MSI P55-GD80 Lynnfield Motherboard Preview‏
by MAC     |     August 19, 2009
A Closer Look at the MSI P55-GD80 pt.1
Enough with the paper specs, time to check out the product itself starting with a brief look at the package and accessories.
Click on image to enlarge
This packaging features the same reserved design that we have seen on previous MSI motherboards, such as the 790FX-GD70 that we have recently reviewed. As you will see below, there really is no correlation between the design of the box and the appearance of the motherboard but that has never been a prerequisite in our book. Most of the key features are mentioned on the front of the box, but a much more detailed overview can be found on the back.
As you can see, once we open the box, it is literally bursting with accessories!
The accessories bundle that MSI have given this high-end model is mighty impressive. First and foremost, there is a heck of a lot of documentation. There are six SATA cables with locking mechanisms, three SATA-to-Molex power cables, the customary IDE cable, a USB PCI bracket, an eSATA PCI bracket, eSATA cables, eSATA power cables and the back I/O shield.
As you can see in the bottom left image, MSI have thrown in a surprising number of CrossFire and SLI bridges. Why three SLI bridges when the Lynnfield/P55 chipset doesn't run tri-SLI without an NVIDIA NF200 chip (which this model doesn't have)? Does MSI know something that we do not? We'll have to wait and see.
The other interesting addition is the v-check cables, which can be used to secure your test leads to the aforementioned v-check points. Overall, this is one of the better motherboard accessories bundles that we have seen lately.
Although we would have liked to see the 8-pin CPU power connector and 24-pin ATX power connector placed right on the edge of the motherboard, all the other connectors and headers are ideally located on the edges. We definitely like the sleek black and blue theme that MSI have recently adopted on most of their motherboard which is a huge step up from the horrible red PCB that was their trademark for oh so many years. Frankly, our only criticism of this layout design is that we would have liked to see the bottom PCI-E x16 slot in another colour to highlight the fact that it is supplied by the P55 PCH and always operates at x4.
Obviously, the centerpiece of the CPU socket area is the new LGA1156 socket and the retention module design. The other eye-catching feature is DrMOS 8+2 phase power design, as evidence by the 10 sealed ferrite core chokes. There are 8 phases for the CPU and 2 phases for the VTT (aka: Uncore/L3 Cache/Integrated Controllers). The MOSFETs are cooled by reasonably low profile heatsinks and connected to each other by the 8mm Superpipe. We don't anticipate any interference problems with any popular CPU coolers. Once again, we are not too impressed with the numerous capacitors surrounding CPU socket, but that's an issue that will only affect those attempting to insulate the socket for sub-zero cooling runs.
The dual-channel DDR3 memory slots support overclocked memory frequencies up to DDR3-2133 and benefit from a 2-phase DrMOS power design. For the curious among you, those RENESAS components are the 3-in-1 DrMOS MOSFETs. The v-switch and v-check points are located right beside the memory slots and right on the edge of the motherboard for easy access.
Above the memory slots, MSI have outfitted two pairs of LEDs that reveal how many phases are in use for both VTT and the memory.
The P55-GD80 features six right-angle SATA II (3Gb/s) ports which are supplied by the P55 chipset and they support AHCI and RAID 0/1/5/10. The blue SATA ports are provided by the popular JMicron JMB322 controller and they support RAID 0/1 and JBOD. A JMicron JMB363 controller supplies the IDE port and the eSATA/USB combo port on the I/O panel.
The P55 PCH is cooled by a slim, low profile finned heatsink. As with the memory, the chipset benefits from a 2-phase Dr.MOS power design and MSI have also fitted this model with LEDs displaying how many PCH phases are in use.
January 24, 2012
January 2, 2012
November 20, 2011
