Review Contents:
Intel Core i7 / LGA1366 CPU Cooler Roundup
by AkG     |     October 20, 2009
Spire TherMax 2
The box that the TherMax 2 came in really did get a good going over by Mr. Shipping Agent and it does show; however, the contents of the box were perfectly fine. To us this is the best accolade you can give a package: it did its job.
On three of the four sides the TherMax 2 is more than adequately protected, but on the front side a good sharp blow in the wrong place could have caused this story to have a much different ending. As you know,plastic film windows are a pet peeve of ours and this may not be the biggest windowed box we have seen. However, we cant complain since the box did take a lickin and keep on ticking.
The TherMax 2 is a very interesting looking cooler, as you can tell this cooler fin design forms a big X. This may be very ascetically pleasing to the eye (or not depending on your personal tastes) but it does have the unintended consequence of significantly reducing the surface area of the fin array.you know the array of fins which cools the heatpipes. Basically, this is definitely not a good thing since the heatpipes need to have the maximum amount of fin surface area in order to dissipate heat.
The other faux pas of this X design is that a good portion of the air from the fan is going to be lost out the sides and will not force its way back to the other side of the X. In theory, this could leave half the cooler outside of the fans airflow. The first thing that crossed our minds was: what were they thinking?
On the positive side, this cooler has an HDT base which could help it in high thermal circumstances. However, this could also work as a double-edged sword since an increase of heat being transferred to cooling fins that arent being actively cooled by the fans airflow can lead to high CPU temperatures.
Taking a closer look at the base of the TherMax 2, we instantly knew the design wasnt the only thing that it has going against it. The polishing and quality of finish is about what the original Xigmatek S1283 sported, which means not good at all. It may not be terrible, but it certainly is not anywhere near best in class. All in all, we dont expect much from this heatsink but we have been known to be surprised in the past, so anything is possible.
The fan which accompanies the TherMax 2 is a sleeve bearing 120mm, 2200RPM unit and in what seems to be a reoccurring theme in this review, no model number is listed on the fan nor is there a 3rd party manufacturers logo or name anywhere to be seen. To us this means its either made by Spire or they just wanted their sticker to cover up any trace of the actual manufacturer. On the positive side this fan at its rated speed of 2200RPMs moves an impressive 93.3 cubic feet per minute. Unlike many we are going to look at today this fan is not PWM complaint and thus the only way to change the speed of the fan is via voltage adjustment. On the plus side, the power cable of the fan is a decent length and while it is not sheathed it is a flat wire style with all four cables stuck together.
As with many sleeve bearing fans this fan exhibits a bit of shaft slop, which is nothing to worry about. What is worrisome is a fan moving at the speed this one does also exhibits a lot of off axis slop. At best this combination will result in a fan which is noisier than it should be and at worst will have a shorter lifespan.
Latest Reviews in Cooling
March 15, 2010
When it comes to CPU coolers, most consumers usually have to choose between a low price or good performance since there are very few products on the market that feature both. With their Traquillo, Ge...
January 28, 2010
When we last looked at Zalman's new CNPS10X family with the Extreme version, there seemed to be a lot to like but there were some shortcomings as well. Zalman has now launched the Flex Edition which ...
January 5, 2010
At the upcoming CES 2010 show, Zalman will be showing a number of their new products which include cases, coolers and even some new 3D products. In this article, we take a quick, pictorial look at som...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/23884-intel-core-i7-lga1366-cpu-cooler-roundup.html
Posted By Date
Cheat Engine :: View topic - Cooler Master V10 Yesterday 09:21 PM
PC Pitstop Forums > Shopping List February 25, 2010 07:58 AM
Building a new computer... February 8, 2010 08:26 AM
Tuniq Tower 120 Extreme CPU Cooler February 7, 2010 07:53 PM
IT's MINE January 31, 2010 09:23 AM
Get your RIGS out for the lads! - Page 47 - AVForums.com January 26, 2010 03:39 PM
Elite Bastards - Thursday news round up January 25, 2010 02:43 AM
nolan's Bookmarks on Delicious January 20, 2010 03:49 PM
Virtual-Hideout.Net | News Archive January 16, 2010 08:29 PM
Shopping List - PC Pitstop Forums January 15, 2010 05:48 PM
which HSF performace is superb in a price range? January 7, 2010 10:19 AM
Review of Prolimatech Mega Shadow Deluxe Edition, Review Prolimatech Mega Shadow Deluxe Edition - Cooling January 4, 2010 12:05 PM
Review of Spire Thermax 2 SP679S1-PCI, Review Spire Thermax 2 SP679S1-PCI - Cooling - Page 1 of 2 December 27, 2009 01:25 PM
Best air coolers for the lga 1366 socket! - Overclock.net - Overclocking.net December 17, 2009 04:58 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 3 December 17, 2009 10:16 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 18 December 13, 2009 09:55 AM
