| by 3oh6 | May 12, 2009 | ||
| Included Software Included SoftwareThe included software package from ASUS is still quite similar to that of the past. The interface is the same, and some old favorites for software are still there. In addition to the older software like AI Suite and PC Probe, ASUS has expanded the software line up to include TurboV and their latest version of EPU. Here is a quick animated image showing the various menu options of the main software interface that pops up after inserting the installation disk. ![]() As mentioned, the interface is identical to ASUS installation disks going back as far as P965 days or older. It is easy to navigate and easy to get the programs installed. As the saying goes, if it isn't broke, don't fix it. ![]() TurboV is an overclocking utility ASUS recently came out with that provides basic overclocking abilities including voltage adjustments from within Windows. We can also save profiles and load them from within Windows. The first thing to note is that changes in TubroV change the BIOS settings. This is generally a big no no with Windows overclocking software. If someone should set something too high for the system to run, you are now going to try to boot with those settings which can easily fail. Regardless of how well a system recovers from a failed overclock, you never want software in Windows to change settings in the BIOS. ![]() Next up is the overwhelmingly disappointing EPU-6 software. This go-round EPU 6 actually works, as in, it does what it sets out to do. The software "calibrated" our system fine and all of the modes would function accordingly. Unfortunately we just don't see the point of running such software. It essentially does the same thing that SpeedStep does inherently at a hardware level. At idle, the system drops the CPU multi and lowers the vCORE. The system then speeds up when load is applied. We can adjust the various modes to enable chipset voltage downgrade and other options, but these seemingly have no effect. ![]() So ASUS added new software to the fold that works to a certain degree, why leave AI Suite on the installation CD? It serves no real purpose aside from giving the user instant access to the other pieces of software. But the other pieces of software automatically run after being installed so there is no need to even open them. We found the idea of having three pieces of software that essentially do the same thing, to be rather confusing, and just useless; much like the software itself. ![]() The last piece of software ASUS includes with the CD is the only one that actually serves a purpose and does it relatively well. It is somewhat configurable and does what it is suppose to do. PC Probe II reports voltages, fans speeds, system temperatures and doesn't fail at its job. Of course we do get some random error every time we open PC Probe II but at least it opens and functions. We still prefer a less bulky system monitor like Everest Ultimate which can integrate with the Windows side bar in Vista, and with a little configuration can display everything PC Probe II does without all the screen space used up. | ||
