Intel Lynnfield Core i5-750 & Core i7-870 Processor Review
by MAC     |     September 6, 2009
Feature Test: Intel Turbo Boost - Turbocharged
2.93Ghz Core i7-870 Turbo'ing up to 3.59Ghz
For those of you who skipped the microarchitecture section, let's recap what Turbo Boost is, what it does, and how it is better than ever on Lynnfield.
Turbo Mode is an exciting feature that automatically unlocks additional speed bins (multipliers) and allows the processor to self-overclock based on thermal conditions and workload. For example, if the Power Control Unit (PCU) senses that only one core is active and the other three are in an idle state, it will use the unused power and thermal headroom to overclock that single active core to ensure superior single-threaded performance. Conversely, if you are running a multi-threaded application, the PCU will measure the thermal headroom and if the processor is running cool enough it will overclock all four cores. On the Core i7 Bloomfield chips, Turbo Mode could provide a 266Mhz speed boost in single-threaded workloads and 133Mhz in multi-threaded applications. However, for Lynnfield Intel have really kicked things up a notch. As we have all seen these last few months, Core i7 processors have a lot of overclocking headroom, which is testament to Intel's top-notch 45nm High K manufacturing process. With this in mind, Intel's engineers have put this substantial headroom to good use by giving Core i5-700 series processors 4 additional speed bins (up to 532Mhz faster) and Core i7-800 series model 5 additional speeds (up to 666Mhz faster).
Although the results will be fairly self-evident, let's check out the performance gains that Turbo Mode provides on the top-end Core i7-870 model. As per the above, thermal conditions permitting, it will run one core at 3.59GHz for single-threaded workloads, and anywhere between 3.06Ghz to 3.46Ghz in multi-threaded applications.
Intel Core i7-870
Turbo Boost Off
Intel Core i7-870
Turbo Boost On
Performance Difference
Cinebench R10 64-bit: Single Thread38534580+19%
Cinebench R10 64-bit: Multi-Thread1685618115+7%
HDxPRT203222+9%
Lame Front-End172s144s+19%
Photoshop CS4 64-bit248.1s206.1s+20%
SuperPi 32M781.592s648.211s+20%
WinRAR 3.8.0 Compression200s162s+23%
x264 HD Benchmark24.84 FPS26.33 FPS+6%
3DMark Vantage: CPU Score1800519543+8%
Valve Particle Simulation Benchmark142 Score152 Score+7%
As promised, the performance gains are there and they are substantial, ranging from 6-7% in highly multi-threaded applications to 20% in single-thread workloads. The performance gains that Turbo Boost provides are definitely nothing to scoff at, especially since they free and automatic which is ideal for less computer savvy users.
Now when you combine Turbo Boost with Hyper-Threading, you have two technologies that can work together to create some very noticeable performance improvements. Enough talking, time for some real benchmarks.
Latest Reviews in Processors
February 1, 2012
Being the newest and highest-end addition to AMD’s A-series APU lineup, not only does the A8-3870K feature the much raved about integrated Radeon HD 6550D, but it comes with fully unlocked multipliers...
November 14, 2011
Intel's X58 platform has been around for over three years now (yes, it really has been that long) and for many a changing of the guard in the enthusiast market couldn't come soon enough.  Replacing th...
October 11, 2011
After many, many years of gossip, presentations, leaks, and showcases AMD's new Bulldozer processors are finally here. This is AMD's attempt at making an architecture with significant multi-threaded p...
