ASUS P7P55D Deluxe Lynnfield Motherboard Review
by FiXT     |     September 30, 2009
System Benchmarks
SuperPi Mod v1.5
When running the SuperPI 32MB benchmark, we are calculating Pi to 32 million digits and timing the process. Obviously more CPU power helps in this intense calculation, but the memory sub-system also plays an important role, as does the operating system. We are running one instance of SuperPi via the HyperPi 0.99b interface. This is therefore a single-thread workload.
Here we see the ASUS motherboard completing the calculations 2 seconds faster than its rival, which is roughly 0.3% quicker. Miniscule, but that's expected given the identical configurations.
Cinebench R10
Cinebench R10 64-bit
Test1: Single CPU Image Render
Test2: Multi CPU Image Render
Comparison: Generated Score
Developed by MAXON, creators of Cinema 4D, Cinebench 10 is designed using the popular Cinema software and created to compare system performance in 3D Animation and Photo applications. There are two parts to the test; the first stresses only the primary CPU or Core, the second, makes use of up to 16 CPUs/Cores. Both are done rendering a realistic photo while utilizing various CPU-intensive features such as reflection, ambient occlusion, area lights and procedural shaders
Whatever happened multiplier-wise in the Everest CPU benchmark did not repeat itself in Cinebench, since the ASUS boasts results that are merely 1.5% higher, but every point counts.
PCMark Vantage x64
PCMark Vantage Advanced 64-bit Edition (1.0.0.0)
PCMark Suite / Default Settings
The main focus of our General Tasks category lies with the most recent installment of the PCMark series, Vantage. While still classified under the description of a Synthetic benchmark, PCMark Vantage uses many of Vista's (Note - Vantage is Vista-only) built-in programs and features along with its own tests, so it is "real-world" applicable in regards to CPU performance. The following is a general list of the tests in the PCMark suite, very much in line with tasks of an average user: Data encryption, Data compression, CPU image manipulation (compression/decompression/resize), Audio transcoding,Video transcoding,Text editing,Web page rendering, Windows Mail, Windows Contacts, and CPU game test.
Finally, a decisive victory. In PCMark Vantage, the P7P55D Deluxe flexed its muscles and surpassed the DP55KG by a noteworthy 5%.
HDxPRT 2009
HDxPRT 2009, otherwise known as the Intel High Definition Experience and Performance Ratings Test 2009, is a new platform evaluation tool for measuring digital media experience. HDxPRT evaluates the capabilities of a media PC using real world usage scenarios and popular media applications. The benchmark's results are illustrated in the Create HD Score, which represents the overall digital media creation performance of a test system.
HDxPRT 2009 workloads are based on usages performed with popular programs, like: i. DivX encoder to create videos for YouTube, ii. MainConcept H.264 encoder to create videos for Blu-ray discs, iii. Sorenson Squeeze 5 for Flash videos, iv. Adobe Photoshop Elements 7 for Photo editing v. Apple iTunes to convert music for portable media players vi. Cyberlink PowerDVD 8 and Windows Media Player to play H.264 videos vii. On2 Flix 8 Player and Windows Media Player to play Flash videos.
In this true test of multimedia prowess, the ASUS board distinguished itself by being 2% faster than Intel's offering.
Photoshop CS4
For the image editing portion of this review, we will use Photoshop CS4 in coordination with Driver Heaven’s Photoshop Benchmark V3, which is an excellent test of CPU power and memory bandwidth. This is a scripted benchmark that individually applies 15 different filters to a 109MB JPEG, and uses Photoshop’s built-in timing feature to provide a result at each test stage. Then it’s simply a matter of adding up the 15 results to reach the final figure.
Continuing the trend, the P7P55D finishes the Photoshop benchmark a scant 1.5% quicker than the DP55KG.
Lame Front End
Lame Front End v1.0 is a single-threaded application, which means that it only utilizes a single processor core. This will obviously limit performance but it will allow us to see the benefits of Lynnfield aggressive Turbo Boost with single-threaded loads. We will be encoding a WAV rip of Santana’s Supernatural album and converting it to MP3 using the highest fidelity VBR 0 quality preset.
In LFE, the tables are turned, with this single-threaded workload offering the Intel model its first minor victory.
x264 HD Benchmark
x264 HD Benchmark v1.0
Test: MPEG-2 HD 720P Video Clip Conversion to x264
DVD Video Length: 30 Seconds
Comparison: FPS of Second Pass
x264 is quickly becoming the new codec of choice for encoding a growing number of H.264/MPEG-4 AVC videos. Think of it as the new Divx of HD and you can understand why we felt it critical to include. Tech Arp's recent development of the x264 HD Benchmark takes a 30 second HD video clip and encodes it into the x264 codec with the intention of little to no quality loss. The test is measured using the average frames per second achieved during encoding, which scales with processor speed and efficiency. The benchmark also allows the use of multi-core processors so it gives a very accurate depiction of what to expect when using encoding application on a typical full length video.
Although the difference between the two motherboards is less than 1FPS, that equates to a roughly 3.5% difference, with the ASUS being the faster model.
WinRAR
WinRAR 3.8.0
Test: Compression of 1GB of Assorted Files
Comparison: Time to Finish
One of the most popular file compression/decompresion tools, we use WinRAR to compress a 1GB batch of files and archive them, timing the task until completion.
Capping off its victorious streak, the P7P55D Deluxe shaves two seconds of the DP55KG's compression time.
With the ASUS motherboard taking the lead in 7 of the 8 benchmarks, it is indeed the faster motherboard in real-life apps, but the difference is truly minimal at best.
January 24, 2012
January 2, 2012
November 20, 2011
