Xigmatek S126384 “Thor’s Hammer” CPU Cooler Review
by AkG     |     August 3, 2009
Value
The term “Value” is such an amorphous term that it truly has different meanings for different people. For some a CPU cooler is only as good as it over-clocking potential, for others it is how quiet it does its job; for others still it’s how effective it is for its cost. We here at HWC try to provide as many answers as possible for the term “Value”. Hopefully by this point in the review people looking at OC potential or loudness levels will have a fairly good idea of what its Value is. For the “best bang for the buck” crowd we have included a chart below showing how much each 1*C less costs when compared to Intel’s FREE stock cooler. No consideration has been made for noise levels, “looks” or any other extraneous factors; this is just raw performance vs. monetary cost. For any cooler which performs worse than the Intel stock cooler a rating of “FAIL” will be given. For any cooler which has a “Value” of more than $10 per 1*C a rating of “FAIL” will be used in the graph but the chart will list its actual “value”.
All prices are based on either their MSRP (if no e-tailer prices were available at review time) or the online price they sold for at the time of their review. IF a CPU cooler does not include a fan the price of a Scythe F has been included ($12).
To make it as easy as possible for you to modify this ratio we have also included the various coolers temperature difference so if you do come across one of them on sale you can easily modify its “Value” rating. We here at HWC are in no way saying this is the definitive answer to “Value”, rather it should be considered another tool to help you make your final decision. After all something is only as “valuable” as what you consider it to be.
Q6600 Cooling Value
Please Note: This chart has be calculated based upon the differences between Intel stock cooler’s average load at its highest OC on a Q6600 @3.0GHz versus various after market coolers average load temperatures (in their stock configuration with stock TIM) also on a Q6600 @ 3.0GHz.
Ouch, that is one expensive cooler and certainly will not be considered a great value by any stretch of the imagination. On the bright side, at least it is a better value than the TRUE Black was when we reviewed it. This is not much of a silver lining and you will have a tough time convincing yourself (or most likely your “significant other”) that it is a good deal.
i7 920 Cooling Value
Please Note: This chart has be calculated based upon the differences between Intel stock cooler’s average load at its highest OC on a 920 @ 3.42GHz versus various after market coolers average load temperatures (in their stock configuration with stock TIM) also on a 920 @ 3.42GHz.
On the positive side, the i7 value for the Thor's Hammer is a little more “middle of the pack” than the Q6600 value, but this could be just due to the lack of coolers reviewed; and as time goes by it probably will slip down the ranks further and further. There is just no getting around the fact that this is an expensive cooler and it does not have a great value considering the competition it is up against.
Latest Reviews in Cooling
October 12, 2011
September 29, 2011
July 14, 2011
