Categories
Review Contents:
OCZ Summit 120GB SSD Review
by AkG     |     September 14, 2009
Interior Impressions
Before we continue: Please remember that opening any SSD will effectively void your warranty.
While we have gotten used to the layout of Indilinx’s drives, this Samsung one isn't much different. In grand total you have: 16 flash chips, one RAM chip and one Samsung controller chip.
Except for the fact that the NAND chip layout may not be exactly the same as an Indilinx, the overall appearance is still dictated by logic for both companies. At the top of the PCB you have the controller and ram chips and then rows of NAND chips. In fact, the only real difference is unlike Indilinx SSDs which have two rows of four chips on each side of the PCB, the Summit has two rows of three on the “top” side and then on the backside a small row of two more chips in between the larger double row of 4 chips each. It is interesting to see the differing layouts and the different way both companies arrive at the same conclusion (or total number of parts), but to be honest we prefer the cleaner look of the Indilinx drives as this one looks slightly more cluttered.
The I/O controller chip is of course none other than the Samsung S3C29RBB01-YK40. As expected, this is the exact same controller which graces the Corsair P series of SSDs. As noted in that previous review, the S3C29RBB01-YK40 is a 32bit ARM 9 microcontroller and is rated for speeds of 220MB/Sec read and 200MB/s writes. On paper this makes it SLIGHTLY slower in reads but slightly faster in writes than the Indilinx Barefoot controller with its 230 / 190 rating. While Samsung is not exactly open about the architecture used, it is our understanding this controller has 8 channels (compared to the 4 channel Indilinx Barefoot controller).
The RAM which graces this board is also made by Samsung. To be specific this is a single 128MB Mobile DDR SDRAM model number K4X1G323P0-8GC6. This 90-FBGA ram chip is rated to run at 1.8v CL3 and is rated for an operating temperature range of -25°C to 85°C (or what Samsung calls Extended, Low, PASR & TCSR. Or as is becoming a regular theme…it’s a more robust as well as bigger chip than is found in Indilinx SSDs.
Unlike the usual K9HCG08U1M we find in Indlinx-based drives the MLC NAND chips used in the Summit are Samsung K9HCGZ8U5M-SCK0 units. Using the online Samsung model decoder we can see these chips are 48 pin MLC Quad Die Package, 1st generation lead free & Halogen Free (ROHS compliant), 2.7V ~ 3.6V, chips which operate with Quad nCE (Quad Chip Enable control) & Quad R/nB (QuadReady/Busy Output) and customer bad block special handling. This model is rated at a density of 64Gbits or 8GB per chip and an operating temperature range of 0° to 70°C.
Above the model number we can see these were made in the 7th week of 2009 for the front 6 chips but it was 10th week 2009 for the back 10 chips. In a nut shell the only difference between these chips and the K9HCG08U1Ms is that the “Z” in the model name means they have specifically designed for SSD and do not come with the typical “Normal (x8)” designation. The other difference is the QUAD (the “5” in the model number) vs. DUAL NCE & R/nb (the “1” in their model) capabilities of the Indilinx SSD chips. When you think about it, it is not surprising that that Samsung uses enhanced (or at the very least custom model) chips for their drives as that is one of the perks of being the supplier of NAND chips to darn near ALL SSD builders!
Latest Reviews in Storage
February 25, 2010
Many people have shied away from SSDs due to their somewhat limited storage capacity and high price for the drives.  Spindle-based hard drives on the other hand have massive amounts of storage space b...
February 11, 2010
In a computing world that is seeing its storage needs rapidly expand, we have seen a quick surge in the capacities of today’s hard drives. While we all know that the recent SSD revolution has produced...
