Gigabyte Ghost GM-M8000 Gaming Mouse Review
by AkG     |     July 6, 2009
Up Close and Personal con't
Taking these customizable features to the next level is the built in memory, which can store not only the 3 profiles but also a bunch of macros which YOU can create. You will have to install the light weight, bloat free software to change any of the settings, create said macros or even customize the built in 3 profiles (which are all set to the same default setting) but you do not have to keep said software running (or even installed) when you are finished. Everything is stored on board the mouse and where ever the mouse is…so too are your customizations. We will look into this with more detail in the software section but on a cursory glance, we are impressed.
While this is NOT a wireless mouse it has one of the best cables we have come across in this mid-teir price range in a long while. The cable is not only long at 1.8 Meters, and not only is there a low ferrous choke to reduce external noise messing up the signal but the whole length of the cable is finished in a tight and slick feeling material braid. Without a doubt, this is one elegant and yet simple solution to “cord snag”.
Overall, the Ghost is shaping up to be one easy to use mouse with a ton of features, all of which have been properly executed AND at a price which is starting to become amazingly low.
Flipping the mouse over, we can see that Gigabyte included two large ultra low friction feet; one at the front of the mouse and the back. While they are large and more than enough to get the job done we really wish they had included a third (and preferable fourth) foot for cover side to side motion to prevent the mouse from digging in when being used in a hot and heavy manner on a neoprene backed cloth mouse pad. If you use a HWC Custom Surface 1030 Archetype this is not a problem…but not everyone is advanced in their gaming setup and some actually prefer a more old school “feel”. Even on some of the more "advanced" gaming surfaces, the additional feet could prove to be beneficial.
Smack dead center on the long axis of the mouse lays the little hole which hides the eye of the 4000DPI sensor and laser. While 4000 dpi is not the highest we have seen from a laser mouse, it is right up there with some of the best in the industry. Heck, most people are not going to be gaming at 4000 dpi as it requires a level of precision and fast twitch muscles, combined with endless hours of “training” (usually a favorite FPS) that most casual gamers just don't have the time to develop.
Honestly though, it doesn't matter if you will spend most of your time at 400 dpi or 4000 dpi is beside the point. As we have said in the past: there is no such thing as overkill, so having "too much" precision is a good thing as it is better than "not enough". This setting is something that isn't available with most lower priced mice. So, whether or not you are a professional gamer is immaterial since as long as you take your play seriously nothing can be more frustrating that hitting an artificial wall created by inferior tech. This is not something you will have to worry about with the Ghost.
Moving on to the back end of the mouse, we come to the large weight area door. With a simple twist this door pops off allowing you customize the weight and thus feel of the Ghost. As we said in the accessories section, you get three 6 gram weights and one large 20 gram weight, allowing for a heck of a lot of possibilities. To our way of thinking this extra touch really was great to see and was impressive as it is usually only found on much more costly mice. After all, not everyone prefers the same weight to their mouse so why should you have to accommodate yourself to your mouse and not the other way around.
Personally, a light weight mouse with high DPI for fast FPS games is perfection, but when it comes to photo editing where precision is paramount, the slowest, heaviest mouse rules. To this end, I found one 6 gram weight in the center (with 3200DPI) was perfect for FPS (just enough weight to remove a sense of whippiness to this lightweight mouse), and all slots filled for Photoshop (at 800DPI) was the secret to long lasting happiness.
In the end, this weight customization perfectly sums up the philosophy behind the Ghost. Gigabyte really does seem to have gone out of their way to include every possible tweak you can think of and then some. Everything from on the fly DPI changing, to one-click customized mouse button settings, to quick weight lose / gains is blended seamlessly into a package that should be very comfortable for most people. If this mouse was in the $80+ range we would very pleased with it, the fact all this comes in at a price which is a lot less…..is impressive indeed.
Latest Reviews in Peripherals
January 4, 2012
Mouse pads aren't exactly items that steal much of the limelight from the premier products in this industry but they're still an integral part of anyone's gaming experience.   XFX has now released the...
December 28, 2011
Cooler Master's original Storm Sentinel gaming mouse was a popular choice among gamers but some encountered problems with its Twin Eye sensor.   A new mouse has now been released which takes the Senti...
December 11, 2011
Gaming mice are a dime a dozen these days so SteelSeries has decided to introduce a product that moves away from their traditional understated design towards something a bit more mainstream.  The new ...
