very, VERY quiet. While it is 0.8DBA louder than a Noctua NF-P12-1300 it is also running 200rpms faster. ValueHopefully by this point in the review people looking at OC potential or loudness levels will have a fairly good idea of what its Value is. For the “best bang for the buck” crowd we have included a chart below showing how much each 1°C less costs when compared to Intel’s FREE stock cooler. No consideration has been made for noise levels, “looks” or any other extraneous factors; this is just raw performance vs. monetary cost. For any cooler which performs worse than the Intel stock cooler a rating of “FAIL” will be given. For any cooler which has a “Value” of more than $10 per 1°C a rating of “FAIL” will be used in the graph but the chart will list its actual “Value”. All prices are based on either their MSRP (if no e-tailer prices were available at review time) or the lowest price found in our Price Comparison engine at the time of their initial review for the "Original" chart and are the lowest price found in our Price Comparison engine at the time of this review for the "Updated" chart. If a CPU cooler does not include a fan the price of a Scythe S-Flex 1200RPM has been included ($12). To make it as easy as possible for you to modify this ratio we have also included the various coolers temperature difference so if you do come across one of them on sale you can easily modify its “Value” rating. We here at HWC are in no way saying this is the definitive answer to “Value”, rather it should be considered another tool to help you make your final decision. After all something is only as “valuable” as what you consider it to be. Please Note: This chart has be calculated based upon the differences between Intel stock cooler’s average load at its highest OC on a 920 @ 3.42GHz versus various after market coolers average load temperatures (in their stock configuration with MX-2 TIM) also on a 920 @ 3.42GHz. Any way you slice it, the Tranquillo is an excellent value and you could get a lot worse bang for your hard earned money. While it may not come in below the magic two dollar mark, it does come with a kick ass fan that allows it to be very adaptable to many situations. To put it another way, if you are looking for a great deal this should be on your short list. | ||
