ASUS M4A785TD-V EVO and M4A785TD-M EVO AM3 Motherboards Review
by Mike D.     |     December 8, 2009
A Closer Look at the M4A785TD-V EVO
At first glance, the overall layout of the M4A785TD-V EVO is quite good. The ATX power connector and SATA ports can be found at the edge of the board, and the CPU-power connector is located at the top left – all ideal locations. The IDE connector really isn’t in a very good location near the case header connections, but this is forgivable given that most people don’t use IDE devices these days. You’ll also notice the absence of a floppy header – good riddance in our opinion.
From an expansion slot perspective, the layout looks good as well. There is triple slot spacing between the two full-length PCI-E slots and the 1X slot can accept very long cards without obstructing anything on the board. ASUS was a little bit excessive with the legacy PCI slots in our opinion, but definitely a good thing for those with older wireless cards and sound cards.
USB headers and case headers can be found in the usual south west corner of the board. A parallel header can also be found here for those desperately hanging on to their trusty HP LaserJet 4, but an optional port bracket will have to be purchased from ASUS to use it. The clear CMOS jumper is in a decent location, just above the case header connections, but may be difficult to access with a video card installed in the lower slot.
We should also mention that there are three fan headers on the M4A785TD-V, conveniently located at both east and west sides of the board for intake/exhaust fans. The 4-pin CPU fan header is oddly located at the north west extreme of the board, but still close enough not to be a problem.
Taking a closer look at the top half of the board, we see that ASUS decided to use a standard 4-pin CPU power connector instead of the 8-pin found on higher end boards. Although this doesn’t cause an issue as the two standards are backwards compatible, it does limit the current deliverable to the CPU in extreme overclocking scenarios.
Now with the minor 4-pin observation out in the open, we’ll look at a feature you really don’t find in budget priced boards – 8+2 phase power. Generally speaking, it is common to find 4+1 phase configurations, but ASUS has doubled up both the CPU power phases as well as the HT/memory controller power phases. This should help to provide a more stable delivery of power to the processor and it’s internal components. You’ll also notice that ASUS used all solid capacitors. Not just in the CPU power section of the board, but everywhere. Solid capacitors are much more reliable and should last longer than traditional capacitors. ASUS rates the M4A78T-E as “140W CPU Capable” and we certainly would agree with that statement.
There is also an interesting little jumper right near the CPU power connector labeled “OV_CPU”. Moving it away from its default position allows a CPU voltage selection up to 1.9V. Without moving the jumper, the previous limit was 1.7V. ASUS doesn’t document what this jumper does anywhere in the manual, but with a name like OV_CPU, we couldn’t help but try it out for ourselves.
A large passive heatsink also covers the MOSFETS and should help to provide extra cool in instances of “heavy power draw” – i.e. overclocking and overvolting!
We find four non-alternating dual channel memory slots in their typical location at the top right of the board. The blue and black color separates the channels so for two dim, dual channel operation, you simply match the colors. The memory power is provided by a simple single-phase design. This is expected given the price of the board, and should be just fine for the majority of buyers out there. As mentioned, the the CPU fan header is located at the extreme corner of the board, which is a little out of the way but not really a problem. It is of the 4-pin variety, so those with standard 3-pin and newer 4-pin PWM fans are covered.
If you’ve never been to Sydney, Australia, you need not look farther than the ASUS M4A785TD-V to see the famous “Sydney Opera House”. In all seriousness, the wide two-tone 785G heatsink adds quite an eye-catching centerpiece to the board. We’ll see just how effective this heatsink is in the “Thermal Performance” section.
On the right hand side of the large 785G heatsink, we see half of a DDR3 module protruding. This IC is the 785G’s “side-port memory” that helps to boost performance. Although 128MB may seem puny in comparison to today’s 1GB discrete standard, it can boost frame rates over the sharing main memory alone. This is a very positive feature that the ASUS EVO boards have going for them, as quite a few entry level 785G boards do not have onboard side-port memory modules. This is definitely a feature prospective 785G buyers should look for if planning to use the onboard Radeon 4200 video capabilities.
The AMD SB710 southbridge is covered by a small and low-profile passive heatsink. Although it may appear very small in comparison to the one covering the 785G, the SB710 has a very small thermal footprint and genuinely doesn’t need much in the way of cooling as we’ll see shortly.
On the SATA side of things, we can find five labeled ports just above the SB710. You may be wondering where that sixth port went, and we’ll direct your attention to the E-SATA port on the rear I/O panel. Although the ports are not on the edge of the board in a 90 degree orientation, we were pleased with their location. Even with a very long PCI-Express graphics card in the upper slot, all SATA ports remain accessible. A case-fan header can also be found right next to the SATA ports for easy connection to a frontal case intake fan.
The M4A785TD-V enjoys two full-length 16X slots, and a single PCI-E 1X slot. We were a little disappointed to see three legacy PCI slots on the board – in a perfect world, it would have been nice to trade at least one of these out for an additional PCI-E 1x slot as PCI is beginning to go the way of the dinosaur.
Although the M4A785TD-V does support Crossfire using its two full-length PCI-E slots, we should mention that the lower slot is held back to a mere 4X operating mode, while the upper blue slot operates with full 16X bandwidth. Since all of these PCI-E lanes hang off of the 785G chipset, it should technically have been possible to split the lanes into an 8X/8X configuration. It appears that AMD decided not to do this in order to promote higher-end - and more expensive - 790GX and 790FX offerings to the enthusiast market. With that said, a 4X PCI-E 2.0 slot is plenty for folding purposes, or for low to mid-range crossfire configurations. If we had to choose between a single slot, or the slot configuration in the M4A785TD-V, we’d gladly pick the two slots!
January 24, 2012
January 2, 2012
November 20, 2011
