Categories
Review Contents:
GlacialTech UFO V51 CPU Cooler Review
by AkG     |     July 4, 2009
Testing Methodology
To ensure that the results from one review to another are not only reproducible but actually pertinent to this review, the Testing Methodology will be the same throughout all reviews used. If something does change we will be sure to make a special note of it and explain why this change was done and more importantly why it had to be changed or altered.
Any all CPU Cooling Solutions which do not come with their own fan, a Noctua NF-P12-1300 will be used if it accepts 120mm fans, if it only accepts 92mm a Noctua NF-B9-1600 will be used.
Except where noted all comparison testing was done on an open bench with an ambient temperature of 20c. Recorded temps were as reported via CoreTemp's "Temp Log". Average load temps were taken after 15 minutes of running Prime95 small fft and are taken directly from CoreTemps temperature text file. Excel was used to average the results of all cores. Idle temps were taken 15 minutes after Load testing ceased. Motherboard temperatures were recorded using SpeedFan. All CPU throttling technology was disabled in the BIOS; as was all CPU fan speed control. More importantly, the CM fans built in fan speed control was set to full speed.
Arctic Cooling MX-2 thermal paste was used for all coolers during these tests unless otherwise noted. Application of thermal paste was in accordance with TIM manufacturers instructions; and while not necessary, the TIM was allowed to cure for 24 hours under moderate to high loads (with periods of low loads) prior to testing.
All tests were run a minimum of 4 times and only best results are represented.
Please Note: To keep the motherboard chipsets from overheating a single 40mm Scythe Ultra Kaze was used, but was orientated in such a way as to not interfere with nor help the CPU cooler (i.e. it was basically on top of the South Bridge and pointed down). The 120mm Scythe E on the side of the open test bench was unplugged during temperature testing.
Notes about Overclocking:
For Q6600s I consider 1.45 volts to be the most that I would seriously consider for a moderate-to-long term overclock.
For i7s I consider 1.45 VCore and VTT to be the most that I would seriously consider for a moderate-to-long term overclock. As luck would have it this particular 920 would not overclock any better that 3.8 irregardless of how much voltage we pushed (we literally maxed out the Vcore and VTT/PLL available in the BIOS options and it still wouldnt be stable).
Yes you can go much higher but the longevity of the CPU is then called into question. Just as importantly the CPU should average out at LESS than 65c for the Q6600 and 75 C for the i7 as this is also what I consider the safest, maximum long term overclocking temp for each of those CPUs. For the purposes of these tests I was willing to overlook higher temperatures as long as they averaged below 65c/80c (775 and i7 respectively) and did not peak over 75/80c. If 75/80c was displayed for more than 10seconds in CoreTemp all testing was stopped and that test run was considered a fail.
With these two general guidelines I overclocked both systems until either one (or both) of these "rules" was needed to be broken to continue.
Overclocking was accomplished by increasing FSB/Bclk speed and then Vcore/VTT (only if necessary).
Before testing for idle and max temperatures Orthos was run for 1 hour to make sure that it was stable at a given overclock and voltage. If both finished with no errors SuperPi set to 32m was run twice. After the stability testing was accomplished the given system was allowed to sit idle for 30minutes before starting the official tests. IF both of the above stated guidelines were not broken then testing continued with an increased overclock. These steps were then repeated until 1 or both of the general guidelines were broken.
As they have no bearing on these tests the RAMs voltage and timings are not recorded. Please do not consider this a full how to review on overclocking or safe guidelines for overclocking nor even an indicator on how well a given CPU will overclock. IF you are interested in OCing your system, and use these guidelines we at HWC take no responsibility for the results. Bad Things can happen if you are not careful.
Complete Test System:
Processor:
Q6600
Intel i7 920
Motherboard:
Gigabyte p35 DS4
Gigabyte X58-UD3R
Memory:
4GB Mushkin DDR2-800
6GB Aneon Xtune DDR3-1600
Graphics card:
Asus 8800GT TOP
Hard Drive: 1x OCZ Apex 120GB
Power Supply: Topower Powerbird 900W
Special thanks to Direct Canada for their support and supplying the i7 920 CPU.
Special thanks to Gigabyte for their support and supplying the i7 motherboard.
