Cooler Master Hyper N520 CPU Cooler Review
by AkG     |     June 8, 2009
Passive Cooling
In certain extreme cases you may have to deal with a dead fan; or alternatively you are interested in using a certain cooler as a passive cooler. While we are hesitant to recommend any Air cooler for passive cooling, unless the manufacturer has designed it to be one, we all know things break and there is a possibility of ending up with a passively cooled device even if you neither meant nor wanted it to be so! To this end we have devised the following torture test to see how a given cooler will perform in a worst case scenario.
The following test will be PASS/FAIL unless a manufacture specifically states a CPU cooling solution is designed for passive cooling as we feel that do to otherwise would be very disingenuous and down right unfair. If it is designed for passive use we will of course provide hard data on its performance. We believe this is a fair and reasonable compromise between providing you our reader the most information possible, while still being fair and unbiased to the manufacturers.
Any one can create a test which has no possibility of success but that would be a waste of any ones time; this test on the other hand is as tough as we can make it and still have to possibility of success. What makes this test so difficult, is the simple reason that we will be testing in an open bench which has absolutely no external air flow. Even in the most under-cooled cases there is always some air movement, even if the air movement is only coming from the PSU it is still a heck of a lot more than will be afforded a cooler on our open bench. As we stated earlier this is a worst case, scenario where the cooler will have to shed all the heat it can by simple passive radiation!
The first and main part of the test is 15 minutes of prime95 small fft being run at stock speed (2.66GHz) on our Quad Core Intel i7 920. If at anytime the temperature of any of the four cores reaches and stays at 75° C for greater than 10 seconds we will consider this test a FAIL. If a given cooler fails this test a second set of tests will be run using out Q6600 at stock speed (2.4GHz). We will then report our findings in the below chart.
Please note: Any Air based CPU cooler which passes the i7 920 test will automatically be given a PASS grade on the cooler running secondary test. To keep things easier to understand the only time we will publish the Q6600 subtest is when a given cooler has failed the main test.
While it was a close call, that copper base can suck up a boat load of heat before being overwhelmed, but it did fail the i7 passive test. On the bright side it passed the Quad test and where this cooler comes with two fans its highly doubtful anyone will suffer a double catastrophic fan failure. If you do lose one, your temps will go up and give you plenty of warning; yet they will never reach the point of being a risk to your expensive CPU.
Latest Reviews in Cooling
October 12, 2011
September 29, 2011
July 14, 2011
