G.Skill Trident 6GB PC3-16000 CL9 Tri Channel Memory Kit Review
by MAC     |     August 10, 2009
Package & Memory Overview
A little attention to packaging and design goes a long way towards creating a positive impression of a product, so let's see what G.Skill have done with this triple-channel DDR3 memory kit.
Click on image to enlarge
G.Skill have packaged the F3-16000CL9T-6GBTD in a standard plastic clamshell with a cardboard insert, which is the usual packaging method for most mainstream memory kits. We used to be wary to see this type of packaging because modules can occasionally become loose, but these modules were mounted snugly with no wiggle room. Thankfully, the plastic packaging can be opened / pulled apart by hand and it does not require a knife or scissors to open, which means that it is also resealable.
For the new Trident series, G.Skill have rolled out a brand new, eye-catching heatspreader design. This heatspreader is more extravagant than past G.Skill designs and they look great in our eyes, especially when matched with the similarly black & red Rampage II Extreme. We would have liked to see a colour-coordinated PCB though, since the green look is way past its prime.
These heatspreaders are made of one fairly substantial piece of aluminium and an aluminium backplate. Despite its impressive design, this is still a traditional finned heatsink design so there are no heatpipes or other convection elements. Nevertheless, when you hold these modules in your hand you can feel that these are top-notch heatspreaders by any measure.
As you can see, there are no clips or bolts holding the heatsink together. G.Skill have instead opted for a particularly adhesive type of thermal tape. It was so sticky in fact that we chickened out in our attempt to remove the heatspreaders and reveal the ICs. Having said that, based on our overclocking experiences and various forum posts, we can state with a great deal of certainty that our sample featured Elpida J1108BBSE-DJ-F ICs, which are effectively the little brother to the world-renowned Elpida Hyper J1108BASE-MNH-E.
As you can see in the last image, the heatspreader is approximately 2.25" tall and makes perfect contact with the memory chips.
Latest Reviews in RAM
January 11, 2011
As CPU memory controllers continue to become the bottleneck when it comes to overclocking memory, having modules that can keep up has become increasingly important.  G.Skill's Ripjaws modules are curr...
November 10, 2010
As memory prices have been falling, manufacturers have jumped on the "more is better" bandwagon and are releasing kits with absolutely massive capacities.  In this review we take a look at OCZ's new F...
September 1, 2010
The sub-$150 memory market is thick with products from the likes of Corsair, OCZ, G.Skill, Patriot and so many others.  Mushkin is now adding their name to the list with their new Ridgeback series.  I...