Latest Reviews in Cooling
March 15, 2010
When it comes to CPU coolers, most consumers usually have to choose between a low price or good performance since there are very few products on the market that feature both. With their Traquillo, Ge...
January 28, 2010
When we last looked at Zalman's new CNPS10X family with the Extreme version, there seemed to be a lot to like but there were some shortcomings as well. Zalman has now launched the Flex Edition which ...
January 5, 2010
At the upcoming CES 2010 show, Zalman will be showing a number of their new products which include cases, coolers and even some new 3D products. In this article, we take a quick, pictorial look at som...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/17535-glacialtech-ufo-v51-cpu-cooler-review.html
Posted By Date
PCWizKid's Tech Talk - PC Hardware and Software Discussion Forum January 7, 2010 09:20 AM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking December 4, 2009 03:23 AM
[OC]ModShop - GlacialTech UFO V51 CPU Cooler Review July 24, 2009 09:30 PM
ModMag.net: Hardware Canucks: обзор кулера GlacialTech UFO V51 Silent July 15, 2009 10:45 AM
GlacialTech UFO V51 CPU cooler - FrostyTech News July 12, 2009 09:25 PM
Techgage - Tech Roundup - July 10, 2009 July 10, 2009 08:04 AM
GlacialTech UFO V51 CPU Cooler Review @ Hardware Canucks July 9, 2009 12:44 PM
News des 7./8. Juli 2009 | 3DCenter.org July 9, 2009 08:37 AM
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews July 9, 2009 05:09 AM
Futuremark - News - Newsarticle July 7, 2009 08:19 PM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking July 7, 2009 08:00 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - GlacialTech UFO V51 July 7, 2009 02:49 AM
News around the web: NASA says it snows on Mars - TechSpot News July 6, 2009 11:51 PM
GlacialTech UFO V51 CPU Cooler | CCE Reviews July 6, 2009 11:18 PM
Top news stories - The Tech Report July 6, 2009 07:13 PM
GlacialTech UFO V51 CPU Cooler Review July 6, 2009 06:31 PM
PC Perspective - The #1 Choice for PC Hardware Reviews and Information July 6, 2009 03:32 PM
NCIX FORUMS - Why so cheap? - Mushkin HP3 996629 4GB 2X2GB PC3-12800 D... July 6, 2009 01:47 PM
NCIX FORUMS - Hate Bluebird! Here's a quick fix! - LG GH22NS50 Black 22X SATA DVD Writer OE... July 6, 2009 12:00 PM
NCIX FORUMS - the US is giong bankrupt... July 6, 2009 11:55 AM
July 6 News from Around the Web : News From Around The Web July 6, 2009 07:13 AM
Overclocker Cafe - A Hardware Tech Site for the Rest of Us. July 6, 2009 05:25 AM
techPowerUp! - The latest in hardware and gaming July 6, 2009 01:39 AM
Weekend Roundup :: TweakTown July 5, 2009 10:21 PM
NCIX FORUMS - What the hell??? - BFG GeForce GTX 260 OC MAXCORE55 590MHZ ... July 5, 2009 07:51 PM
Hardware RoundUp - HotHardware July 5, 2009 05:25 PM
Sunday Shortbread - The Tech Report July 5, 2009 05:22 PM
NCIX FORUMS - Help with i7 Motherboard July 5, 2009 01:50 PM
Blue's News: Story - Hardware Reviews July 5, 2009 12:46 PM
Blue's News - All the carnage that's fit to post! July 5, 2009 10:24 AM
NT Compatible - Daily Windows News and Information July 5, 2009 08:47 AM
Hardware Round-UP (05/07/09) July 5, 2009 07:54 AM
OCTools - Reinventing the Tools of OC July 5, 2009 06:30 AM
GlacialTech UFO V51 CPU Cooler Review July 5, 2009 06:18 AM
Daily Reviews Summary 07/05/09 July 5, 2009 05:21 AM
GlacialTech UFO V51 CPU cooler July 5, 2009 04:11 AM
GlacialTech UFO V51 CPU Cooler Review July 5, 2009 04:06 AM
Overclockers Online July 5, 2009 12:02 AM