Links on "Game Over!" | Facebook December 11, 2009 01:01 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 5 December 9, 2009 06:19 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup - Page 20 December 9, 2009 11:54 AM
techPowerUp! :: Review Database December 6, 2009 12:31 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - FrostyTech News December 5, 2009 03:59 PM
FrostyTech - Best Heat Sinks & PC Cooling Reviews December 4, 2009 09:26 PM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking November 30, 2009 02:33 AM
Foros Cantv.net: Publica fotos de tu computador :) November 29, 2009 03:57 PM
iXBT Labs - News Archive November 23, 2009 08:29 AM
CPU Heatsinks temps... - Page 2 - Overclock.net - Overclocking.net November 22, 2009 05:58 PM
Just Bought 8 Gentle Typhoons @ 1850rpm, Post Up A Good PC Case For 'Em - [H]ard|Forum November 21, 2009 12:08 AM
Just Bought 8 Gentle Typhoons @ 1850rpm, Post Up A Good PC Case For 'Em - [H]ard|Forum November 20, 2009 05:09 AM
E758 - Help me decide on a heatsink/fan November 20, 2009 04:59 AM
Simple Water Cooling - AVForums.com November 19, 2009 07:05 AM
What's in the box? November 15, 2009 01:34 PM
ġũ November 12, 2009 11:46 PM
processor cooler de Zalman CNPS9900 LED of Zalman CNPS 10X - Processors, Moederborden & Geheugen - GoT November 12, 2009 01:52 PM
PC Perspective - News Archive November 9, 2009 06:06 PM
Need to get rid of the beast - Overclock.net - Overclocking.net November 9, 2009 03:31 PM
Untitled document November 6, 2009 01:56 AM
Review of Spire Thermax 2 SP679S1-PCI, Review Spire Thermax 2 SP679S1-PCI - Cooling - Page 1 of 2 November 5, 2009 02:09 AM
I have about $2200 what should I get? - Page 2 - Overclock.net - Overclocking.net November 4, 2009 07:28 AM
News Items 0-2045 October 31, 2009 08:22 AM
Лучший сайт про моддинг - ModMag.net: Тест семи процессорных кулеров для Intel Core i7 October 30, 2009 03:04 PM
iXBT Labs - Daily Mailbox October 30, 2009 07:47 AM
welcome to ZEROtherm October 28, 2009 09:33 PM
News des 23. Oktober 2009 | 3DCenter.org October 28, 2009 04:54 PM
silentpcreview.com | View topic - ZEROtherm Nirvana CPU Cooler October 28, 2009 07:13 AM
Technology Geeks - The New Stuff: Intel Core i7 / LGA1366 CPU Cooler Roundup October 26, 2009 11:12 PM
Worried about Q9550 Yorkfield temps... - Page 2 - Overclock.net - Overclocking.net October 26, 2009 11:35 AM
PC Perspective - The #1 Choice for PC Hardware Reviews and Information October 26, 2009 10:53 AM
Hardware Roundup - HotHardware October 25, 2009 03:35 PM
Virtual-Hideout - PC Hardware News & Reviews Est. 1999 October 24, 2009 07:54 PM
Blog PcComponentes Lo mejor de la semana October 24, 2009 08:09 AM
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews October 24, 2009 04:57 AM
- - 296 - hardwareBG.com October 23, 2009 04:52 AM
News around the web: Sony unveils 360 3D display - TechSpot News October 23, 2009 04:36 AM
Elite Bastards - News October 23, 2009 03:19 AM
The breadbox - The Tech Report October 23, 2009 01:54 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup - PCAXE forum October 23, 2009 01:41 AM
Techgage - Home October 22, 2009 11:11 PM
Intel Core i7 / LGA1366 CPU Cooler Roundup October 22, 2009 08:55 PM
Overclockers Online October 22, 2009 06:16 PM
Top news stories - The Tech Report October 22, 2009 04:56 PM
The Macross - Super Desktop Computer - Page 4 - Mac Forums October 22, 2009 03:55 PM
Thursday Shortbread - The Tech Report October 22, 2009 03:44 PM
TechConnect Magazine - Techconnect Review Round-up 22/10/09 October 22, 2009 12:22 PM
Warp2Search.net October 22, 2009 12:00 PM
Comparativa Disipadores Gama Alta Para I7 - HardLimit October 22, 2009 10:42 AM
[TweakNews] Computer Hardware and Consumer Electronics news and comprehensive reviews. October 22, 2009 10:38 AM
October 22 News from Around the Web : News From Around The Web October 22, 2009 09:48 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - Intel Core i7 / LGA1366 October 22, 2009 09:10 AM
Blue's News - All the carnage that's fit to post! October 22, 2009 07:09 AM
Daily Reviews Summary 10/22/09 October 22, 2009 07:05 AM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking October 22, 2009 06:18 AM
NT Compatible - Daily Windows News and Information October 22, 2009 05:36 AM
techPowerUp! - The latest in hardware and gaming October 22, 2009 05:10 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup October 22, 2009 03:46 AM
Intel Test: LGA1366 CPU Cooler Roundup - Hardwareboard.eu - Das ultimative Hardware Forum October 22, 2009 03:41 AM
Thursday Morning Roundup :: TweakTown October 22, 2009 02:03 AM
Coolit Systems Domino Worth it? - Page 2 - Overclock.net - Overclocking.net October 22, 2009 01:17 AM
Intel Core i7 / LGA1366 CPU Cooler Roundup @ Hardware Canucks October 22, 2009 12:24 AM
Seven-Way Intel Core i7 LGA1366 CPU Cooler Roundup - Futuremark / YouGamers Forums October 22, 2009 12:11 AM
Seven-Way Intel Core i7 LGA1366 CPU Cooler Roundup - Futuremark / YouGamers Forums October 21, 2009 11:30 PM
Hardware Round-UP (22/10/09) October 21, 2009 11:13 PM
Futuremark - News - Newsarticle October 21, 2009 10:04 PM
ms_reviews October 21, 2009 09:06 PM
Prolimatech Megahalems or Mega Shadow Deluxe October 21, 2009 07:29 PM
OCTools - Reinventing the Tools of OC October 21, 2009 07:06 PM
