OCZ Vertex 120GB SSD Review
by AkG     |     July 5, 2009
IOMETER
IOMeter is heavily weighted towards the server end of things, and since we here at HWC are more End User centric we will be setting and judging the results of IOMeter a little bit differently than most. To test each drive we ran 5 test runs per HDD (1,4,16,64,128 que depth) each test having 8 parts, each part lasting 10 min w/ an additional 20 second ramp up. The 8 subparts were set to run 100% random, 80% read 20% write; testing 512b, 1k, 2k,4k,8k,16k,32k,64k size chunks of data. When each test is finished IOMeter spits out a report, in that reporst each of the 8 subtests are given a score in I/Os per second. We then take these 8 numbers add them together and divide by 8. This gives us an average score for that particular que depth that is heavily weighted for single user environments.
For all intents and purposes the Vertex and Falcon both post the same awe inspiring level of performance. To bad the Intel is slightly better at the middle que depths, as other wise it would have been another win for this amazing device.
IOMeter Stutter Test
In our usual IOMeter test we are trying to replicate real world use where reads severly outnumber writes. However, to get a good handle on how well a Solid State Disk Drive will handle a worse case scenario (and thus how likely the dreaded stutter issue will happen) we have also run an additional test. This test is made of 1 section at que depth of 1. In this test we ran 100% random. 100%writes of 4k size chunks of information. In the .csv file we then found the Maximum Write Response Time. This in ms is worst example of how long a given operation took to complete. We consider anything higher than 333ms (one third of a second) to be a good indicator that stuttering may happen, with the higher the number the worse the duration of the stutter will most likely be.
As we said in the past, we will take a negligible (and completely unnoticeable) increase in average completion time for an extremely low worst case scenario. We are not sure who did the leg work to find Indilinx, nor do we know what engineers helped in nurturing the Barefoot controller to life but whoever they were….THANK YOU and thank you OCZ for making this possible. A three way competition (Indilinx vs. Intel vs. Samsung) makes for much more interesting times as well as a generally better price for customers.
Latest Reviews in Storage
February 6, 2012
We've been hearing about and anticipating new Intel's Cherryville SSDs for some time now they are finally being released in the guise of the 520 series.  They are built around the same SandForce SF228...
January 23, 2012
Seagate's new Barracuda 3TB is one of the fastest hard drives currently available and it come with plenty of storage space for a reasonable price.   What it can't do is compete on a level performance ...
January 12, 2012
Corsair's Performance 3 256GB SSD showed many enthusiasts that an SSD didn’t need to have “SandForce” in the same sentence as “performance” and that the new Marvell controller was a force to be reckon...