January 20, 2010
As the SSD marketplace expands at a near-breakneck pace, OEMs and manufacturers alike are moving quickly to cover as many price points as possible.  One of the most popular portions of this market doe...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/22118-ocz-summit-120gb-ssd-review.html
Posted By Date
Elite Bastards - Thursday news round up January 24, 2010 07:01 AM
OCZ Summit Benchmarks? - [H]ard|Forum November 27, 2009 03:47 AM
OCZ Summit 120GB SSD Review - Madshrimps Forum Madness October 20, 2009 07:45 AM
PC Perspective - Speaking of 6 Gigabits per second ... October 19, 2009 01:05 AM
techPowerUp! :: Review Database October 6, 2009 02:45 PM
Intel SSDSA2MH080G2C1 X25-M 80GB SATA 2.5" 9.5mm SSD Drive 34nm Gen2 Flash Technology - $234.19 Shipped - Page 6 - SlickDeals.net Forums October 4, 2009 02:41 AM
SweClockers.com - Forum: Ska jag köpa lr vänta? October 2, 2009 08:40 PM
OCZ Technology | ???? | Solid State Drives | OCZ Summit Series SATA II 2.5" SSD September 30, 2009 11:11 AM
Techgage - Tech Roundup - September 17, 2009 September 28, 2009 10:00 AM
Presently i7 setup, what can i add to make it better ? - Overclock.net - Overclocking.net September 24, 2009 01:14 PM
OCZ Technology | Products | Flash Media | OCZ Summit Series SATA II 2.5" SSD September 23, 2009 11:28 PM
Which MTRON SSD drive choose ? - Catalyst PixelMAD SAMSC Support September 23, 2009 04:52 AM
PC Perspective - News September 22, 2009 02:46 AM
OCZ Summit 120GB SSD Review @ Hardware Canucks September 22, 2009 01:52 AM
PC Perspective - The #1 Choice for PC Hardware Reviews and Information September 21, 2009 03:44 PM
September 16 News from Around the Web : News From Around The Web September 20, 2009 08:51 PM
PCSTATS.com - PC Hardware Reviews and Guides - Get The 'Stats and Stay Informed! September 18, 2009 09:10 PM
OCZ Summit 120GB SSD - PCSTATS.com September 18, 2009 03:54 PM
Accelerate Your Mac News Archive for Wednesday Sept. 16, 2009 September 17, 2009 04:00 PM
Elite Bastards - News September 17, 2009 03:59 PM
OCZ Technology | Products | Solid State Drives | OCZ Summit Series SATA II 2.5" SSD September 17, 2009 01:48 PM
Athlon ii x4 620 and 630 reviewed - The Inquirer September 17, 2009 10:13 AM
OCZ Technology | Recent Reviews | Page 1 September 17, 2009 10:12 AM
Futuremark - News - Newsarticle September 17, 2009 09:04 AM
Daily Reviews Summary 09/17/09 September 17, 2009 08:00 AM
Techgage - Home September 17, 2009 06:37 AM
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews September 17, 2009 03:44 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - OCZ Summit 120GB SSD September 17, 2009 03:40 AM
OCZ Summit 120GB SSD September 17, 2009 03:06 AM
OCTools - Reinventing the Tools of OC September 16, 2009 10:27 PM
Accelerate Your Macintosh! News Page - 9/16/09 September 16, 2009 09:29 PM
Hardware Roundup - HotHardware September 16, 2009 09:09 PM
OCZ Summit 120GB Solid State Drive Review - Futuremark / YouGamers Forums September 16, 2009 05:27 PM
OCZ Summit 120GB SSD Review September 16, 2009 04:40 PM
News around the web: New Africa broadband 'ready' - TechSpot News September 16, 2009 01:35 PM
TechConnect Magazine - Techconnect Review Round-up 16/9/09 September 16, 2009 12:56 PM
Top news stories - The Tech Report September 16, 2009 08:31 AM
techPowerUp! - The latest in hardware and gaming September 16, 2009 07:42 AM
[TweakNews] Computer Hardware and Consumer Electronics news and comprehensive reviews. September 16, 2009 07:39 AM
Blue's News - All the carnage that's fit to post! September 16, 2009 07:16 AM
NT Compatible - Daily Windows News and Information September 16, 2009 02:44 AM
Wednesday Shortbread - The Tech Report September 16, 2009 02:39 AM
OCZ Summit 120GB SSD Review September 16, 2009 01:48 AM
Overclockers Online September 15, 2009 08:16 PM
