Review Contents:
MSI 790FX-GD70 AM3 Motherboard Review
by lemonlime     |     July 26, 2009
System Benchmarks
SuperPi Mod v1.5
When running the SuperPI 32MB benchmark, we are calculating Pi to 32 million digits and timing the process. Obviously more CPU power helps in this intense calculation, but the memory sub-system also plays an important role, as does the operating system.
As we’re accustomed to seeing, SuperPI prefers raw computational power above all. Not very significant gains were realized with memory subsystem performance improvements.
PCMark Vantage X64
The latest iteration of the popular system benchmark is PCMark Vantage from the Futuremark crew. The PCMark series has always been a great way to either test specific areas of a system or to get a general over view of how your system is performing. For our results, we simply run the basic benchmark suite which involves a wide range of tests on all of the sub-systems of the computer.
In our PCMark Vantage testing, the quad “unlocked” configuration did best as these tests are multi-threaded. Small but measurable gains were seen across the various memory configurations.
Cinebench R10 64-Bit
Developed by MAXON, creators of Cinema 4D, Cinebench 10 is designed using the popular Cinema software and created to compare system performance in 3D Animation and Photo applications. There are two parts to the test; the first stresses only the primary CPU or Core, the second, makes use of up to 16 CPUs/Cores. Both are done rendering a realistic photo while utilizing various CPU-intensive features such as reflection, ambient occlusion, area lights and procedural shaders.
Wow, talk about a massive boost thanks to the two unlocked processor cores. Cinbench scales very well in multi-core scenarios. Memory performance alone didn’t seem to impact Cinebench scores much. It appears that it prefers raw computational power.
X264 HD Benchmark
Tech Arp’s recent development of the x264 HD Benchmark takes a 30 second HD video clip and encodes it into the x264 codec with the intention of little to no quality loss. The test is measured using the average frames per second achieved during encoding, which scales with processor speed and efficiency. The benchmark also allows the use of multi-core processors so it gives a very accurate depiction of what to expect when using encoding application on a typical full length video.
We see a similar pattern emerge in x264. The extra processing cores made a significant improvement in performance and memory performance boosts did little to improve the frame rates.
WinRAR 3.80
The last of our real-life tests will be with the highly popular & multi-threaded WinRAR 3.8.0 tool. WinRAR is a compression and decompression tool with a built in benchmark. We simply run the benchmark up to 500MB of processed data and record how long it takes.
WinRAR realizes some significant performance improvements with higher memory efficiency and loves the quad configuration due to its multi-threaded nature. We found it pretty surprising that there was a whopping thirty eight second delta between 7-7-7 and 6-6-6 timings.
March 14, 2010
The Republic of Gamers series from ASUS has always been known for being among the best in the industry and the Rampage motherboards are at the their forefront.  The new Rampage III Extreme will soon b...
March 11, 2010
ASUS hasn't been making much noise in the high-end AMD market as of late and has instead concentrated their new Republic of Gamers series motherboards towards Intel users.  That is all about to change...
March 3, 2010
ASUS has long been known for their Republic of Gamers series of motherboards and while they have products already in place for both of Intel's P55 and X58 platforms, they felt it was time to take thin...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/21087-msi-790fx-gd70-am3-motherboard-review.html
Posted By Date
The *Official* MSI 790FX-GD70 Owners Club - Page 520 - Overclock.net - Overclocking.net February 26, 2010 11:22 AM
[FS][US] Msi 790fx-gd70 - techPowerUp! Forums February 15, 2010 01:58 PM
FS: MSI 790FX-GD70 & E8400 - [H]ard|Forum February 14, 2010 01:22 PM
[FS][US] Msi 790fx-gd70, E8400 - techPowerUp! Forums February 14, 2010 09:25 AM
NCIX.com - Buy MSI 790FX-GD70 ATX AM3 790FX DDR3 4PCI-E16 CrossFire 1PCI-E1 2PCI eSATA SATA GBLAN Motherboard - 790FX-GD70 In Canada. February 9, 2010 07:33 PM
adl314's Bookmarks on Delicious February 5, 2010 03:34 PM
Need help to buy new mobo! January 26, 2010 11:44 PM
Phenom 2 X2 550 BE o/c & unlock - TheLab.gr January 25, 2010 03:01 AM
MSI P55-GD80 Lynnfield Motherboard Preview? -::: MITRAMSI :::- January 17, 2010 12:40 AM
fases de poder de las mobos - Foros de CHW January 13, 2010 09:08 PM
EC Firmware - MSI-Microstar - Motherboards-Memory January 13, 2010 02:56 AM
PC Perspective - News Archive November 26, 2009 08:33 PM
