Review Contents:
Cooler Master Storm Scout Mid-Tower Case Review
by lemonlime     |     May 20, 2009
Interior Impressions pg.2
And the dark theme continues! Even the rear of the motherboard tray is painted in black powder-coat. Good show, Cooler Master. As you can see, quite a few cables run from the top of the case to the PSU opening at the bottom and Cooler Master has them bundled up all nice and tidy using zip-ties. There are actually about a dozen hooks that can be found at the rear of the motherboard tray for cable management.
Unfortunately, the PSU lead opening is not terribly large, and the header cables stuff it pretty well out of the box.
The inside roof of the Scout is dominated by a second non-LED 140mm fan that we’ll take a closer look at shortly. The fan is secured using self-taping fan screws from the top panel and can be swapped out for a 120mm model without modification.
All of the front I/O panel leads run just above the top-most 5.25 inch drive bay and through a small opening near the top right corner of the motherboard tray. Buyers will need to be careful when installing their motherboard as these cables do tend to creep into the ATX footprint a little.
The front, top and rear fans all connect using 4-pin molex connectors, although the top panel fan can be converted to a 3-pin by undoing Cooler Master’s zip-tie job at the rear of the case and removing the molex adapter installed on it. Due to the small amount of space between the hard drive cage and the fan, only 25mm thick replacement fans can be mounted in this location.
The front panel of the Scout is nice and easy to remove. A little bit of pulling pressure simply snaps it out of place. Although the panel is constructed entirely out of plastic, it has a nice and sturdy feel to it.
Behind the front panel, we find a stamped ‘honeycomb’ style grille for the front intake fan. It mounts using simple self-taping fan screws and mounting holes are present to swap out this oversize 140mm fan with standard 120x25mm fans if so desired.
At the rear of the front panel, individual pieces of dust-filtering foam are held into each 5.25 inch drive bay cover, and in front of the fan. The foam is a little on the thick side, and will definitely restrict airflow to some degree but will be very effective at keeping dust out of the case. Those more interested in maximum cooling performance can very easily pull it out and keep it in a drawer for future use.
The front 140mm fan bears the label “A14025-10CB-4MN-F1” and a quick Google search turned up very little information on this fan. Cooler Master does not provide any revealing information on these fans, aside from the fact that they are 140mm in diameter and 25mm thick. Not even CFM values or noise ratings are provided for some odd reason. Usually, marketing departments are eager to show off these values for comparison purposes. Although we are not 100% certain, we do believe this is a sleeve bearing model.
The fan motor receives power via a 4-pin molex connector and LED power via a 2-pin proprietary connector. The two-pin LED power connector mates to the Scout’s LED controller switch to toggle the light on and off.
The 140x25mm fan located at the top of the case is a non-LED model with a simple 3-pin fan connector. Those interested in monitoring the RPM of this fan should remove the 3-pin to 4-pin adapter that Cooler Master installs and use the native 3-pin connector.
The model number “A14025-10CB-3BN-F1” is very similar to the aforementioned LED model. They both draw 0.14 amps at 12V, so we can likely assume that these fans are almost identical in their motors, dimensions and airflow characteristics.
The rear 120mm exhaust fan turned up a little more information as this particular model is used in other Cooler Master cases. The black, non-LED variety of this fan is actually used in the Storm Sniper. It appears to be a sleeve bearing fan rated for 0.16A at 12V and 44CFM at a full rotational speed of 1200RPM. At 44CFM and only 1200RPM, this model was definitely chosen for its low-noise characteristics.
Like the other 140mm LED fan, this model also employs a 4-pin molex power connector for the motor, and a proprietary 2-pin LED power connector for the Scout’s LED switch.
Although we wish we could have provided some more detailed information about the fans used in the Scout, we’ll be giving its overall cooling configuration a run for its money in our “Cooling Performance” section.
February 15, 2010
Cooler Master has a long history of building quality cases and in this review we take a look at their limited edition HAF 932 AMD Edition enclosure.  This case offers all of the best features from the...
January 31, 2010
The mid tower case market is cluttered with products all vying for your attention but Silverstone's new Fortress FT02 dares to be different by incorporating a new "stack cool" design for component pla...
