Categories
Review Contents:
Intel Core i7 / LGA1366 CPU Cooler Roundup
by AkG     |     October 20, 2009
Conclusions
ProlimaTech Mega Shadow Deluxe Edition
After performance numbers like this monster posted what can you say but...wow. It really is a great cooler and it really does work wonderfully at a wide range of fan speeds. The only issue we have here is that the Mega Shadow seems to be nothing more than a gussied-up Megahalems with a fancy new all black look. Is this a bad thing per say? Not at all. We were just hoping to see something more from ProlimaTech, especially considering this product sports a brand new name. Yes, it has a revised and thankfully simplified mounting system but thats about it.
To be totally honest this is not entirely fair to the Mega Shadow since it truly is gorgeous to look at and has the ability to cool off overclocked i7 CPUs like no ones business. It is also great to see that its improved backplate is compatible with 775, i7 and i5 (unlike the Megahalems which is 775 and i7 only) but there is still no AMD lovin here. Compared to these other redeeming qualities, the fact that the Shadow ships with four wire fan clips may not seem like a big deal but to us it is. The ability to mount a pair of 120mm fans allows the Mega Shadow to increase its performance by leaps and bounds even with a pair of lower speed fans.
The only limiting factor that this cooler has is its somewhat extreme price tag. Hopefully as time goes by it will come down from its presently stratospheric level so it will be more appealing to a wider range of consumers but we sort of like the exclusivity the price brings. The Mega Shadow really is the best of the best and with its enhanced mounting abilities we think it deserves to not only our Damn Good award to also be crowned our new king of the air coolers. If you are willing to pay for the best, then this is where the buck stops.
Pros:
- Best in class cooling performance
- Dual fan capable
- Multi-socket Intel mounting abilities
- Easy installation
- Gorgeous looks
Cons:
- Price
- No fan included
Spire TherMax 2
When all is said and done, the TherMax 2 is a good cooler for mild to moderate overclocking and many people will find it to be a decent choice. It really is not stellar at any speed but is not a terrible choice either. Honestly, with a bit of work on Spire's end with regards to the quality of the base and the inclusion of a backplate-based mounting setup, the TherMax series could be a real contender.
Unfortunately, a lot of that performance came from the fact that Spire needed to use an extremely noisy fan to push air through the oddly shaped fin array. When the fan was changed out for one with a less noticeable acoustical footprint, the TherMax 2 was still a lot better than stock cooling solution but it began to suffer a bit. It really is only when you get down into the ultra low range with 900RPM fans that things really take a turn for the worse. As long as you stick with a more typical 1300 1500 RPM range most people will be more than satisfied with the results.
In the end this would not be the first cooler we would chose for most situations but with its broad compatibility range and decent results it would be far from the last cooler we go with. There are however, better choices out there if budget is first and foremost in your mind.
Pros:
- Reasonable price
- Decent cooling performance at lower heat loads
- Very good value (up to moderate heat loads)
Cons:
- Not a great choice for low noise situations
- Only able to mount one fan
- AMD type mounting setup for Intel systems
- Very loud fan
Latest Reviews in Cooling
August 30, 2010
Shaped like a bona fide V6 engine, Cooler Master's new V6 GT heatsink is aiming to knock several high end coolers off of their respective thrones. To accomplish this, the V6 GT is equipped with a pai...
August 15, 2010
Closed system water cooling units have been gaining popularity over the last two years or so and it is only natural that we have seen a gradual evolution in their designs. Corsair is now taking the n...
