Categories
Review Contents:
ASUS Xonar 7.1 D2 Review
by Robscix     |     October 6, 2007
Features
The ASUS Xonar 7.1 is said to eventually be available in two versions: one for normal PCI and the second for PCI-E. The Xonar card features ultra high fidelity sound quality with a 118 db SNR for playback and an 115db SNR for recording. This card also has the latest in digital output standards with Dolby Digital Live and DTS connect technologies aswell as Dolby headphone and Dolby Virtual speaker. The Xonar is capable of full duplex High Definition recording in 24/192 and the ALT internal loop-back technology allows legal ripping of Mp3s. A dedicated Midi bracket is included for Midi I/O for the home musician. ASUS also added some modding "BLING" to this card which features an orange light inside the EMI shielding and corresponding LEDs in the inputs and outputs, making it easier for the user to identify the signals.
Specifications
Audio Performance
Output Signal-to-Noise Ratio (A-Weighted): 118 dB
Input Signal-to-Noise Ratio (A-Weighted): 118 dB
Output THD+N at 1kHz: 0.0004% (-108dB
Input THD+N at 1kHz: 0.0004% (-108dB)
Frequency Response (-3dB, 24-bit/96kHz input): <10Hz to 46kHz (for all channels)
Frequency Response (-3dB, 24-bit/192kHz input): <10Hz to 90kHz (for all channels)
Output/Input Full-Scale Voltage: 2 Vrms (5.65 Vp-p)
Sample Rate Conversion Quality: Almost lossless, high-fidelity floating-point filters, which has:
-140dB THD+N (typical value for 44.1K->48KHz, 24bit)
-145dB Dynamic Range (typical value for 44.1K->48KHz, 24bit)
Main Chipset
Audio Processor: ASUS AV200 High-Definition Sound Processor (Max. 192KHz/24bit)
24-bit D-A Converter of Digital Sources: Burr-Brown PCM1796 *4 (123dB SNR, Max. 192kHz/24bit)
24-bit A-D Converter for Analog Inputs: Cirrus-Logic CS5381* 1 (120dB SNR, Max. 192kHz/24bit)
Sample Rates & Resolution
Analog Playback Sample Rate and Resolution: 44.1K/48K/96K/192KHz @ 16/24bit
Analog Recording Sample Rate and Resolution: 44.1K/48K/96K/192KHz @ 16/24bit
S/PDIF Digital Output: 44.1K/48K/96K/192KHz @ 16/24bit ,Dolby Digital, DTS, WMA-Pro
S/PDIF Digital Input: 44.1K/48K/96K/192KHz @ 16/24bit
ASIO 2.0 Driver Support: 44.1K/48K/96K/192KHz @ 16/24bit
Latest Reviews in Sound Cards
June 8, 2008
Silverstone has long been known for their cases, power supplies and other components. What they are not yet well known for is their high-end audio equipment, some o...
April 24, 2008
Sound cards usually aren't the first thing many people think of when looking to put together a list of upgrades for their system. With the release of the Xonar DX, ...
November 27, 2007
The PC audio market is currently in a renaissance period. There have been new and exciting releases around every corner and today we will be taking a closer look at...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/2808-asus-xonar-7-1-d2-review.html
Posted By Date
Is x-plosion the very best sound card for under $200 ? - AVS Forum August 26, 2008
xonar d2 pm - PC Magazine Fora August 24, 2008
DISTRIBUTORLER Auzen kart getirtin. August 8, 2008
나의 오덕 산 답사기 : Asus Xonar D2 August 6, 2008
## Asus Xonar D2 vs. Creative X-Fi Elite Pro ## August 4, 2008
iXBT.com: " ASUS Xonar D2" [5] - iXBT.com August 4, 2008
[18/10/2007] - ASUS Xonar D2/PM - Forum AquaPC July 26, 2008
NCIXUS.com - Buy ASUS Xonar D2X 7.1 Channel PCI-E Sound Card 24BIT Dolby Digital DTS Connect SPDIF 118DB Snr - XONAR D2X. July 22, 2008
Guide to Building a HD HTPC - AVS Forum July 20, 2008
Asus Xonar D2/D2X 7.1 Soundcard - Head-Fi: Covering Headphones, Earphones and Portable Audio July 19, 2008
Mobile01 ??????????? July 19, 2008
ASUS Xonar D2 - Guru3D.com Forums July 17, 2008
iXBT.com: " ASUS Xonar D2" [1] - iXBT.com July 17, 2008
