Review Contents:
GlacialTech UFO V51 CPU Cooler Review
by AkG     |     July 4, 2009
Passive Cooling
In certain extreme cases you may have to deal with a dead fan; or alternatively you are interested in using a certain cooler as a passive cooler. While we are hesitant to recommend any Air cooler for passive cooling, unless the manufacturer has designed it to be one, we all know things break and there is a possibility of ending up with a passively cooled device even if you neither meant nor wanted it to be so! To this end we have devised the following torture test to see how a given cooler will perform in a worst case scenario.
The following test will be PASS/FAIL unless a manufacture specifically states a CPU cooling solution is designed for passive cooling as we feel that do to otherwise would be very disingenuous and down right unfair. If it is designed for passive use we will of course provide hard data on its performance. We believe this is a fair and reasonable compromise between providing you our reader the most information possible, while still being fair and unbiased to the manufacturers.
Any one can create a test which has no possibility of success but that would be a waste of any ones time; this test on the other hand is as tough as we can make it and still have to possibility of success. What makes this test so difficult, is the simple reason that we will be testing in an open bench which has absolutely no external air flow. Even in the most under-cooled cases there is always some air movement, even if the air movement is only coming from the PSU it is still a heck of a lot more than will be afforded a cooler on our open bench. As we stated earlier this is a worst case, scenario where the cooler will have to shed all the heat it can by simple passive radiation!
The first and main part of the test is 15 minutes of prime95 small fft being run at stock speed (2.66GHz) on our Quad Core Intel i7 920. If at anytime the temperature of any of the four cores reaches and stays at 75° C for greater than 10 seconds we will consider this test a FAIL. If a given cooler fails this test a second set of tests will be run using out Q6600 at stock speed (2.4GHz). We will then report our findings in the below chart.
Please note: Any Air based CPU cooler which passes the i7 920 test will automatically be given a PASS grade on the cooler running secondary test. To keep things easier to understand the only time we will publish the Q6600 subtest is when a given cooler has failed the main test.
With “active cooling” numbers as bad as the UFO posts is it really any surprise that it fails at passive cooling? All we can say is if you actually plan on using this and its two fans somehow do fail (which is thankfully very unlikely) at least you can rest assured that modern day CPUs will self throttle when dangerous temperatures are reached.
Latest Reviews in Cooling
March 15, 2010
When it comes to CPU coolers, most consumers usually have to choose between a low price or good performance since there are very few products on the market that feature both.  With their Traquillo, Ge...
January 28, 2010
When we last looked at Zalman's new CNPS10X family with the Extreme version, there seemed to be a lot to like but there were some shortcomings as well.  Zalman has now launched the Flex Edition which ...
January 5, 2010
At the upcoming CES 2010 show, Zalman will be showing a number of their new products which include cases, coolers and even some new 3D products. In this article, we take a quick, pictorial look at som...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/17535-glacialtech-ufo-v51-cpu-cooler-review.html
Posted By Date
PCWizKid's Tech Talk - PC Hardware and Software Discussion Forum January 7, 2010 09:20 AM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking December 4, 2009 03:23 AM
[OC]ModShop - GlacialTech UFO V51 CPU Cooler Review July 24, 2009 09:30 PM
ModMag.net: Hardware Canucks: обзор кулера GlacialTech UFO V51 Silent July 15, 2009 10:45 AM
GlacialTech UFO V51 CPU cooler - FrostyTech News July 12, 2009 09:25 PM
Techgage - Tech Roundup - July 10, 2009 July 10, 2009 08:04 AM
GlacialTech UFO V51 CPU Cooler Review @ Hardware Canucks July 9, 2009 12:44 PM
News des 7./8. Juli 2009 | 3DCenter.org July 9, 2009 08:37 AM
3DCenter.org | 3D-Grafikkarten-Benchmarking, Downloads, News & Reviews July 9, 2009 05:09 AM
Futuremark - News - Newsarticle July 7, 2009 08:19 PM
MADSHRIMPS - Hardware Reviews ,Crazy Projects, Modding Tutorials and Overclocking July 7, 2009 08:00 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - GlacialTech UFO V51 July 7, 2009 02:49 AM
News around the web: NASA says it snows on Mars - TechSpot News July 6, 2009 11:51 PM
GlacialTech UFO V51 CPU Cooler | CCE Reviews July 6, 2009 11:18 PM
Top news stories - The Tech Report July 6, 2009 07:13 PM
GlacialTech UFO V51 CPU Cooler Review July 6, 2009 06:31 PM
PC Perspective - The #1 Choice for PC Hardware Reviews and Information July 6, 2009 03:32 PM
NCIX FORUMS - Why so cheap? - Mushkin HP3 996629 4GB 2X2GB PC3-12800 D... July 6, 2009 01:47 PM
NCIX FORUMS - Hate Bluebird! Here's a quick fix! - LG GH22NS50 Black 22X SATA DVD Writer OE... July 6, 2009 12:00 PM
NCIX FORUMS - the US is giong bankrupt... July 6, 2009 11:55 AM
July 6 News from Around the Web : News From Around The Web July 6, 2009 07:13 AM
Overclocker Cafe - A Hardware Tech Site for the Rest of Us. July 6, 2009 05:25 AM
techPowerUp! - The latest in hardware and gaming July 6, 2009 01:39 AM
Weekend Roundup :: TweakTown July 5, 2009 10:21 PM
NCIX FORUMS - What the hell??? - BFG GeForce GTX 260 OC MAXCORE55 590MHZ ... July 5, 2009 07:51 PM
Hardware RoundUp - HotHardware July 5, 2009 05:25 PM
Sunday Shortbread - The Tech Report July 5, 2009 05:22 PM
NCIX FORUMS - Help with i7 Motherboard July 5, 2009 01:50 PM
Blue's News: Story - Hardware Reviews July 5, 2009 12:46 PM
Blue's News - All the carnage that's fit to post! July 5, 2009 10:24 AM
NT Compatible - Daily Windows News and Information July 5, 2009 08:47 AM
» Hardware Round-UP (05/07/09) July 5, 2009 07:54 AM
OCTools - Reinventing the Tools of OC July 5, 2009 06:30 AM
GlacialTech UFO V51 CPU Cooler Review July 5, 2009 06:18 AM
Daily Reviews Summary 07/05/09 July 5, 2009 05:21 AM
GlacialTech UFO V51 CPU cooler July 5, 2009 04:11 AM
GlacialTech UFO V51 CPU Cooler Review July 5, 2009 04:06 AM
Overclockers Online July 5, 2009 12:02 AM
