Specifications
Now that he have taken a closer look at the memory and its packaging,let's examine the specifications.
As mentioned previously, the OCZ OCZ3P1600LV6GK is a 6GB PC3-12800/DDR3-1600 memory kit rated for 7-7-7-24 timings at 1.65 volts. This new low memory voltage requirement is a direct result of the integrated memory controller (IMC) that is a key feature of the new
Intel Core i7 processors. Although the technical and performance benefits of an IMC are undeniable, the end-result is nevertheless a processor design that is more susceptible to failure when high vDIMM is utilized without proper precautions. Although we do not adhere to our own wisdom, we highly recommend that users abide by the recommended 1.65V memory voltage limit just to avoid accidental damage to these pricey new quad-core processors.
The memory kit that we are reviewing is the 6GB (3 x 2GB) version of this product, but as we can see on the lower-right OCZ do offer a 3GB (3 x 1GB) kit with identical specifications, part #
OCZ3P1600LV3GK. It retails for as low $111CDN, but frankly you would crazy not to spend the extra $40-50 to get the 6GB kit.
Those planning on making the leap to Core i7 will need to purchase a new Intel X58 Express-based motherboard, and this particular model has undoubtedly been compatibility tested with some of the best and most popular models on the market. We can personally attest that this memory kit works flawlessly on the ASUS Rampage II Extreme, Gigabyte EX58-UD5, and Intel DX58SO 'SmackOver', and we have no reason to believe that it would have any compatibility issues with the
EVGA X58 SLI or Foxconn BloodRage.
As you can see this memory kit does not have any Extreme Memory Profiles (XMP) profiles, which is slightly disappointing for novice users, but enthusiasts obviously won't even notice their omission. Should you have any functionality or stability problems with your modules, OCZ's memory kits are backed by a lifetime warranty and the company has superlative customer service and technical support, both online and via the more traditional methods.
