ASUS P7P55D Deluxe Lynnfield Motherboard Preview‏
by MAC     |     August 12, 2009
A Closer Look at the ASUS P7P55D Deluxe Cont'
Click on image to enlarge
Starting clockwise from the top-left, we see the VIA VT2020 10-channel High Definition Audio CODEC. This is a newer, previously unseen onboard audio solution which should prove to be a tough competitor to the dominant Realtek ALC888/889 series. It supports such niceties as DTS Surround Sensation and the ASUS Noise Filter feature. The Realtek 8110SC and 8112L are both Gigabit LAN controllers. At this point, we aren't entirely sure why ASUS chose two difference models, nor why they did not make use of the P55's native Intel Gigabit LAN support, but we assume it has something to do with the ASUS AI NET 2 feature.
In the last image we have three different chips. The well-known EPU2 chip has been enhanced with newer functions, but it continues to work to help maximize energy efficiency based on the system load. The T.Probe (at the bottom) and PEM ICs are the brand new power phase management controllers. These chips manages the VRM area in real-time to balance load across the power phases and ensure the best possible efficiency and temperatures.
As labeled, the TURBO_CON is where to plug in the TurboV remote. We would have prefered to see this connector on the I/O panel, but for now all you need to do is slide the remote's wire in between two I/O panel modules which isn't a big deal.
The entire P7P55D series features a proper 8-pin CPU power connector, but judging by the fact that our board came with a plastic cap covering four pins, you may still be able to get by with a 4-pin connector.
Starting from left to right, the rear I/O panel features a PS/2 mouse port, PS2/ keyboard port, a CMOS reset button, two USB 2.0 ports, coaxial and optical S/PDIF connectors, a Gigabit LAN port and two additional USB 2.0 ports, a FireWire port and two additional USB 2.0 ports, the second Gigabit LAN port and two additional USB 2.0 ports, and finally the six audio jacks on the audio module.
The back of the motherboard is interesting in that ASUS have installed a second set of MOSFETs there, and they have even outfitted them with their own heatsinks. This proves ASUS is listening to our collective feedback, since we previously demonstrated that those back-mounted MOSFETs can get exceedingly hot. We are glad to see that the chipset cooler is held in place with proper mounting screws, gone are the days of the problematic push-pins.
That about it for today's preview, but the launch date is quickly approaching so check back for the official review. While we can't comment on performance or overclocking at this point, but judging from what we have seen in this preview ASUS is once again looking at dominating the competition with a feature-rich yet affordable product. For all intents and purposes, the P7P55D Deluxe certainly looks impressive.
January 24, 2012
January 2, 2012
November 20, 2011
