| by MAC | January 24, 2010 | ||
| Included Software pt.2 Included Software pt.2Smart 6One of the keynote new technologies introduced by GIGABYTE at Computex was Smart 6, which is a collection of six user-friendly system management tools. In their own words, Smart 6 "allows you to speed up system performance, reduce boot-up time, manage a secure platform and recover previous system setting easily with a click of the mouse." ![]() As you can see, Smart 6 has its own dock that allows quick access to the six SMART utilities. ![]() Smart QuickBoot, as the name suggests, helps reduce boot-up time. This tool consists of BIOS QuickBoot and OS QuickBoot. BIOS Quick Boot allows your system bypass the time-consuming power-on self test (POST) procedure after three successful boots, if no changes are made to the BIOS or hardware configuration. The OS QuickBoot on the other hand makes the system go into an advanced S3 sleep mode upon exiting the operation system, and it permits a quick resume to full OS functionality. ![]() Quick Boost provides quick and effortless overclocking for novice users. Just click on one of three overclocking presets and the program does the rest of the work for you. This is the same Quick Boost as found within Easy Tune 6. ![]() Smart Recovery is kind of like Windows Restore/Apple Time Capsule function, where you can roll-back system settings to a previous working status. Users can select just about any day, week, or month to roll-back from, without having had to manually tell the program to create a backup flag. ![]() Now most GIGABYTE motherboards feature two physical BIOS ROMs, but with Smart DualBIOS this is the first time that important passwords and dates can be saved directly to the new 16MB BIOS chips (up from the previous 8MB). While this might seem like a security risk, the only way to access Smart DualBIOS is with a password. It is simply a secure way of storing the countless passwords that most people have nowadays. ![]() Smart Recorder monitors and records system activities, such as when a system was turned on or off, and what data files were accessed or copied. ![]() Smart TimeLock is a feature all kids will despise, as it allows parents the ability to schedule time limits for their children to use the PC. Parents can even make different usage time rules for weekdays and weekends. | ||
