Review Contents:
Intel Core i7 / LGA1366 CPU Cooler Roundup
by AkG     |     October 20, 2009
Kingwin XT-1264
Well one thing is for certain: the Kingwin XT-1264 sports one flashy full color box. The box itself is made of moderately thick cardboard and is covered in a riot of colors but it still provides decent protection for its contents. In a nut shell this box has all you could ask for information and detail wise to make a fairly informed decision.
We do take umbrage to the fact they only show the AMD mounting setup on the box and not the pushpin based Intel 775 / i7 setup. This is a bit misleading but we have a sneaking suspicion that this product was designed mainly as an AMD cooler and the Intel attachments are more of an afterthought. Lets call it a hunch for now, shall we?
Lets start with explaining the nomenclature Kingwin uses in their naming scheme and then move onto the dimensions of this curious cooler before we really start exploring in depth the design of this cooler. Basically, Kingwins naming scheme is the same as Xigmateks as you start with the fan size (12cm), then state the size of the heatpipes (6mm) and then the number of them used. In fact, Xigmatek makes the HDT-S1264 cooler that uses the exact same technology as this unit.
Even though it may look big in the pictures, the Kingwin XT-1264 weighs in at a relatively light 467 grams.with a fan attached. This does put it at a distinct size disadvantage when compared to other HDT coolers we have reviewed; and in fact, it is one of the lightest weight coolers we have reviewed in a long while.
Making things slightly worse is the fact that this cooler can only mount a single fan and it uses the less than optimal (in an aftermarket cooler) push pin style mounting setup found on stock Intel coolers. Sure, a second fan can be mounted but not without extensive modifications to the lower portion of the fin array.
The top of the base has nine mini-sized heatpipes added to it, much like the OCZ Gladiator Max, Xigmatek Thors Hammer and a host of other HDT coolers out there. The theory behind these mini heatpipes they help dissipate the heat that builds up in the aluminum sections between the heatpipes which in effect should add to the thermal efficiency of this cooler. The fatal flaw in this theory is that they are below the fan and are thus passively cooled but Kingwin has added smaller fins to increase the surface area of these mini cooling towers.
The heatpipes themselves have been slightly bent inwards to form the base of this cooler, and the base itself has a decidedly poor finish even for an HDT-based unit. Also on the positive side, the gaps between the aluminum pillars and the flattened HDTs are relatively small so they shouldnt suck up as much thermal compound other HDT heatsinks.
When it comes to the 120mm fan which ships with this unit, things are little bit murkier as the label shows a product number of AD0912HX-A7BGL. When you decode this label it tells you that this is a 92*92*25mm fan.which is obviously incorrect. Most likely this label was supposed to be AD1212HX-A7BGL, which would make this a higher speed version of the ADDA fan which graces the Ximgatek S1283. Basically, this is a 7 bladed 120x25mm hypro bearing fan made by ADDA which is PWM capable and designed to run between 1000 and 2200RPMs. At its maximum nominal speed of 2200RPMs it is rated to move about 99.6CFM.
The above specs are based on the assumption that this is an AD1212HX-A7BGL, and there is some evidence that we may be incorrect. According Kingwin THEIR version of this fan is rated for 700 2300RPMs, moves 82.0 101.2 CFM and has between 3.28 3.97mm of static pressure. We are inclined to believe most of their specifications as it is fairly close to the ones listed above. The only part of their specifications we have issues with is we are not sure how ANY 120x25mm fan can move that much air at 700rpms, nor have so much static pressure at such low speeds.
Unfortunately, this fan also displays a lot of shaft slop but no off axis slop which we are more worried about. Forward and backward motion or shaft slop is not an issues and it really is only when you have a lot of off axis slop that it becomes an issue. Honestly, we have no doubts about this fan lasting a long while.
The hypro bearing (as ADDAs patented tweak on the design is called) or the Rifle bearing as it is usually called, is a unique hybrid sleeve bearing design in which a normal sleeve bearing has been modified so that there is a continuous groove (that looks a lot like lands and groves of a rifled gun barrel) on the bearing shaft which keeps a constant flow of oil moving between the shaft and the bearing. While they may not be as quiet as normal sleeve bearings, they do have a longer life expectancy. To make things even more interesting, ADDA has added a magnetic field to prevent friction between the bearing and fan hub, further increasing the life of the bearing. On the positive side, this fan is PWM capable.
