| by AkG | November 25, 2009 | ||
| Testing Methodology Testing MethodologyTesting a hard drive is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for SSDs to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our testbed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end user’s experience will be like. Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the XP load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being a WD 320 single platter drive. For these tests we used a combination of the ATTO Disk Benchmark, HDTach, HDTune, Cystal Disk Benchmark, h2benchw, SIS Sandra Removable Storage benchmark, and IOMeter for synthetic benchmarks. For real world benchmarks we timed how long XP startup took, Adobe CS3 (w/ enormous amounts of custom brushes installed) took, how long a single 4GB rar file took to copy to and then from the hard drives, then copy to itself. We also used 1gb of small files (from 1kb to 20MB) with a total 2108 files in 49 subfolders. For the temperature testing, readings are taken directly from the hottest part of the drive case using a Digital Infrared Thermometer. The infrared thermometer used has a 9 to 1 ratio, meaning that at 9cm it takes it reading from a 1 square cm. To obtain the numbers used in this review the thermometer was held approximately 3cm away from the heatsink and only the hottest number obtained was used. Please note to reduce variables the same XP OS image was used for all the hard drives. For all testing a Gigabyte PA35-DS4 motherboard was used. The ICH9 controller on said motherboard was used. All tests were run 4 times and average results are represented. Processor: Q6600 @ 2.4 GHZ Motherboard: Gigabyte p35 DS4 Memory: 4GB G.Skill PC2-6400 Graphics card: Asus 8800GT TOP Hard Drive: 1x WD 320 Power Supply: Seasonic S12 600W SSD FIRMWARE (unless otherwise noted): G. Skill Titan: 0955 G.Skill Falcon: 1571 (AKA FW 1.3) OCZ Apex: 955 OCZ Vertex: 1.3 (AKA FW 1571) Patriot Torqx: 1571 (AKA FW 1.3) Corsair P64: 18C1Q OCZ Summit: 1801Q A-Data S592: 1279 (AKA PRE 1.1 FW) OCZ Agilit EX 60GB: 1.3 (AKA 1.4 for MLC Indilinx Drives) Please note: The "G.Skill 64GB" listed in some of the graphs (the one with incomplete data) is the very first SSD we here at HWC reviewed. It does not have a name but its model number is FS-25S2-64GB and here is a link to our review of it. | ||
