| by lemonlime | May 20, 2009 | ||
| Cooling Performance Cooling Performance ![]() As you can see, the Scout bests our open bench testing, but falls short of the Sniper by about four degrees in our CPU testing. Although it doesn’t do as well in comparison to the other two cases in the chart, please keep in mind that it is a much smaller case (especially in comparison to the Spedo). ![]() The motherboard sensor in the Asus M3A78-T is located between the two PCI-Express 16x slots, so lower temperatures read by this sensor usually equate to lower GPU temperatures. Interestingly, the Scout actually does a better job keeping this motherboard area cool than the Storm Sniper. This may be the result of either the closer front intake fan - due to the case’s shorter length - or a great deal of air flow created by the HD3850 fans blowing toward the expansion slots where it cannot easily escape. As you’ll see in a moment, the later may be the case. ![]() Since our two HD 3850s are not identical, GPU1 is always a few degrees toastier than GPU2. Please note that this has more to do with the cards themselves than their relative positioning in the case. Although the motherboard sensor told us that the Scout reduced the temperature between the GPUs, the GPU cores themselves were not cooled as effectively as they were in the Storm Sniper. We believe that this is due in part to the lack of vented expansion brackets to allow hot air to escape from around the video cards, but the compact nature of the case undoubtedly plays a role in this as well. When it comes to full-load GPU testing, the Scout puts forth a decent showing considering its size. If you consider the elaborate ‘ATC’ cooling contraption in the absolutely massive Thermaltake Spedo, being only one degree behind is quite a feat. ![]() With the GPUs at idle, there is very little difference between all four configurations, and only a one degree delta was observed between the best and worst in this particular test. | ||
| Latest Reviews in Computer Cases | |||||||||