Latest Reviews in Cooling
March 15, 2010
When it comes to CPU coolers, most consumers usually have to choose between a low price or good performance since there are very few products on the market that feature both. With their Traquillo, Ge...
January 28, 2010
When we last looked at Zalman's new CNPS10X family with the Extreme version, there seemed to be a lot to like but there were some shortcomings as well. Zalman has now launched the Flex Edition which ...
January 5, 2010
At the upcoming CES 2010 show, Zalman will be showing a number of their new products which include cases, coolers and even some new 3D products. In this article, we take a quick, pictorial look at som...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/23884-intel-core-i7-lga1366-cpu-cooler-roundup.html
Posted By Date
Cheat Engine :: View topic - Cooler Master V10 Yesterday 09:21 PM
PC Pitstop Forums > Shopping List February 25, 2010 07:58 AM
Building a new computer... February 8, 2010 08:26 AM
Tuniq Tower 120 Extreme CPU Cooler February 7, 2010 07:53 PM
IT's MINE January 31, 2010 09:23 AM
Get your RIGS out for the lads! - Page 47 - AVForums.com January 26, 2010 03:39 PM
Elite Bastards - Thursday news round up January 25, 2010 02:43 AM
nolan's Bookmarks on Delicious January 20, 2010 03:49 PM
Virtual-Hideout.Net | News Archive January 16, 2010 08:29 PM
Shopping List - PC Pitstop Forums January 15, 2010 05:48 PM
which HSF performace is superb in a price range? January 7, 2010 10:19 AM
Review of Prolimatech Mega Shadow Deluxe Edition, Review Prolimatech Mega Shadow Deluxe Edition - Cooling January 4, 2010 12:05 PM
Review of Spire Thermax 2 SP679S1-PCI, Review Spire Thermax 2 SP679S1-PCI - Cooling - Page 1 of 2 December 27, 2009 01:25 PM
Best air coolers for the lga 1366 socket! - Overclock.net - Overclocking.net December 17, 2009 04:58 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 3 December 17, 2009 10:16 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 18 December 13, 2009 09:55 AM
Links on "Game Over!" | Facebook December 11, 2009 01:01 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 5 December 9, 2009 06:19 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 20 December 9, 2009 11:54 AM
techPowerUp! :: Review Database December 6, 2009 12:31 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - FrostyTech News December 5, 2009 03:59 PM
FrostyTech - Best Heat Sinks & PC Cooling Reviews December 4, 2009 09:26 PM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking November 30, 2009 02:33 AM
Foros Cantv.net: Publica fotos de tu computador :) November 29, 2009 03:57 PM
iXBT Labs - News Archive November 23, 2009 08:29 AM
CPU Heatsinks temps... - Page 2 - Overclock.net - Overclocking.net November 22, 2009 05:58 PM
Just Bought 8 Gentle Typhoons @ 1850rpm, Post Up A Good PC Case For 'Em - [H]ard|Forum November 21, 2009 12:08 AM
Just Bought 8 Gentle Typhoons @ 1850rpm, Post Up A Good PC Case For 'Em - [H]ard|Forum November 20, 2009 05:09 AM
E758 - Help me decide on a heatsink/fan November 20, 2009 04:59 AM
Simple Water Cooling - AVForums.com November 19, 2009 07:05 AM
What's in the box? November 15, 2009 01:34 PM
ġũ November 12, 2009 11:46 PM
processor cooler de Zalman CNPS9900 LED of Zalman CNPS 10X - Processors, Moederborden & Geheugen - GoT November 12, 2009 01:52 PM
PC Perspective - News Archive November 9, 2009 06:06 PM
Need to get rid of the beast - Overclock.net - Overclocking.net November 9, 2009 03:31 PM
Untitled document November 6, 2009 01:56 AM
Review of Spire Thermax 2 SP679S1-PCI, Review Spire Thermax 2 SP679S1-PCI - Cooling - Page 1 of 2 November 5, 2009 02:09 AM
