Gigabyte GA-X58A-UD7 LGA1366 Motherboard Review
by MAC     |     January 24, 2010
System Benchmarks
SuperPi Mod v1.5
When running the SuperPI 32MB benchmark, we are calculating Pi to 32 million digits and timing the process. Obviously more CPU power helps in this intense calculation, but the memory sub-system also plays an important role, as does the operating system. We are running one instance of SuperPi via the HyperPi 0.99b interface. This is therefore a single-thread workload.
Cinebench R10
Cinebench R10 64-bit
Test1: Single CPU Image Render
Test2: Multi CPU Image Render
Comparison: Generated Score
Developed by MAXON, creators of Cinema 4D, Cinebench 10 is designed using the popular Cinema software and created to compare system performance in 3D Animation and Photo applications. There are two parts to the test; the first stresses only the primary CPU or Core, the second, makes use of up to 16 CPUs/Cores. Both are done rendering a realistic photo while utilizing various CPU-intensive features such as reflection, ambient occlusion, area lights and procedural shaders
PCMark Vantage x64
PCMark Vantage Advanced 64-bit Edition (1.0.0.0)
PCMark Suite / Default Settings
The main focus of our General Tasks category lies with the most recent installment of the PCMark series, Vantage. While still classified under the description of a Synthetic benchmark, PCMark Vantage uses many of Vista's (Note - Vantage is Vista-only) built-in programs and features along with its own tests, so it is "real-world" applicable in regards to CPU performance. The following is a general list of the tests in the PCMark suite, very much in line with tasks of an average user: Data encryption, Data compression, CPU image manipulation (compression/decompression/resize), Audio transcoding,Video transcoding,Text editing,Web page rendering, Windows Mail, Windows Contacts, and CPU game test.
Photoshop CS4
For the image editing portion of this review, we will use Photoshop CS4 in coordination with Driver Heaven’s Photoshop Benchmark V3, which is an excellent test of CPU power and memory bandwidth. This is a scripted benchmark that individually applies 15 different filters to a 109MB JPEG, and uses Photoshop’s built-in timing feature to provide a result at each test stage. Then it’s simply a matter of adding up the 15 results to reach the final figure.
Lame Front End
Lame Front End v1.0 is a single-threaded application, which means that it only utilizes a single processor core. This will obviously limit performance but it will allow us to see the benefits of Lynnfield aggressive Turbo Boost with single-threaded loads. We will be encoding a WAV rip of Santana’s Supernatural album and converting it to MP3 using the highest fidelity VBR 0 quality preset.
x264 HD Benchmark
x264 HD Benchmark v1.0
Test: MPEG-2 HD 720P Video Clip Conversion to x264
DVD Video Length: 30 Seconds
Comparison: FPS of Second Pass
x264 is quickly becoming the new codec of choice for encoding a growing number of H.264/MPEG-4 AVC videos. Think of it as the new Divx of HD and you can understand why we felt it critical to include. Tech Arp's recent development of the x264 HD Benchmark takes a 30 second HD video clip and encodes it into the x264 codec with the intention of little to no quality loss. The test is measured using the average frames per second achieved during encoding, which scales with processor speed and efficiency. The benchmark also allows the use of multi-core processors so it gives a very accurate depiction of what to expect when using encoding application on a typical full length video.
WinRAR
WinRAR 3.8.0
Test: Compression of 1GB of Assorted Files
Comparison: Time to Finish
One of the most popular file compression/decompresion tools, we use WinRAR to compress a 1GB batch of files and archive them, timing the task until completion.
January 24, 2012
January 2, 2012
November 20, 2011
