| by Michael "SKYMTL" Hoenig | April 27, 2009 | ||
| Enhancing the Visual Experience Enhancing the Visual Experience ATI’s cards have been the staple of people building HTPCs for some time now with features like UVD, HDMI and high-end audio options. With the HD4000-series, AMD are taking things to the next level with some very interesting advances on their already-established technologies which will make these cards even more appealing to HTPC aficionados and regular consumers alike. To do this they have set before themselves three primary goals: to provide multi-stream HD playback as supported in Blu-Ray 2.0 profiled movies, to improve the visual quality on HD monitors and to accomplish fast video transcoding by taking advantage of the processing power of the R700-series cores. Considering we have seen in the past how well features like UVD work, any enhancements to already-existing features is more than welcome in today’s quickly changing world of high definition. While we will be going over some of the features ATI has implemented it is just the tip of the iceberg of what is being offered to those of us who use our graphics cards to process HD signals. UVD 2 – Dual Bitstream Playback With Blu-Ray finally winning the high definition format wars, manufacturers have taken lightning-quick steps to step up support for the format. One of the many ways AMD is doing this is through full support of the Blu-Ray 1.1 profile and BD Live (profile 2.0). With UVD 2 the R700-series processors are able to decode two streams of high definition (H.264, VC-1 and MPEG-2) content in order to give the viewer the picture-in-picture options present in the 1.1 profile. This gives us the capability to watch a movie in large format while having something like an alternate scene or director’s commentary playing in the smaller picture in the corner of the screen. High Definition Audio & Video through HDMI & Displayport ![]() HDMI is quickly becoming the standard of choice for high definition movie and audio aficionados. With the HD3800 series AMD supported 5.1 channel audio-out through the HDMI connector but with the HD4800-series, they have taken things one step further by offering full 7.1 channel output. This means the these new cards will have support for AC3, DTS, Dolby True-HD and DTS HD formats with a full 6.144 Mbps bit rate and 192KHz sample rate along with up to 24 bits/sample. Add to this native HDCP support and true 1080P output and what we have here is a true multimedia powerhouse. Did we mention that the R700-series core has native support for Display Port as well? Well, it does but it is up to the board partner’s discretion whether or not they add the necessary output connector. Enhanced DVD Upscaling & Dynamic Contrast While there are plenty of us who will use HD signals through the HD4000-series of cards, whether we like it or not we will still be outputting lower definition signals to our wonderful new HDTV every now and then. In these cases, a standard 480i picture will look absolutely horrible if it is scaled up to fit on a high definition 1080P TV so ATI provides the Avivo HD upscaling option in their drivers. What this does is take the low resolution signal and clean it up so to speak so it looks better when displayed on a high definition screen. Another interesting feature ATI has packed into their drivers is the Dynamic Contrast Adjustment. Personally, I more often than not adjust the contrast manually based on the application since the values from one game or movie to the next can vary a lot. ATI has taken the guesswork and thrown it out the window by providing a post-processing algorithm which will automatically (and smoothly) adjust the contrast ratio in real time. AVIVO HD: The Real DealEven though we have reviewed quite a few ATI graphics cards which support AVIVO HD technology, we have never really touched upon its benefits. Since this card can caters to the HTPC crowd as much as it does towards the casual gamer crowd, we figured now would be as good a time as any to touch upon the benefits. First of all, AVIVO HD (and its accompanying UVD 2) offers hardware decoding of high definition video streams which will minimize load on your CPU and thus provide smoother playback. Some Nvidia cards like the 9500GT offer full H.264 decoding and AACS decryption but offloads decoding of VC-1 video streams to the CPU. Meanwhile, all of the cards in ATI’s lineup from the lowest HD 4500-series all the way up to the HD 4800-series support full VC-1 and H.264 hardware decoding. Just remember, you need software which supports hardware decoding such as Cyberlink’s PowerDVD. Let’s take a look at what is offered in the Catalyst Control Center when it comes to AVIVO options When you first enter the AVIVO portion of the CCC, you have a quick-select box which will give you various preset video settings so you won’t have to fiddle around with too many settings to get your desired color levels. However, for those of you with a finer taste for the perfect picture, ATI has more for you. In the Basic Color section you have all of the, brightness, contrast, tint and saturation controls at your fingertips. There is also a Use Application Settings which will cause any game or software-specific color profiles to override the settings you choose in this section. ATI also includes and area with finer color adjustments for skin tone and color vibrancy. Normally, we don’t dare touch these settings but since some movies tend to have different color parameters than others, they come in handy every now and then. In the Basic Quality section, you are able to control the deinterlacing mode used in videos. While we normally recommend you keep this at its default value, when watching movies on a high resolution screen, I personally set it to Vector Adaptive and Pulldown Dection. The two final options you have here are Theatre Mode and All Settings. In Theatre Mode, you are able to scale the video output across multiple displays while the All Settings holds….well...all the settings from the previous sections without their accompanying thumbnail preview. | ||
