| by Michael "SKYMTL" Hoenig | January 17, 2010 | ||
| A Closer Look at the Raster & PolyMorph Engines A Closer Look at the Raster & PolyMorph EnginesIn the last few pages you may have noticed mention of the PolyMorph and Raster engines which are used for highly parallel geometry processing operations. What NVIDIA has done is effectively grouped all of the fixed function stages into these two engines, which is one of the main reasons drastically improved geometry rendering is being touted for GF100 cards. In previous generations these functions used to be outside of the core processing stages (SMs) and NVIDIA has now brought them inside the core stages to ensure proper load balancing. This in effect will help immeasurably with tessellated scenes which feature extremely high triangle counts. ![]() Within the PolyMorph engine there are five stages from Vertex Fetch to the Stream Output which each process data from the Streaming Multiprocessor they are associated with. The data then gets output to the Raster Engine. Contrary to past architectures which featured all of these stages in a single pipeline, the GF100 architecture does all of the calculations in a completely parallel fashion. According to our conversations with NVIDIA, their approach vastly improves triangle, tessellation, and Stream Out performance across a wide variety of applications. In order to further speed up operations, data goes from one of 16 PolyMorph engines to another and uses the on-die cache structure for increased communication speed. ![]() After the PolyMorph engine is done processing data, it is handed off to the Raster Engine’s three pipeline stages that pass off data from one to the next. These Raster Engines are set up to work in a completely parallel fashion across the GPU for quick processing. ![]() Both the PolyMorph and Raster engines are distributed throughout the architecture which increases parallelism but are distributed in a different way from one another. In total, there are 16 PolyMorph engines which are incorporated into each of the SMs throughout the core while the four Raster Engines are placed at a rate of one per GPC. This setup makes for four Graphics Processing Clusters which are basically dedicated, individual GPUs within the core architecture allowing for highly parallel geometry rendering. Now that we are done with looking at the finer details of this architecture, it’s time to see how that all translates into geometry and texture rendering. In the following pages we take a look at how the new architecture works in order to deliver the optimal performance in a DX11 environment. | ||
