| by AkG | November 25, 2009 | ||
| IOMeter / IOMeter Stutter Test IOMeterIOMeter is heavily weighted towards the server end of things, and since we here at HWC are more End User centric we will be setting and judging the results of IOMeter a little bit differently than most. To test each drive we ran 5 test runs per HDD (1,4,16,64,128 que depth) each test having 8 parts, each part lasting 10 min w/ an additional 20 second ramp up. The 8 subparts were set to run 100% random, 80% read 20% write; testing 512b, 1k, 2k,4k,8k,16k,32k,64k size chunks of data. When each test is finished IOMeter spits out a report, in that reports each of the 8 subtests are given a score in I/Os per second. We then take these 8 numbers add them together and divide by 8. This gives us an average score for that particular que depth that is heavily weighted for single user environments. ![]() Needless to say, this drive rocks the IOM tests. In fact, it basically ties the rock star of this test (the Intel X-25M) three times, beats it once and loses once which makes the Agility EX’s performance better than any other Indilinx drive we have tested. IOMeter Stutter TestIn our usual IOMeter test we are trying to replicate real world use where reads severly outnumber writes. However, to get a good handle on how well a Solid State Disk Drive will handle a worse case scenario (and thus how likely the dreaded stutter issue will happen) we have also run an additional test. This test is made of 1 section at que depth of 1. In this test we ran 100% random. 100%writes of 4k size chunks of information. In the .csv file we then found the Maximum Write Response Time. This in ms is worst example of how long a given operation took to complete. We consider anything higher than 333ms (one third of a second) to be a good indicator that stuttering may happen, with the higher the number the worse the duration of the stutter will most likely be. ![]() Once again the Agility EX puts down some great numbers. Not only is its average good enough for a solid second place, its maximum numbers (a much more important number as this number has the most effect on “stutter”) are down there at Hard Drive levels. You can forget about worrying about stutters with this drive as it is easily one of the best performers in this test. | ||
