ATI Radeon HD 4770 512MB GDDR5 Review
by Michael "SKYMTL" Hoenig     |     April 27, 2009
Heat & Acoustics
For the heat test, all cards are set up on an open test bench in a room with a controlled ambient temperature of 22°C.
* HD4850 1GB is a custom cooled card from Gigabyte
The temperatures seen with this new 40nm core look very good upon first glance. Indeed, for a card that performs like the HD 4770, these temperatures are downright amazing and almost put it in line with the non-reference Gigabyte HD 4850 1GB. The one little stumbling block is that the idle results are very similar to those we recorded on a HD 4830. Remember, the HD 4830 has a very compact single slot cooler and its core uses the (supposedly) less efficient 55nm manufacturing process. Meanwhile, the HD 4770 uses a large dual slot cooler sporting an aluminum fin assembly many other cards would be jealous of but maintains an idle temperature that is only 1°C better than the HD 4830. This could be due to any number of scenarios from heatsink base quality to mounting pressure to the fact that our HD 4830 is one of the cooler-running samples but we still needed to bring this up.
All the way at the beginning of this review we stated that in many cases a 2-pin fan header raises red flags when it comes to noise. However, the HD 4770 bucks this trend by being near-silent most of the time with its fan spinning at a mere 30% of its rated output. We say most of the time because every now and then the fan will increase its speed significantly for about two to three seconds which was distracting. However, the fan speed was completely adjustable through the Catalyst Control Center.
Power Consumption
For this test we hooked up our power supply to a UPM power meter that will log the power consumption of the whole system twice every second. In order to stress the GPU as much as possible we once again use the Batch Render test in 3DMark06 and let it run for 30 minutes to determine the peak power consumption while letting the card sit at a stable Windows desktop for 30 minutes to determine the peak idle power consumption. We have also included several other tests as well. Please note that after extensive testing, we have found that simply plugging in a power meter to a wall outlet or UPS will NOT give you accurate power consumption numbers due to slight changes in the input voltage. Thus we use a Tripp-Lite 1800W line conditioner between the 120V outlet and the power meter.
* HD4850 1GB is a custom card from Gigabyte
At load, the HD 4770 proves itself to be very efficient even when compared to some lower performing cards which proves that ATI is striding to have the best of both worlds: gaming power and efficiency.
While ATI can celebrate all they want when it comes to overall full load efficiency, idle power consumption is still something that needs to be worked on. There has been some talk floating around regarding the power consumption of GDDR5 memory and we wouldn’t doubt this is one of the contributing factors here. Nonetheless, the HD 4770 remains one of the most efficient products we have tested and a few watts more or less when idling isn’t going to completely blow your electricity bill.
Latest Reviews in Video Cards
February 8, 2012
February 6, 2012
January 30, 2012
