ASUS P7P55D Deluxe Lynnfield Motherboard Review
by FiXT     |     September 30, 2009
Package & Accessories
Enough with the paper specs, time to check out the product itself starting with a brief look at the package and accessories.
Click on image to enlarge
Here we have the shiny blue/purple-ish box that is the mainstay for nearly all ASUS Intel-based motherboards, but with one minor change: a flap. Although the box is already adorned with logos illustrating this model's numerous features and specifications, the flap has quite a bit of additional information about all of the interesting ASUS-specific features that the P7P55D Deluxe comes with. Essentially, if you take a few moments to look and read the box, you will know exactly what you are getting with this product.
The accessories bundle is a little light, but honestly there's nothing missing. There are six SATA cables, three of which have a 90-degree connectors and the customary IDE cable. There is the anti-EMI I/O panel and Q-Connectors, which make attaching the case cables to the system panel connector a much easier process. ASUS have also included an SLI bridge and a USB/eSATA PCI expansion bracket. Last, but certainly not least, is the one-of-a-kind TurboV remote, which allows for real-time system overclocking in coordination with the TurboV EVO chip. It also allows you to select Turbo Key and EPU profiles.
January 24, 2012
January 2, 2012
November 20, 2011
