ASUS P7P55D Deluxe Lynnfield Motherboard Review
by FiXT     |     September 30, 2009
Included Software
Now that we have the motherboard unpacked and installed, it is time to take a look at some of the software utilities that ASUS has included with the P7P55D Deluxe.
Click on image to enlarge
Here we have the familiar setup screens for the included software CD. It contains all the drivers or ASUS-specific utilities that you will need to get your system up & running. However, we obviously recommend that you visit the ASUS website to get the very latest software revisions.
PC Probe II
Click on images to enlarge
PC Probe II is a system monitoring utility that displays information regarding fan speeds, component temperatures and voltages, as well as alerting users once preset thresholds have been surpassed. As always we like to see some additional voltage readouts, VTT/IMC and memory voltage at the very latest. We also wouldn't mind seeing some integration with Vista's sidebar, just to help clean up the desktop area a bit.
AI Suite
The AI Suite provides basic system information, but its main function is to host shortcuts to five other ASUS utilities and features, namely the EPU-6 Engine, AI NAP, CPU Level Up, Fan Xpert, and TurboV. The AI NAP is an advanced sleep feature that allows users to put their computers to sleep without terminating any tasks. Fan Xpert allows users to select from 7 fan speed profiles that can be individually applied to any fan.
TurboV EVO
For their P55 lineup, ASUS have unveiled TurboV EVO, a new version of their popular overclocking utility. This application allows users to adjust all essential system parameters from within Windows, namely the base clock frequency, CPU voltage, VTT/IMC voltage, memory voltage, and even then CPU voltage and PCH voltage when you click on 'more settings'. All these settings can be tweaked without the need to reboot. This program also allows users to also save profiles and load them from within Windows. As usual, we had a good experience with the program, and we have come to rely on it to make quick on-the-fly adjustments in order to find stable overclock settings in various benchmarking applications.
TurboV EVO also contains the Auto Tuning feature, which will automatically overclock your system by going through five tweaking and stability testing phases. As you will see in our Auto Overclocking Results section, Auto Tuning proved to be quite competent, and since ASUS are continually improving this feature, it will get better and better at safely squeezing extra performance from the available components.
This utility allows you to program some functions for Turbo Key, which can turn the PC power button (or selected keyboard keys) into a physical overclocking button, very much like the Turbo buttons of 386/486-era. This provides novice users a one-touch solution to boost system performance whenever they need it. When the TurboV Remote is installed, the Turbo Key section allows you to associate the A-B-C buttons to three default overclocking profiles, or even to load your own.
T.Probe
The T.Probe utility allows users to see how many MOSFETs are being utilized on the fly, as well as get a representation of the MOSFET temperatures. Ultimately, we find this particular piece of software to be more of a novelty than anything else, especially since it doesn't actually report temperatures in a tangible °C/°F manner.
EPU-6 Engine
First showcased on the P5Q series, the EPU-6 Engine has been one of ASUS's most highly touted features. This utility works in coordination with the EPU (Energy Processing Unit) controller in order to minimize your system's energy consumption. It does this by continuously monitoring and altering the speeds and voltages of the CPU, VGA card, hard drives and fans. There are four manually selectable modes and an automatic mode that varies settings according to system load. Regrettably, unlike Gigabyte's Dynamic Energy Saver (DES) technology, EPU-6 will not work when your system is overclocked, which obviously makes it a less attractive proposition from our power user point-of-view. Can it provide tangible energy efficiency gains? We will verify that in our Power Consumption section.
Express Gate
Last, we have the ExpressGate “instant-on” operating system. This SplashTop Linux mini-OS allows for quick access to basic functions. In mere seconds, users can web browse, view photos, chat via Pigdin, and even make internet calls through Skype. As you can see in the image that is directly above, ExpressGate features an application dock somewhat similar to that which can found in recent Apple OS X versions. It is a convenient way to layout the four included applications. There are also a configuration panel with some very basic setup options.
It was painless to setup thanks to its completely automated installation procedure, and very easy to use. It resides on the hard drive, and prompts you to use it or continue booting normally everytime you start your computer, unless you disable it in the BIOS.
Overall, ExpressGate is useful for those instances where your PC is off and you need the internet or Skype right away, but otherwise it quickly becomes a novelty feature due to its inherent software limitations.
January 24, 2012
January 2, 2012
November 20, 2011
