| by 3oh6 | June 9, 2009 | ||||||||||||
| First Stop: Air Cooling Canyon ![]() We have arrived at our first destination, Air Cooling Canyon. Get out, stretch your legs, and no fighting for the bathroom! Here we will explore the maximum frequencies for our benchmark suite as well as the maximum stable 24/7 overclock we can achieve with our Thermalright Ultra-120 eXtreme CU cooler. We have already seen the hardware lineup so here are a couple quick photos of the setup during this stop of our road trip. ![]() We ran the system with the fans in push/pull with another fan blowing down on the memory and helping move air across the ground level of the motherboard. This is our typical air cooling setup when testing anything. We've said it before and we'll say it again; friends don't let friends run memory without a fan. So when you are out drinking with your friends this summer, enjoying a few too many fine import beers on a patio, don't forget that piece of advice and keep those fans on high. Seriously though, do everyone a favor in that situation and just crawl home. Your knees won't love you the next day but it is the right thing to do. ![]() Overclocking the i7 975 is not unlike any other i7 processor. With an unlocked multiplier you can simply increase the CPU multi until you hit your limit, or you can play with base clock and the CPU multiplier to find that absolute maximum the processor can handle. We managed a lofty 4364MHz overclock using a rather high base clock. There is no performance gain to the high base clock, we just wanted to show that the processor had no problem running up that high. We also found that the 23X CPU multiplier really didn't mind being overclocked at all. A general rule of thumb with i7 processors has been to stick to odd CPU multipliers as they tend to require less vCORE to stabilize than even multipliers do. This continues to hold true with the new D0 stepping processors as we witnessed with this chip, and other retail 920's. ![]() You can sort of see the heat cycle of the A/C unit in the testing room. About 10 minutes into the test the A/C cycled on for a few minutes then off, and back on again close to the half way mark where the temperatures leveled right out. This is a great indication of how much ambient temperatures effect the core temperature of your processor when using air cooling.
There is a lot of data up there so let's sum it up in one sentence. The Core i7 975 EE is fast, real fast. Even with just air cooling, this chip excelled, staying cool enough to push over 4.8GHz for SPi 1M and CPU-Z validation. We put a cap on voltage of 1.500v as anything over that would be getting higher than we are even comfortable with. Keep in mind the vCORE droop this board suffers from is still in effect, especially with multi-core benchmarks. The scores put up for a single GTX 295 in Aquamark and 3DMark 05 are especially impressive for having the CPU simply on air cooling. To put things into perspective, our first Core i7 965 we bought here at Hardware Canucks is only capable of 3DMark 06 at 4.8GHz...under LN2 cooling. Running 4.5GHz kind of surprised us at this point in our road trip. We knew we would get there, just not on our first stop. Here is a chart outlining the clocks we reached through our entire suite of benchmarks. ![]() There you have it: one spot on the map checked off and we are already impressed. Unfortunately the old overclocking adage goes: if the chip is good on air, it often struggles under sub-zero conditions. This of course isn't always the case, but is something a lot of elite benchmarkers go by when estimating the abilities of a processor. We are about to find out either way so everyone back in the bus and get your mitts and toques out for the next stop on our journey, Phase Change City. | ||||||||||||
| Latest Reviews in Processors | |||||||||
