| by Michael "SKYMTL" Hoenig | January 17, 2010 | ||
| Image Quality Improvements (Jittered Sampling) Image Quality ImprovementsEven though additional geometry could end up adding to the overall look and “feel” of a given scene, methods like tessellation and HDR lighting still require accurate filtering and sampling to achieve high rendering fidelity. For that you need custom anti-aliasing (AA) modes as well as vendor-specific anisotropic filtering (AF) sampling and everything in between. As the power of GPUs rapidly outpaces the ability of DX9 and even DX10 games to feed them with information, a new focus has been turned to image quality adjustments. These adjustments do tend to impact upon framerates but with GPUs like the GF100 there is much less of a chance that increasing IQ will result in the game becoming unplayable. Quicker Jittered Sampling Techniques Many of you are probably scratching your head and wondering what in the world jittered sampling is. Basically, it is a shadow sampling method that has been around since the DX9 days (maybe even prior to that) which allows for realistic, soft shadows to be mapped by the graphics hardware. Unfortunately, this method is extremely resource hungry so it hasn’t been used very often regardless of how good the shadows it produces may look. ![]() In the picture above you can see what happens with shadows which don’t use this method of mapping. Basically, for a shadow to look good it shouldn’t have a hard, serrated edge. ![]() Soft shadows are the way to go and while past generations of hardware were able to do jittered sampling, they just didn’t have the resources to do it efficiently. Their performance was adequate with one light source in a scene but when asked to produce soft shadows from multiple light sources (in a night scene for example), the framerate would take an unacceptably large hit. With the GF100, NVIDIA had the opportunity to vastly improve shadow rendering and they did just that. ![]() To do quicker, more efficient jittered sampling, NVIDIA worked with Microsoft to implement hardware support for Gather4 in DX11. Instead of doing four texture fetches per cycle, the hardware is now able to specify one coordinate with an offset and fetch four textures instead of having to fetch all four separately. This will significantly improve the shadow rendering efficiency of the hardware and is still able to work as a standard Gather4 instruction set if need be. With this feature turned on, NVIDIA expects a 200% improvement in shadow rendering performance when compared to the same scene being rendered with their hardware Gather4 turned off. | ||
