MSI P55-GD80 LGA1156 Motherboard Review‏
by MAC     |     October 18, 2009
I/O Benchmarks
A first here at Hardware Canucks, we have finally included some basic I/O benchmarks. We love to hear your thoughts and ideas about what to implement and whether we should expand to include LAN and audio tests, so let us know on the forums.
HD Tach 3.0.4 - SATA
For this benchmark, HDTach was used. It shows the potential read speed which you are likely to experience with an Intel X25-M 80GB G1 solid state drive (SSD) on this motherboard. The long test was run to give a slightly more accurate picture. The test was run three times with the results averaged out.
We don’t put much stock in Burst speed readings and this goes double for SSDs; the more important number is the Average Speed number. This number will tell you what to expect from a given drive in normal, day to day operations. The higher the average the faster your entire system will seem.
We also test CPU utilization in order to make sure that there isn't a problem needlessly wasting CPU cycles. Lastly, we have also included the random access time, just as another barometer of overall storage sub-system performance. In both cases, the lower the better.
Although the MSI board exhibited the highest burst speed (and read the description for our thoughts on burst speed), the P7P55D Deluxe was still a tiny bit faster when it came to average read speed.
We are glad to see that all three motherboards have identical CPU utilization and random access times, clearly they are all functioning optimally.
HD Tach 3.0.4 - USB
For this benchmark, HDTach was used. It shows the potential read speed which you are likely to experience from this motherboard's USB 2.0 ports. In this test, we connected an external 2.5" 5400RPM hard drive to a USB port, ran the test three times and averaged the results. The long test was run to give a slightly more accurate picture.
We don’t put much stock in Burst speed readings; the more important number is the Average Speed number. This number will tell you what to expect from a given drive in normal, day to day operations. The higher the average the faster your entire system will seem.
For some reason, the MSI's USB 2.0 performance was consistently a touch slower than the ASUS and Intel models, but it's unnoticeable on a day-to-day basis.
The P55-GD80 tied with the DP55KG when it came to access times, with the ASUS being a little bit faster. CPU utilization was once again equal across the board.
HD Tach 3.0.4 - eSATA
For this benchmark, HDTach was used. It shows the potential read speed which you are likely to experience from this motherboard's eSATA port with an Intel X25-M G1 80GB solid state drive. with these hard drives. The long test was run to give a slightly more accurate picture. The test was run three times with the results averaged out.
Both the P55-GD80 and the P7P55D Deluxe utilize the same JMicron JMB363 controller for eSATA support, and as such they achieved very similar performance levels. Both were a good deal faster than the Intel DP55KG, which uses by a Marvell 88E6145 controller.
Once again, the MSI and ASUS are equal, but Intel board has slightly lower CPU utilization. The access times are identical to when the SSD is plugged directly into the SATA ports, which is an impressive demonstration of eSATA's capabilities.
January 24, 2012
January 2, 2012
November 20, 2011
