Patriot Torqx 128GB SSD Review
by AkG     |     July 16, 2009
Real World Stutters
Over a three day period we used the SSD as our main OS drive. During this period we did everything in our power to make the drive stutter. This is what we found out.
As with the all the other Indilinx based drives we have tested, as long as you occasionally run the wiper.exe program the Patriot Torqx does not stutter. As we have said in the past, you can however overload the drive but just like a regular drive your system just becomes slow but will not crash. Of course, if you pile on enough past this point it will then stutter but this is way, way past the point where even an HDD would start to complain.
Also like the other Indilinx drives, you really don’t need to do any OS tweaking to get phenomenal performance from this drive; nor worry about the dreaded stutter issue as it just isn't there. We of course recommend turning of defrag and the ilk but that is just common sense “care and handling” of any SSD more than tweaking for acceptable user experience. If you do go whole hog and either use MFT (or just diskpar to align the partition instead of replacing it) you will be rewarded with increased performance. However, after a certain point “faster” becomes less and less discernible and the time (and possible monetary investment) required to do such tweaks does quickly hit the point of diminishing returns.
Value
The term “Value” is such an amorphous term that it truly has different meanings for different people. For some a hard drive is only as good as its performance potential, for others it is how quiet or durable it is; for others still it’s how effective it is for its cost. We here at HWC try to provide as many answers as possible for the term “Value”. Hopefully by this point in the review people looking at performance potential will have a fairly good idea of what its Value is. For the “best bang for the buck” crowd we have included a chart below showing how much a give drive costs per GB . No consideration has been made for performance, “durability” or any other extraneous factors; this is just raw performance vs. monetary cost. All prices are based on the lowest price found in our Price Comparison engine at the time of their initial review.
While the Torqx may cost more in total it is not the most expensive Indilinx-based SSD based on price per GB. From a hardware point of view they are all basically the same but in the end it is you and only you who can decide if that 2.5” to 3.5” converter and the TEN YEAR WARRANTY are worth the added cost.
Latest Reviews in Storage
February 6, 2012
We've been hearing about and anticipating new Intel's Cherryville SSDs for some time now they are finally being released in the guise of the 520 series.  They are built around the same SandForce SF228...
January 23, 2012
Seagate's new Barracuda 3TB is one of the fastest hard drives currently available and it come with plenty of storage space for a reasonable price.   What it can't do is compete on a level performance ...
January 12, 2012
Corsair's Performance 3 256GB SSD showed many enthusiasts that an SSD didn’t need to have “SandForce” in the same sentence as “performance” and that the new Marvell controller was a force to be reckon...
