| by Michael "SKYMTL" Hoenig | September 13, 2009 | ||
| Heat & Acoustics / Power Consumption Heat & AcousticsFor all temperature testing, the cards were placed on an open test bench with a single 120mm 1200RPM fan placed ~8” away from the heatsink. The ambient temperature was kept at a constant 22°C (+/- 0.5°C). If the ambient temperatures rose above 23°C at any time throughout the test, all benchmarking was stopped. For this test we use the 3DMark Batch Size test at it highest triangle count with 4xAA and 16xAF enabled and looped it for one hour to determine the peak load temperature as measured by GPU-Z. For Idle tests, we let the system idle at the Vista desktop for 15 minutes and recorded the peak temperature. ![]() While the results here may look at bit disappointing, that observation couldn’t be further from the truth. Even though the Vapor-X cooler featured slightly higher temperatures than that found on the reference HD 4890, the main difference between the two lies with the acoustical footprint they each exhibit. While the reference cooler sounds like a Dust Buster after only a few minutes of the card being under load, Sapphire’s Vapor-X unit is quiet as a mouse and will easily be drowned out by any other fan in your case. Even though the thermal efficiency numbers are impressive relative to the noise produced, there is still the concern that the vast majority of the core’s heat is just dumped back into the case rather than being exhausted out the backplate. We would have much preferred to have seen the cooler sporting closed sides in order to funnel the heat out of the case. Power ConsumptionFor this test we hooked up our power supply to a UPM power meter that will log the power consumption of the whole system twice every second. In order to stress the GPU as much as possible we once again use the Batch Render test in 3DMark06 and let it run for 30 minutes to determine the peak power consumption while letting the card sit at a stable Windows desktop for 30 minutes to determine the peak idle power consumption. We have also included several other tests as well. Please note that after extensive testing, we have found that simply plugging in a power meter to a wall outlet or UPS will NOT give you accurate power consumption numbers due to slight changes in the input voltage. Thus we use a Tripp-Lite 1800W line conditioner between the 120V outlet and the power meter. ![]() Power consumption for the Sapphire HD 4890 2GB is right in line with what we would expect considering it sports 2GB of overclocked, power-hungry GDDR5. | ||
