NVIDIA’s GeForce GF100 Under the Microscope
by Michael "SKYMTL" Hoenig     |     January 17, 2010
Image Quality Improvements
32x CSAA Mode for Improved AA
In our opinion, the differences between the AA modes above 8x are minimal at best unless you are rendering thin items such as grass, a chain-link fence or a distant railing. With the efficiency of the DX11 API in addition to increased horsepower from cards like the GF100, it is now possible to use geometry to model vegetation and the like. However, developers will continue using the billboarding and alpha texturing methods from DX9 which allow for dynamic vegetation, but it will continue to look jagged and under-rendered. In such cases, anti-aliasing can be applied but high levels of AA are needed in order to properly render these items. This is why NVIDIA has implemented their new 32x Coverage Sample AA.
In order to accurately apply AA, three things are needed: coverage samples, color samples and levels of transparency. To put this into context, GT 200 had 8 color samples and 8 coverage samples which means a total rate of 16 samples on edges. However, this only allowed for only 9 levels of transparency. This lead to edges which still looked jagged and without proper blending so dithering was implemented to mask the banding.
The GF100 on the other hand features 24 coverage samples and 8 color samples for a total of 32 samples (hence the 32x CSAA moniker). This layout also offers 33 levels of transparency for much smoother blending of the anti-aliased edges into the background and increased performance as well.
With increased efficiency comes decreased overhead when running complex AA routines and NVIDIA specifically designed the GF100 to cope with high IQ settings. Indeed, on average this new architecture only loses about 7% of its performance when going from 8x AA to 32x CSAA.
TMAA and CSAA: Hand in Hand
No matter how much AA you apply in DX9, there will still invariably be some issues with distant, thin objects that are less than a pixel wide due to the method older APIs use to render these. Transparency Multisample AA (TMAA) allows the DX9 API to convert shader code to effectively use alpha to coverage routines when rendering a scene. This, combined with CSAA, can greatly increase the overall image quality.
It may be hard to see in the image above but without TMAA, the railing in the distance would have its lines shimmer in and out of existence due to the fact that the DX9 API doesn’t have the tools necessary to properly process sub-single pixel items. It may not impact upon gaming but it is noticeable when moving through a level.
Since coverage samples are used as part of GF100’s TMAA evaluation, much smoother gradients are produced. TMAA will help in instances such as this railing and even with the vegetation examples we used in the last section.
Latest Reviews in Video Cards
February 8, 2012
February 6, 2012
January 30, 2012
