| by Michael "SKYMTL" Hoenig | October 12, 2009 | ||
| Heat & Acoustics / Power Consumption Heat & AcousticsFor all temperature testing, the cards were placed on an open test bench with a single 120mm 1200RPM fan placed ~8” away from the heatsink. The ambient temperature was kept at a constant 22°C (+/- 0.5°C). If the ambient temperatures rose above 23°C at any time throughout the test, all benchmarking was stopped. For this test we use the 3DMark Batch Size test at it highest triangle count with 4xAA and 16xAF enabled and looped it for one hour to determine the peak load temperature as measured by GPU-Z. For Idle tests, we let the system idle at the Vista desktop for 15 minutes and recorded the peak temperature. ![]() With a 40nm core at its heart and a dual slot cooler taking care of heat, the temperatures on the HD 5750 never even reach 70C and the card actually stays cool to the touch when it is at idle. The fan speeds are actually aided by the cool-running core and even when the card is under load, it is virtually impossible to tell that it is running. Power ConsumptionFor this test we hooked up our power supply to a UPM power meter that will log the power consumption of the whole system twice every second. In order to stress the GPU as much as possible we once again use the Batch Render test in 3DMark06 and let it run for 30 minutes to determine the peak power consumption while letting the card sit at a stable Windows desktop for 30 minutes to determine the peak idle power consumption. We have also included several other tests as well. Please note that after extensive testing, we have found that simply plugging in a power meter to a wall outlet or UPS will NOT give you accurate power consumption numbers due to slight changes in the input voltage. Thus we use a Tripp-Lite 1800W line conditioner between the 120V outlet and the power meter. ![]() Even though we were prepared for some great power consumption numbers, the HD 5750 simply stunned us and showed how far ATI has come in terms of overall efficiency in comparison to NVIDIA. With load power consumption that was better than any card tested to date coupled with the performance it showed in games makes this one of the best performance per watt cards on the market today. | ||