August 12, 2010
CPU coolers specifically designed for small form factor applications are few and far between but Prolimatech has now thrown their hats into this ring with the new Samuel 17. Able to mount a 120mm fan...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/23884-intel-core-i7-lga1366-cpu-cooler-roundup.html
Posted By Date
Nice Budget Air Cooler for i7 930? - Overclock.net - Overclocking.net July 9, 2010 03:31 AM
Hi, I'm Hillskill and this is my first PC Build - AVForums.com - Page 3 May 26, 2010 03:11 PM
[Solved] New i7 cpu cooler suggestions - CPUs - CPU-Components May 21, 2010 03:51 PM
[Solved] New i7 cpu cooler suggestions - CPUs - CPU-Components May 20, 2010 07:39 PM
Review of Thermalright Cogage TRUE Spirit , Review Thermalright Cogage TRUE Spirit - Cooling - Page 1 of 3 May 19, 2010 08:37 PM
New i7 cpu cooler suggestions - CPUs - CPU-Components May 19, 2010 03:15 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Computing April 30, 2010 05:09 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup @ Hardware Canucks - Compatible Support Forums April 9, 2010 06:02 PM
Reply to a thread: Get a Cooler for i7 - Neoseeker Forums April 9, 2010 01:33 PM
Get a Cooler for i7 - Computer Hardware & Overclocking - Neoseeker Forums April 9, 2010 01:20 PM
Hi, I'm Hillskill and this is my first PC Build - Page 5 - AVForums.com April 5, 2010 11:01 AM
Too hot at stock voltages? - Overclockers Australia Forums April 5, 2010 01:03 AM
Los Top Coolers Actuales para Core i7 - Guru de la PC March 25, 2010 11:01 AM
Cheat Engine :: View topic - Cooler Master V10 March 20, 2010 09:21 PM
PC Pitstop Forums > Shopping List February 25, 2010 07:58 AM
Building a new computer... February 8, 2010 08:26 AM
Tuniq Tower 120 Extreme CPU Cooler February 7, 2010 07:53 PM
IT's MINE January 31, 2010 09:23 AM
Get your RIGS out for the lads! - Page 47 - AVForums.com January 26, 2010 03:39 PM
Elite Bastards - Thursday news round up January 25, 2010 02:43 AM
nolan's Bookmarks on Delicious January 20, 2010 03:49 PM
Virtual-Hideout.Net | News Archive January 16, 2010 08:29 PM
Shopping List - PC Pitstop Forums January 15, 2010 05:48 PM
which HSF performace is superb in a price range? January 7, 2010 10:19 AM
Review of Prolimatech Mega Shadow Deluxe Edition, Review Prolimatech Mega Shadow Deluxe Edition - Cooling January 4, 2010 12:05 PM
Review of Spire Thermax 2 SP679S1-PCI, Review Spire Thermax 2 SP679S1-PCI - Cooling - Page 1 of 2 December 27, 2009 01:25 PM
Best air coolers for the lga 1366 socket! - Overclock.net - Overclocking.net December 17, 2009 04:58 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 3 December 17, 2009 10:16 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 18 December 13, 2009 09:55 AM
Links on "Game Over!" | Facebook December 11, 2009 01:01 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 5 December 9, 2009 06:19 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 20 December 9, 2009 11:54 AM
techPowerUp! :: Review Database December 6, 2009 12:31 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - FrostyTech News December 5, 2009 03:59 PM
FrostyTech - Best Heat Sinks & PC Cooling Reviews December 4, 2009 09:26 PM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking November 30, 2009 02:33 AM
Foros Cantv.net: Publica fotos de tu computador :) November 29, 2009 03:57 PM
iXBT Labs - News Archive November 23, 2009 08:29 AM
CPU Heatsinks temps... - Page 2 - Overclock.net - Overclocking.net November 22, 2009 05:58 PM
Just Bought 8 Gentle Typhoons @ 1850rpm, Post Up A Good PC Case For 'Em - [H]ard|Forum November 21, 2009 12:08 AM
Just Bought 8 Gentle Typhoons @ 1850rpm, Post Up A Good PC Case For 'Em - [H]ard|Forum November 20, 2009 05:09 AM
E758 - Help me decide on a heatsink/fan November 20, 2009 04:59 AM
Simple Water Cooling - AVForums.com November 19, 2009 07:05 AM
What's in the box? November 15, 2009 01:34 PM
ġũ November 12, 2009 11:46 PM
processor cooler de Zalman CNPS9900 LED of Zalman CNPS 10X - Processors, Moederborden & Geheugen - GoT November 12, 2009 01:52 PM