MSI 790FX-GD70 AM3 Motherboard Review November 18, 2009 06:31 PM
MSI Taiwan ? ???,???,?????,?????, ??,???,???,????,??? November 18, 2009 12:46 AM
MSI 790FX-GD70 lämpö ongelma November 8, 2009 02:49 AM
Unlocking Cores on MSI 790FX-GD70 - bit-tech.net Forums October 27, 2009 09:51 PM
Hardware News - SimHQ Forums October 13, 2009 10:34 AM
My First Rig (3rd Revision) - EXTREME Overclocking Forums October 10, 2009 05:46 AM
Speed Fan Remote 1 on new build 82c - Overclock.net - Overclocking.net October 7, 2009 11:20 AM
Review of MSI 790FX-GD70, Review MSI 790FX-GD70 - Mainboards - Page 2 of 3 September 24, 2009 09:13 PM
EC Firmware September 18, 2009 10:18 AM
EC Firmware September 17, 2009 06:23 PM
ADVENTURES OF PITINI September 11, 2009 04:49 AM
?? ??PC???????: MSI 790FX-GD70 AM3 Motherboard ?? September 9, 2009 06:07 AM
?? ??PC??????? September 5, 2009 06:59 AM
PCSTATS.com - PC Hardware Reviews and Guides - Get The 'Stats and Stay Informed! September 4, 2009 06:43 PM
MSI 790FX-GD70 AM3 motherboard - PCSTATS.com September 4, 2009 06:56 AM
PCSTATS.com - PC Hardware Reviews and Guides - Get The 'Stats and Stay Informed! September 4, 2009 06:50 AM
NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection. September 1, 2009 06:51 PM
Untitled document September 1, 2009 12:38 PM
CPU Heatsync for 790FX-GD70 question - Overclock.net - Overclocking.net September 1, 2009 05:03 AM
MSI Europe ? Computer, Laptop, Notebook, Desktop, Mainboard, Graphics and more August 30, 2009 06:56 AM
NCIX.com - Buy MSI 790FX-GD70 ATX AM3 790FX DDR3 4PCI-E16 CrossFire 1PCI-E1 2PCI eSATA SATA GBLAN Motherboard - 790FX-GD70 In Canada. August 26, 2009 02:28 PM
AMD Processors Forums - The review that sold you August 25, 2009 06:34 AM
News around the web: New iPhone Only Visible To Some - TechSpot News August 23, 2009 11:48 AM
MSI Asia ? Computer, Laptop, Notebook, Desktop, Mainboard, Graphics and more August 16, 2009 04:26 PM
[WTS] MSI 790FX-GD70 (AM3 DDR3) August 15, 2009 10:49 PM
Technology Geeks - The New Stuff: MSI 790FX-GD70 AM3 Motherboard Review August 12, 2009 08:27 PM
Hardware News - SimHQ Homepage August 9, 2009 07:13 AM
Custom PC Guide : Budget PC Recommendation August 7, 2009 01:26 AM
NT Compatible News - May 28, 2009 August 4, 2009 10:22 PM
The AMD Phenom II OC'ers Club - Page 216 - techPowerUp! Forums August 4, 2009 09:36 PM
MSI 790FX-GD70 AM3 Motherboard Review August 4, 2009 04:17 PM
MSI Europe ? Computer, Laptop, Notebook, Desktop, Mainboard, Graphics and more August 4, 2009 09:32 AM
MSI Global ? Computer, Laptop, Notebook, Desktop, Mainboard, Graphics and more August 4, 2009 01:16 AM
3DNN • View topic - MSI 790FX-GD70 August 3, 2009 08:36 AM
Techgage - Home August 3, 2009 05:49 AM
MSI 790FX-GD70 AM3 Motherboard Review - Hardware Reviews - All About Anything - Powered by Discuz! August 2, 2009 10:45 AM
Affiliates | Modders-Inc.com | Case Mods and Computer Hardware Reviews August 1, 2009 08:44 PM
MSI 790FX-GD70 AM3 Motherboard Review @ HardwareCanucks July 31, 2009 08:56 AM
PC Perspective - News July 30, 2009 01:07 PM
The breadbox - The Tech Report July 30, 2009 12:20 PM
PC Perspective - No, yer a dip switch! July 30, 2009 12:02 PM
Daily Reviews Summary 07/30/09 July 30, 2009 04:47 AM
News des 29. Juli 2009 | 3DCenter.org July 30, 2009 01:23 AM
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews July 30, 2009 01:22 AM
Hardware Roundup - HotHardware July 29, 2009 11:43 PM
Wednesday Evening Roundup :: TweakTown July 29, 2009 08:01 PM
PCHardwareBlips - Top PC Hardware News, Videos, and Blogs July 29, 2009 07:54 PM
Club Overclocker - The Original Overclocker's Club! July 29, 2009 03:43 PM
WinDrivers.com: Your One-Stop Source For Device Drivers, Anti-Virus Updates and Security Patches July 29, 2009 11:09 AM
[TweakNews.net] - TWEAK IT LIKE YOU MEAN IT! July 29, 2009 07:05 AM
Welcome to SimHQ.com July 28, 2009 04:05 PM
TechConnect Magazine - Techconnect Review Round-up 28/7/09 July 28, 2009 12:06 PM
MSI 790FX-GD70 AM3 Motherboard Review July 28, 2009 11:02 AM
JonnyGURU.com - Silverstone OP1000-P 1000W Review July 28, 2009 10:52 AM
Top news stories - The Tech Report July 28, 2009 09:01 AM
techPowerUp! :: Review Database July 28, 2009 08:15 AM
Tuesday Shortbread - The Tech Report July 28, 2009 07:13 AM
Blue's News - All the carnage that's fit to post! July 28, 2009 06:47 AM
Futuremark - News - Newsarticle July 28, 2009 06:43 AM
NT Compatible - Daily Windows News and Information July 28, 2009 06:33 AM
MSI 790FX-GD70 AM3 Motherboard Review July 28, 2009 05:04 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - MSI 790FX-GD70 AM3 July 28, 2009 05:02 AM
News at Overclockers Online July 28, 2009 04:04 AM
OCTools - Reinventing the Tools of OC July 28, 2009 04:03 AM
techPowerUp! - The latest in hardware and gaming July 28, 2009 01:34 AM
MSI 790FX-GD70 AM3 Motherboard Review @ Hardware Canucks July 28, 2009 12:47 AM
