| by Michael "SKYMTL" Hoenig | July 15, 2009 | ||
| Output Quality Tests Output Quality Tests+12V Ripple Wow. What more is there to say? The ripple suppression this power supply demonstrates is extremely good. The traces on our screen barely moved other than a small jump when things started getting hot and heavy in the Extreme test. You can really see where the load is coming from though as the ripple measured at the PCI-E connector is significantly more than that seen on the CPU connector. +3.3V Ripple +5V Ripple As expected, due to the relatively low load on both these rails there really isn’t much to report here. | ||
| Latest Reviews in Power Supplies | |||||||||
