Review Contents:
Intel Core i7 / LGA1366 CPU Cooler Roundup
by AkG     |     October 20, 2009
Zalman CNPS10X Extreme Installation
Actually installing the 10X is fairly easy and unlike some past reviews, we dont have a problem with the overall process at all. What we do have an issue with however is the fact that this massive cooler doesnt make use of a back plate to help distribute its substantial weight. Rather, it uses a somewhat flaccid hybrid mounting setup consisting of four screws with plastic sleeves that mount atop the main retention bracket. The only time a hybrid mount is a good idea is when youre dealing with low-weight water blocks. But here we have damn near two pounds hanging off your motherboard with only small plastic sleeves to keep those brass screws from stripping out the i7 mounting holes. Yikes.
The trick is to thread these screws through the four holes and then stick the small plastic washer/ sheaths into the holes. Then, you have to mount a large yet flimsy plastic structure over the screws which seems to be used to avoid damage to or flexing of the motherboards PCB. But wait, were not done yet!
Once you have this skeleton bracket in place you then mount a metal bracket right on top of it. The only upside to this is the metal bracket uses captured tension springs on the four corner bolts which means you cant over tighten the screws. This combination does allow for even mounting pressure as long as that plastic bracket doesnt warp in any way, shape or form.
Continuing on this theme of what were they thinking mentality, the metal bracket has two small tabs which are all that comes into contact with the coolers base. Unfortunately, this means the 10X is allowed to spin around much like the original Thermalright TRUE and can actually slide enough that its base hangs partially off the side of the CPU.
Intel i7 Installation
On the positive side this cooler seems to be custom designed for an East / West setup with the fan pushing air towards the rear exhaust fans of your case. This certainly a good thing as this is the typical setup for nearly every user out there.
As you can see, the fin array starts up high and does not block, rub or even come near most of the heatsinks surrounding our motherboard. On the ram side, things are tight but as long as your ram is a typical width the height shouldnt matter too much.
AMD Installation
Well those pictures say it all and this cooler was certainly not designed to be an AMD cooler first and foremost. The biggest and most obvious issue is the ram slots being blocked. This could be just due to our DFI motherboard layoutbut we doubt it. The next issue and the one which really seals the deal for us is that this cooler can only be orientated in a North / South orientation on AMD systems. This is due to the simple fact that the heat pipe orientation and the standard AMD retention system orientation are incompatible with a more typical East / West orientation.
Ok, its official: we dont like the installation of this cooler and it is easily one of the most ill conceived, poorly executed, unintuitive, under-thought, snatching defeat from the jaws of victory setups we have ever seen. What makes this really bad is we can see the glimmer of potential and with only a few small tweaks it could have been great. As we said, earlier if this cooler used an honest to goodness back plate, the top sub-frame was not made from plastic and the securing tabs were bigger and thus more secure, this could have really have allowed the X10 Extreme to shine. As it stands we wonder how big a liability this setup is going to be. And dont get us started with the ass-backwards AMD mounting
Latest Reviews in Cooling
March 15, 2010
When it comes to CPU coolers, most consumers usually have to choose between a low price or good performance since there are very few products on the market that feature both. With their Traquillo, Ge...
January 28, 2010
When we last looked at Zalman's new CNPS10X family with the Extreme version, there seemed to be a lot to like but there were some shortcomings as well. Zalman has now launched the Flex Edition which ...
January 5, 2010
At the upcoming CES 2010 show, Zalman will be showing a number of their new products which include cases, coolers and even some new 3D products. In this article, we take a quick, pictorial look at som...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/23884-intel-core-i7-lga1366-cpu-cooler-roundup.html
Posted By Date
Cheat Engine :: View topic - Cooler Master V10 Yesterday 09:21 PM
PC Pitstop Forums > Shopping List February 25, 2010 07:58 AM
Building a new computer... February 8, 2010 08:26 AM
Tuniq Tower 120 Extreme CPU Cooler February 7, 2010 07:53 PM
IT's MINE January 31, 2010 09:23 AM
Get your RIGS out for the lads! - Page 47 - AVForums.com January 26, 2010 03:39 PM
Elite Bastards - Thursday news round up January 25, 2010 02:43 AM
nolan's Bookmarks on Delicious January 20, 2010 03:49 PM
Virtual-Hideout.Net | News Archive January 16, 2010 08:29 PM
Shopping List - PC Pitstop Forums January 15, 2010 05:48 PM
which HSF performace is superb in a price range? January 7, 2010 10:19 AM
Review of Prolimatech Mega Shadow Deluxe Edition, Review Prolimatech Mega Shadow Deluxe Edition - Cooling January 4, 2010 12:05 PM
Review of Spire Thermax 2 SP679S1-PCI, Review Spire Thermax 2 SP679S1-PCI - Cooling - Page 1 of 2 December 27, 2009 01:25 PM