I have about $2200 what should I get? - Page 2 - Overclock.net - Overclocking.net November 4, 2009 07:28 AM
News Items 0-2045 October 31, 2009 08:22 AM
Лучший сайт про моддинг - ModMag.net: Тест семи процессорных кулеров для Intel Core i7 October 30, 2009 03:04 PM
iXBT Labs - Daily Mailbox October 30, 2009 07:47 AM
welcome to ZEROtherm October 28, 2009 09:33 PM
News des 23. Oktober 2009 | 3DCenter.org October 28, 2009 04:54 PM
silentpcreview.com | View topic - ZEROtherm Nirvana CPU Cooler October 28, 2009 07:13 AM
Technology Geeks - The New Stuff: Intel Core i7 / LGA1366 CPU Cooler Roundup October 26, 2009 11:12 PM
Worried about Q9550 Yorkfield temps... - Page 2 - Overclock.net - Overclocking.net October 26, 2009 11:35 AM
PC Perspective - The #1 Choice for PC Hardware Reviews and Information October 26, 2009 10:53 AM
Hardware Roundup - HotHardware October 25, 2009 03:35 PM
Virtual-Hideout - PC Hardware News & Reviews Est. 1999 October 24, 2009 07:54 PM
Blog PcComponentes Lo mejor de la semana October 24, 2009 08:09 AM
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews October 24, 2009 04:57 AM
- - 296 - hardwareBG.com October 23, 2009 04:52 AM
News around the web: Sony unveils 360 3D display - TechSpot News October 23, 2009 04:36 AM
Elite Bastards - News October 23, 2009 03:19 AM
The breadbox - The Tech Report October 23, 2009 01:54 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - PCAXE forum October 23, 2009 01:41 AM
Techgage - Home October 22, 2009 11:11 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup October 22, 2009 08:55 PM
Overclockers Online October 22, 2009 06:16 PM
Top news stories - The Tech Report October 22, 2009 04:56 PM
The Macross - Super Desktop Computer - Page 4 - Mac Forums October 22, 2009 03:55 PM
Thursday Shortbread - The Tech Report October 22, 2009 03:44 PM
TechConnect Magazine - Techconnect Review Round-up 22/10/09 October 22, 2009 12:22 PM
Warp2Search.net October 22, 2009 12:00 PM
Comparativa Disipadores Gama Alta Para I7 - HardLimit October 22, 2009 10:42 AM
[TweakNews] Computer Hardware and Consumer Electronics news and comprehensive reviews. October 22, 2009 10:38 AM
October 22 News from Around the Web : News From Around The Web October 22, 2009 09:48 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - Intel Core i7 / LGA1366 October 22, 2009 09:10 AM
Blue's News - All the carnage that's fit to post! October 22, 2009 07:09 AM
Daily Reviews Summary 10/22/09 October 22, 2009 07:05 AM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking October 22, 2009 06:18 AM
NT Compatible - Daily Windows News and Information October 22, 2009 05:36 AM
techPowerUp! - The latest in hardware and gaming October 22, 2009 05:10 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup October 22, 2009 03:46 AM
Intel Test: LGA1366 CPU Cooler Roundup - Hardwareboard.eu - Das ultimative Hardware Forum October 22, 2009 03:41 AM
Thursday Morning Roundup :: TweakTown October 22, 2009 02:03 AM
Coolit Systems Domino Worth it? - Page 2 - Overclock.net - Overclocking.net October 22, 2009 01:17 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup @ Hardware Canucks October 22, 2009 12:24 AM
Seven-Way Intel Core i7 LGA1366 CPU Cooler Roundup - Futuremark / YouGamers Forums October 22, 2009 12:11 AM
Seven-Way Intel Core i7 LGA1366 CPU Cooler Roundup - Futuremark / YouGamers Forums October 21, 2009 11:30 PM
Hardware Round-UP (22/10/09) October 21, 2009 11:13 PM
Futuremark - News - Newsarticle October 21, 2009 10:04 PM
ms_reviews October 21, 2009 09:06 PM
Prolimatech Megahalems or Mega Shadow Deluxe October 21, 2009 07:29 PM
OCTools - Reinventing the Tools of OC October 21, 2009 07:06 PM
