Gigabyte GA-X58A-UD7 LGA1366 Motherboard Review
by MAC     |     January 24, 2010
Included Software
Now that we have the motherboard unpacked and installed, it is time to take a look at some of the numerous software utilities that Gigabyte have bundled with the X58A-UD7.
Click on image to enlarge
Here we have the familiar setup screens for the included software CD. It contains all the drivers and the unique Gigabyte utilities that you will need to get your system up & running. Obviously, we still recommend that you visit Gigabyte's website to get the very latest BIOS, drivers, and software revisions. Having said that, the SmartTPM software can only be found on the CD, it's not available for download online.
EasyTune6
EasyTune6 is a system management utility that displays system clock speeds, voltages, temperatures, and fan rotation but more importantly it allows users to overclock from within Windows. Anyone familiar with past EasyTune iterations knows that although this utility has always contained a fair bit of functionality, its ease of use left much to be desired. Thankfully Gigabyte went back to the drawing board and created a brand new EasyTune version from scratch. Let's check it out.
Click on images to enlarge
The CPU and Memory tabs provide basic component information and are somewhat reminiscent of the widely used CPU-Z utility.
The Tuner section is really the only one that's important. First, it contains the Quick Boost feature, which allows automatic overclocking at the touch of a button. Simply pick the Quick Boost level that best suits your needs/courage, reboot the system, and voila! Overclock achieved.
If you click on Easy or Advanced mode, three additional tabs appear: frequency, ratio, voltage. The Frequency tab allows you to tweak the BCLK, memory, and PCI-E frequencies.
Within the Tuner section, the Ratio tab allows you to independently set the multiplier on every individual CPU core, even the 'virtual' logical cores...which is unnecessary to be honest.
The Voltage tab is arguably the most important one since it allows complete control over every voltage option that is found in the BIOS. This is a great tool to fine tune an overclock.
The Graphics tab can be used to manipulate your graphics card’s core/memory/shader clock speeds. Unlike past versions of ET6, this section no longer allows you to control the GPU fan, nor monitor the GPU temperature.
The Smart tab gives you access to the CPU Intelligent Accelerator (C.I.A) 2 and Smart Fan functions. The CPU Intelligent Accelerator was designed to automatically overclock the CPU according to system load and user-selected level. As the name suggests, Smart Fan feature gives users finely-tuned control over the CPU fan speed.
Lastly, we have HW Monitor which is the only part of EasyTune6 that disappoints us. Despite providing us with ten voltage tweaking options in the Tuner tab, the HW Monitor only displays two system voltages and three voltage rails. This is a high-end motherboard and comprehensive voltage monitoring should be standard.
Overall though, we do sincerely enjoy using EasyTune6. It was consistently one of the first pieces of software we installed after a fresh Windows installation, and it was definitely a huge help in finding this motherboard's overclocking limits. EasyTune 6 was arguably the first of the next-generation manufacturer-specific tweaking utilities, and with little tweaks here and there it remains a worthwhile application.
Dynamic Energy Saver 2
Now let's have a look at the brand new Dynamic Energy Saver (DES) 2 energy saving solution, which is one of Gigabyte’s most highly-publicized features.
After first installing the DES2 software, we are greeted with a powered down control panel. This means all energy saving functions are turned off and disabled. Only when we click on the large logo to the right does the panel come to life and the power savings begin.
The software is pretty straightforward; we have our power savings meter in the top portion providing us with information about how much wattage was saved, a CPU Power meter showing real-time CPU power consumption, the power phase status displaying how many of the 24 CPU phases are being utilized, and a representation of which components are being manipulated by the DES2 software. Dynamic Energy Saver 2 works even when the system is overclocked, while other the other manufacturers solutions do not.
AutoGreen
In effect, the AutoGreen utility can help reduce energy consumption when you are away from your computer by putting the system into a low power state when it doesn't sense your bluetooth-enabled cell phone in the vicinity. Once again, since there is no bluetooth receiver included, we didn't get a chance to test out this feature.
January 24, 2012
January 2, 2012
November 20, 2011