Best air coolers for the lga 1366 socket! - Overclock.net - Overclocking.net December 17, 2009 04:58 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 3 December 17, 2009 10:16 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 18 December 13, 2009 09:55 AM
Links on "Game Over!" | Facebook December 11, 2009 01:01 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 5 December 9, 2009 06:19 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 20 December 9, 2009 11:54 AM
techPowerUp! :: Review Database December 6, 2009 12:31 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - FrostyTech News December 5, 2009 03:59 PM
FrostyTech - Best Heat Sinks & PC Cooling Reviews December 4, 2009 09:26 PM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking November 30, 2009 02:33 AM
Foros Cantv.net: Publica fotos de tu computador :) November 29, 2009 03:57 PM
iXBT Labs - News Archive November 23, 2009 08:29 AM
CPU Heatsinks temps... - Page 2 - Overclock.net - Overclocking.net November 22, 2009 05:58 PM
Just Bought 8 Gentle Typhoons @ 1850rpm, Post Up A Good PC Case For 'Em - [H]ard|Forum November 21, 2009 12:08 AM
Just Bought 8 Gentle Typhoons @ 1850rpm, Post Up A Good PC Case For 'Em - [H]ard|Forum November 20, 2009 05:09 AM
E758 - Help me decide on a heatsink/fan November 20, 2009 04:59 AM
Simple Water Cooling - AVForums.com November 19, 2009 07:05 AM
What's in the box? November 15, 2009 01:34 PM
ġũ November 12, 2009 11:46 PM
processor cooler de Zalman CNPS9900 LED of Zalman CNPS 10X - Processors, Moederborden & Geheugen - GoT November 12, 2009 01:52 PM
PC Perspective - News Archive November 9, 2009 06:06 PM
Need to get rid of the beast - Overclock.net - Overclocking.net November 9, 2009 03:31 PM
Untitled document November 6, 2009 01:56 AM
Review of Spire Thermax 2 SP679S1-PCI, Review Spire Thermax 2 SP679S1-PCI - Cooling - Page 1 of 2 November 5, 2009 02:09 AM
I have about $2200 what should I get? - Page 2 - Overclock.net - Overclocking.net November 4, 2009 07:28 AM
News Items 0-2045 October 31, 2009 08:22 AM
Лучший сайт про моддинг - ModMag.net: Тест семи процессорных кулеров для Intel Core i7 October 30, 2009 03:04 PM
iXBT Labs - Daily Mailbox October 30, 2009 07:47 AM
welcome to ZEROtherm October 28, 2009 09:33 PM
News des 23. Oktober 2009 | 3DCenter.org October 28, 2009 04:54 PM
silentpcreview.com | View topic - ZEROtherm Nirvana CPU Cooler October 28, 2009 07:13 AM
Technology Geeks - The New Stuff: Intel Core i7 / LGA1366 CPU Cooler Roundup October 26, 2009 11:12 PM
Worried about Q9550 Yorkfield temps... - Page 2 - Overclock.net - Overclocking.net October 26, 2009 11:35 AM
PC Perspective - The #1 Choice for PC Hardware Reviews and Information October 26, 2009 10:53 AM
Hardware Roundup - HotHardware October 25, 2009 03:35 PM
Virtual-Hideout - PC Hardware News & Reviews Est. 1999 October 24, 2009 07:54 PM
Blog PcComponentes Lo mejor de la semana October 24, 2009 08:09 AM
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews October 24, 2009 04:57 AM
- - 296 - hardwareBG.com October 23, 2009 04:52 AM
News around the web: Sony unveils 360 3D display - TechSpot News October 23, 2009 04:36 AM
Elite Bastards - News October 23, 2009 03:19 AM
The breadbox - The Tech Report October 23, 2009 01:54 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - PCAXE forum October 23, 2009 01:41 AM
Techgage - Home October 22, 2009 11:11 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup October 22, 2009 08:55 PM
Overclockers Online October 22, 2009 06:16 PM
Top news stories - The Tech Report October 22, 2009 04:56 PM
The Macross - Super Desktop Computer - Page 4 - Mac Forums October 22, 2009 03:55 PM
Thursday Shortbread - The Tech Report October 22, 2009 03:44 PM
TechConnect Magazine - Techconnect Review Round-up 22/10/09 October 22, 2009 12:22 PM
Warp2Search.net October 22, 2009 12:00 PM
Comparativa Disipadores Gama Alta Para I7 - HardLimit October 22, 2009 10:42 AM
[TweakNews] Computer Hardware and Consumer Electronics news and comprehensive reviews. October 22, 2009 10:38 AM
October 22 News from Around the Web : News From Around The Web October 22, 2009 09:48 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - Intel Core i7 / LGA1366 October 22, 2009 09:10 AM
Blue's News - All the carnage that's fit to post! October 22, 2009 07:09 AM
Daily Reviews Summary 10/22/09 October 22, 2009 07:05 AM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking October 22, 2009 06:18 AM
NT Compatible - Daily Windows News and Information October 22, 2009 05:36 AM
techPowerUp! - The latest in hardware and gaming October 22, 2009 05:10 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup October 22, 2009 03:46 AM
Intel Test: LGA1366 CPU Cooler Roundup - Hardwareboard.eu - Das ultimative Hardware Forum October 22, 2009 03:41 AM
Thursday Morning Roundup :: TweakTown October 22, 2009 02:03 AM
Coolit Systems Domino Worth it? - Page 2 - Overclock.net - Overclocking.net October 22, 2009 01:17 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup @ Hardware Canucks October 22, 2009 12:24 AM
Seven-Way Intel Core i7 LGA1366 CPU Cooler Roundup - Futuremark / YouGamers Forums October 22, 2009 12:11 AM
Seven-Way Intel Core i7 LGA1366 CPU Cooler Roundup - Futuremark / YouGamers Forums October 21, 2009 11:30 PM
Hardware Round-UP (22/10/09) October 21, 2009 11:13 PM
Futuremark - News - Newsarticle October 21, 2009 10:04 PM
ms_reviews October 21, 2009 09:06 PM
Prolimatech Megahalems or Mega Shadow Deluxe October 21, 2009 07:29 PM
OCTools - Reinventing the Tools of OC October 21, 2009 07:06 PM