PC Perspective - News Archive November 9, 2009 06:06 PM
Need to get rid of the beast - Overclock.net - Overclocking.net November 9, 2009 03:31 PM
Untitled document November 6, 2009 01:56 AM
Review of Spire Thermax 2 SP679S1-PCI, Review Spire Thermax 2 SP679S1-PCI - Cooling - Page 1 of 2 November 5, 2009 02:09 AM
I have about $2200 what should I get? - Page 2 - Overclock.net - Overclocking.net November 4, 2009 07:28 AM
News Items 0-2045 October 31, 2009 08:22 AM
Лучший сайт про моддинг - ModMag.net: Тест семи процессорных кулеров для Intel Core i7 October 30, 2009 03:04 PM
iXBT Labs - Daily Mailbox October 30, 2009 07:47 AM
welcome to ZEROtherm October 28, 2009 09:33 PM
News des 23. Oktober 2009 | 3DCenter.org October 28, 2009 04:54 PM
silentpcreview.com | View topic - ZEROtherm Nirvana CPU Cooler October 28, 2009 07:13 AM
Technology Geeks - The New Stuff: Intel Core i7 / LGA1366 CPU Cooler Roundup October 26, 2009 11:12 PM
Worried about Q9550 Yorkfield temps... - Page 2 - Overclock.net - Overclocking.net October 26, 2009 11:35 AM
PC Perspective - The #1 Choice for PC Hardware Reviews and Information October 26, 2009 10:53 AM
Hardware Roundup - HotHardware October 25, 2009 03:35 PM
Virtual-Hideout - PC Hardware News & Reviews Est. 1999 October 24, 2009 07:54 PM
Blog PcComponentes Lo mejor de la semana October 24, 2009 08:09 AM
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews October 24, 2009 04:57 AM
- - 296 - hardwareBG.com October 23, 2009 04:52 AM
News around the web: Sony unveils 360 3D display - TechSpot News October 23, 2009 04:36 AM
Elite Bastards - News October 23, 2009 03:19 AM
The breadbox - The Tech Report October 23, 2009 01:54 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - PCAXE forum October 23, 2009 01:41 AM
Techgage - Home October 22, 2009 11:11 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup October 22, 2009 08:55 PM
Overclockers Online October 22, 2009 06:16 PM
Top news stories - The Tech Report October 22, 2009 04:56 PM
The Macross - Super Desktop Computer - Page 4 - Mac Forums October 22, 2009 03:55 PM
Thursday Shortbread - The Tech Report October 22, 2009 03:44 PM
TechConnect Magazine - Techconnect Review Round-up 22/10/09 October 22, 2009 12:22 PM
Warp2Search.net October 22, 2009 12:00 PM
Comparativa Disipadores Gama Alta Para I7 - HardLimit October 22, 2009 10:42 AM
[TweakNews] Computer Hardware and Consumer Electronics news and comprehensive reviews. October 22, 2009 10:38 AM
October 22 News from Around the Web : News From Around The Web October 22, 2009 09:48 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - Intel Core i7 / LGA1366 October 22, 2009 09:10 AM
Blue's News - All the carnage that's fit to post! October 22, 2009 07:09 AM
Daily Reviews Summary 10/22/09 October 22, 2009 07:05 AM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking October 22, 2009 06:18 AM
NT Compatible - Daily Windows News and Information October 22, 2009 05:36 AM
techPowerUp! - The latest in hardware and gaming October 22, 2009 05:10 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup October 22, 2009 03:46 AM
Intel Test: LGA1366 CPU Cooler Roundup - Hardwareboard.eu - Das ultimative Hardware Forum October 22, 2009 03:41 AM
Thursday Morning Roundup :: TweakTown October 22, 2009 02:03 AM
Coolit Systems Domino Worth it? - Page 2 - Overclock.net - Overclocking.net October 22, 2009 01:17 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup @ Hardware Canucks October 22, 2009 12:24 AM
Seven-Way Intel Core i7 LGA1366 CPU Cooler Roundup - Futuremark / YouGamers Forums October 22, 2009 12:11 AM
Seven-Way Intel Core i7 LGA1366 CPU Cooler Roundup - Futuremark / YouGamers Forums October 21, 2009 11:30 PM
Hardware Round-UP (22/10/09) October 21, 2009 11:13 PM
Futuremark - News - Newsarticle October 21, 2009 10:04 PM
ms_reviews October 21, 2009 09:06 PM
Prolimatech Megahalems or Mega Shadow Deluxe October 21, 2009 07:29 PM
OCTools - Reinventing the Tools of OC October 21, 2009 07:06 PM