January 26, 2010
Lian Li is a case manufacturer that has been long known for their outstanding attention to detail and high end quality of everything from high-end lower-tier chassis.   In this review we take a look a...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/17960-cooler-master-storm-scout-mid-tower-case-review.html
Posted By Date
The Coolermaster Storm Scout Club - Page 25 - Overclock.net - Overclocking.net February 14, 2010 06:14 PM
Review of Cooler Master Storm Scout, Review Cooler Master Storm Scout - Cases - Page 4 of 5 December 9, 2009 01:19 AM
The Coolermaster Storm Scout Club - Page 233 - Overclock.net - Overclocking.net December 3, 2009 09:24 PM
NCIX.com - Buy Coolermaster Storm Scout Black ATX Tower Case 5X5.25 5X3.5INT 120MM & 140MM Red LED Fan No PSU - SGC-2000-KKN1-GP In Canada. November 29, 2009 06:31 PM
NCIX.com - Buy Coolermaster Storm Scout Black ATX Tower Case 5X5.25 5X3.5INT 120MM & 140MM Red LED Fan No PSU - SGC-2000-KKN1-GP In Canada. November 29, 2009 06:27 PM
NCIXUS.com - Buy Coolermaster Storm Scout Black ATX Tower Case 5X5.25 5X3.5INT 120MM & 140MM Red LED Fan No PSU - SGC-2000-KKN1-GP. November 25, 2009 03:07 PM
Cooler Master Storm Scout Mid-Tower Case Review November 13, 2009 08:22 AM
Scout / Midgard / D.Lord KC-62 / CM690 November 11, 2009 12:06 AM
The Official CM Storm Scout Club. - Page 233 - Overclock.net - Overclocking.net October 31, 2009 06:30 AM
Case Recommendations? - Page 2 - Overclock.net - Overclocking.net October 29, 2009 04:01 PM
BEST MID TOWER CASE? October 2, 2009 05:01 AM
BEST MID TOWER CASE? October 1, 2009 10:31 AM
Technology Geeks - The New Stuff: Cooler Master Storm Scout Mid-Tower Case Review September 28, 2009 08:46 PM
Extra fans for this case? September 21, 2009 08:07 PM
MysteryByte Computers - Halifax, Nova Scotia - 902.453.2983 September 12, 2009 08:30 PM
Building New Rig and Need Expert Advice September 10, 2009 01:04 AM
Cual case eligirian?? - VelocidadMaxima.com August 13, 2009 01:21 PM
Untitled document July 29, 2009 02:08 PM
Technology Geeks - The New Stuff July 21, 2009 05:21 AM
CM Storm Scout case - Icrontic Forums July 16, 2009 01:50 PM
The Official CM Storm Scout Club. - Page 25 - Overclock.net - Overclocking.net July 11, 2009 06:07 PM
iXBT Labs - Latest News July 11, 2009 01:19 PM
NCIX.com - Buy Coolermaster Storm Scout Black ATX Tower Case 5X5.25 5X3.5INT 120MM & 140MM Red LED Fan No PSU - SGC-2000-KKN1-GP In Canada. June 28, 2009 03:33 PM
Cooler Master Storm Scout mid-tower case - PCSTATS.com June 26, 2009 09:27 AM
Awards - Cooler Master June 25, 2009 08:50 PM
News Items 0-2020 June 21, 2009 02:31 PM
I7 build, need small case June 12, 2009 09:44 AM
Cooler Master Storm Scout mid-tower case June 12, 2009 04:17 AM
I7 build, need small case June 12, 2009 12:51 AM
will Coolermaster Scout fit this? - Overclockers UK Forums June 11, 2009 07:45 AM
Virtual-Hideout.Net | News Archive June 10, 2009 12:26 AM
Hardware Canucks - The Latest Computer Hardware News and Reviews June 7, 2009 08:15 AM
Elite Bastards • View topic - Thursday news round up June 5, 2009 09:46 AM
Enthusiast Hardware News and Niche Market Hardware Guide - Ninjalane.com May 30, 2009 09:12 AM
New Case - Cain's Lair Forums May 29, 2009 11:49 AM
New Case - Cain's Lair Forums May 29, 2009 04:39 AM
Virtual-Hideout - PC Hardware News & Reviews Est. 1999 May 27, 2009 06:21 PM
Virtual-Hideout - PC Hardware News & Reviews Est. 1999 May 27, 2009 02:47 AM
Scout - Cooler Master May 26, 2009 06:31 AM
[BBG Aanschaf] Mainstream en high-end gamesysteem mei 2009 - Complete Systemen & Laptops - GoT May 26, 2009 04:58 AM
Cooler Master Storm Scout Mid-Tower Case Review May 25, 2009 02:20 PM
Welcome to SimHQ.com May 23, 2009 04:08 AM
Reviews - Cooler Master May 22, 2009 09:52 PM
[TweakNews.net] - TWEAK IT LIKE YOU MEAN IT! May 22, 2009 06:41 PM
iXBT Labs - News Archive May 22, 2009 05:25 PM
Cooler Master May 22, 2009 05:10 PM
News around the web: How to fit 300 DVDs on 1 disc - TechSpot News May 22, 2009 02:54 PM
WinDrivers.com: Your One-Stop Source For Device Drivers, Anti-Virus Updates and Security Patches May 22, 2009 01:24 PM
iXBT Labs - Daily Mailbox May 22, 2009 08:06 AM
Overclocker Cafe - A Hardware Tech Site for the Rest of Us. May 22, 2009 03:50 AM
Cooler Master Storm Scout Mid-Tower Case - Big Bruin May 21, 2009 09:51 PM
Big Bruin - Tech News and Reviews May 21, 2009 07:11 PM
PC Perspective - The #1 Choice for PC Hardware Reviews and Information May 21, 2009 06:06 PM
techPowerUp! :: Review Database May 21, 2009 04:37 PM
TechConnect Magazine - Techconnect Review Round-up 21/5/09 May 21, 2009 03:48 PM
NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection. May 21, 2009 03:04 PM
techPowerUp! - The latest in hardware and gaming May 21, 2009 12:16 PM
Cooler Master Storm Scout Mid-Tower Case Review May 21, 2009 12:09 PM
May 21 News from Around the Web : News From Around The Web May 21, 2009 09:59 AM
Daily Reviews Summary 05/21/09 May 21, 2009 07:27 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - Cooler Master Storm Scout Mid-Tower May 21, 2009 07:19 AM
Blue's News: Story - Hardware Reviews May 21, 2009 07:11 AM
NT Compatible - Daily Windows News and Information May 21, 2009 07:10 AM
OCTools - Reinventing the Tools of OC May 21, 2009 06:43 AM
Top news stories - The Tech Report May 21, 2009 05:42 AM
Blue's News - All the carnage that's fit to post! May 21, 2009 05:40 AM
Overclockers Online May 21, 2009 02:48 AM
Cooler Master Storm Scout Mid-Tower Case Review May 21, 2009 02:37 AM
Thursday Morning Roundup :: TweakTown May 21, 2009 02:26 AM
Thursday Shortbread - The Tech Report May 20, 2009 11:36 PM
Cooler Master Storm Scout Mid-Tower Case Review @ Hardware Canucks May 20, 2009 11:33 PM
» Hardware Round-UP (21/05/09) May 20, 2009 10:49 PM
