| by AkG | July 16, 2009 | ||
| Crystal DiskMark Crystal DiskMarkCrystal DiskMark is designed to quickly test the performance of your hard drives. Currently, the program allows to measure sequential and random read/write speeds; and allows you to set the number of tests iterations to run. We left the number of tests at 5. When all 5 tests for a given section were run Crystal DiskMark then averages out all 5 numbers to give a result for that section. Read Performance![]() As expected, these results are awfully darn good and once again they just underline our assumption that for the most part an Indilinx Barefoot SSD is a Indilinx Barefoot SSD regardless of the label plastered on the outside of the case. Write Performance![]() Well now this is interesting. It seems that this SSD is the only Indilinx drive to break the 12MB/sec mark in the grueling 4k write test on our testbed. It still is nowhere in the same league as the X-25M but the slight variances in chips we talked about earlier does seem to give our particular drive a nice little boost in performance. We wonder what other surprises are going to pop up. | ||
