Cooler Master Storm Sentinel Advance Gaming Mouse Review
by AkG     |     November 3, 2009
Storm Tactic AP Software Overview
To use the Tactic AP software that comes with this mouse, actually don’t need to install it since it can be run directly from the CD. This software is a simple and easy way of interfacing with the hardware on the mouse (and its 64k of storage) and telling it what you want to see on the OLED screen, how you want it to react to the various mouse commands and what LED colour (if any) to turn on. As with some of the other high end mice out there this lightweight program does not need to be running (or even installed) for you to have access to the advanced features of the mouse, once you have loaded your customs settings onto it.
To put it bluntly this is a fire and forget piece of software which probably won’t be used too much as the Sentinel is a pretty smart mouse which does not need any bloatware running in the background to interpret the various actions and relays that information to the OS. It may not be the first to implement this and turn a “dumb” peripheral into a little powerhouse but the Sentinel is one of the first mice we have used that takes a good long, hard look into how software is supposed to function.
The main control panel (which is what the program opens by default) is fairly self explanatory, as this is where most of the main functions are located. On the left hand side is the button assignment where you chose what each of the 8 buttons actually does. Across the bottom are the profile options which allow you to set up each custom profile and by extension buttons’ functions as well. You will have to set up each profile separately as the default is to have setting is to have all the buttons act the same (i.e. the default commands shown in the picture above).
By default the USB report rate is set to 1000hz, which is nice as this is one less step you have to do…unless you want to use a custom profile to have a lowered report rate that is. Meanwhile, in the top right hand corner you have the four default DPI levels which you can go through by pressing the DPI up or down buttons on top of the mouse. As with many other high end mice you can independently set the X and Y levels and can do so with a lot more precision than the mouse itself offers. The lower right hand portion of this main screen is concerned with double click speed, button response time and motion sensitivity; all using the ubiquitous slider.
All in all, this is a busy screen but it allows you to have many of the Sentinel’s functions right at your fingertips.
The second tab is the colour control tab, which allows you to set the various LED colours and you can actually set the front LEDs to a different colour from the top ones. All in all you get 8 colours to choose from (which explains the whole pretentious “OctoShade” bit) and can also set the LEDs to different styles. The full colour mode means that they stay on at their fullest intensity while “breathe mode” sets the LEDs to slowly increase in intensity until they reach full brightness and then they slowly dim till they are off. Rinse and repeat and you have this setting. Rapid fire….rapidly blinks the LEDs every time you click a button can be seriously annoying but to each their own. The last possibility is “disabled” which as the name suggests turns off the LEDs.
As with the mouse buttons, the LED’s actions and colours can be set up individually for each of the preset profiles. This allows you to intuitively know which profile the mouse is set with just a visual check.
The next tab is the macro editor and this is where we ended up being bit disappointed as it “only” allows for up to 43 actions…which really means it is limited to a mere 21 keystroke/ mouse click commands as each click is registered as a depression and then as a separate release (to allow for multiple keystroke commands like Cntrl+Alt+Delete for example). This is much less than the 254 you get with the Gigabyte “Ghost” GM800 (for example). However, this slight limitation does explain how Cooler Master was able to cram in two extra profiles into the same 64K of space the Ghost had. However, it appears you are not limited in the number of these macros you can create, just how many you can load to the mouse. We should mention that we think 43 actions is more than enough of all but the most demanding professional gamer.
In a very interesting move, the Tactic AP software also allows for scripts to be stored onboard and activated just like a macro via pre configured mouse button click. This is the fourth tab and much like the macro tab, setting up a custom script to run every time you press a button is extremely easy. In grand total each script can be a maximum of 86 actions…or 43 key / mouse commands (as once again a depression and release is considered two actions. Also like the macro controls you can also have the script set to loop (if you keep the mouse button down) and even how fast it should do so. As with the macros, you can have a darn near unlimited amount stored on your system but “only” a realistic max of seven per profile (and 35 total) stored in the on board memory of the mouse.
While the other tabs are impressive what we REALLY liked was the abilities offered by the library tab. Here you are able to quickly and easily import macros and scripts from the PC to the mouse and vice versa and even back them all up to an external file which can be read by the software. This means if you make a bunch of macros (for example) on one computer you can save them on a flash drive and load them as needed on a different computer. This ability to share your custom scripts and macros with other Storm Sentienl Advance users is simple amazing and really goes to show that Cooler Master listened to what the gaming community wants.
The last tab is simply a way to get updates the software and your mouse via the internet.
Overall we really like the software which comes with the Storm Sentinel since it is fairly easy to use while being extremely versatile. It incorporates everything we could possibly want in a piece of software. The fact that you don’t have to have it running all the time in the background is a nice bonus and something we have come to expect from high end mice. The only thing we really don’t like about it is the overall cluttered look of every interface. Maybe a customizable skin should be in Cooler Master’s cards for their next update.
Latest Reviews in Peripherals
January 4, 2012
Mouse pads aren't exactly items that steal much of the limelight from the premier products in this industry but they're still an integral part of anyone's gaming experience.   XFX has now released the...
December 28, 2011
Cooler Master's original Storm Sentinel gaming mouse was a popular choice among gamers but some encountered problems with its Twin Eye sensor.   A new mouse has now been released which takes the Senti...
December 11, 2011
Gaming mice are a dime a dozen these days so SteelSeries has decided to introduce a product that moves away from their traditional understated design towards something a bit more mainstream.  The new ...
