| by Michael "SKYMTL" Hoenig | May 7, 2009 | ||
| Overclocking Results Overclocking ResultsWhat do we consider a stable overclock? If the card can pass our test which involves a 20 minute loop of 3DMark06, 30 minutes of playing Far Cry 2 and an additional 30 minute gameplay sequence in Left 4 Dead, it is considered stable. Since overclocking can vary from one card to the next within the same family of cards, you should be aware that these results will not be considered when voicing our final opinions about these four cards. As such, we will show you the final overclocking results but leave our opinions to ourselves and let you guys form your own conclusions. Gigabyte GTS 250 1GB OC Final Overclocks Core: 805Mhz Shader: 2002Mhz Memory (DDR): 2432Mhz Sparkle Calibre GTS 250 X250 Final Overclocks Core: 813Mhz Shader: 2041Mhz Memory (DDR): 2530Mhz ASUS GTS 250 1GB Dark Knight Final Overclocks Core: 808Mhz Shader: 2004Mhz Memory (DDR): 2404Mhz EVGA GTS 250 1GB Superclocked Final Overclocks Core: 829Mhz Shader: 2032Mhz Memory (DDR): 2644Mhz | ||
