| by 3oh6 | March 12, 2009 | ||||||||||||||||||||||||||||||||||
| Test Setup & Methodologies Test Setup & Methodologies
We have listed two Corsair Dominator kits of memory, one being the from the Dominator-GT series and the other being the highly popular Dominator 3x2GB PC3-12800 CL8 kit from Corsair. We will be using for the Dominator-GT kit for all of our overclocking and benchmarking but will also be testing to make sure the PC3-12800 Dominator kit run smoothly at stock on this motherboard. Both kits will in fact be tested for stability at their XMP profiles to ensure 100% compatibility with the DFI X58-T3eH8. This has been an increasingly popular type of testing we have found during the X58/triple-channel memory era and one we will continue with for the foreseeable future. Let's now go over out stability testing methodology. Stability Overclocking MethodologyTesting for true system stability is an arduous task and one that can be hotly debated in an open forum. We have many years of experience watching these debates and have tried to put together a strong collection of stability tests to accommodate all schools of thought on the subject. Our stability testing methodology has also been a great success in finding a number of 24/7 overclocks on all kinds of systems. A lot of us here at HWC, myself included, use this same type of testing when setting up our own daily use machines and those that we setup for friends and family. This methodology is sound and shouldn't be taken lightly. We are definitely not like other sites that post a CPU-Z screen shot and then say the system passed all of our benchmarks. Our results should be considered a realistic sample of what one can expect from this motherboard for 24/7 operation. ![]() Obviously we won't be able to test everything for a literal 24/7 overclock because of time restraints with a review, but our virtual recipe equates nicely to a 24/7 stable overclock. The following is a run-down of programs used for our stability testing. All overclocked results in the next section have passed this testing, with screen shots to outline settings used:
We truly feel this testing methodology produces solid and useful results for end users. Of course you do have to keep in mind that all setups will react differently. Our CPU may need more or less vCORE/VTT in order to run the overclocks we will be looking at shortly. The memory we used may be stronger or weaker than kits in your machines. There are a number of variables when it comes to overclocking and there are no stead fast rules, only guidelines. We have provided all of the voltages used for our overclocks but those should only be used as a guide or starting point for your systems. You may need more - or less - voltage to achieve the same type of clocks. Benchmark MethodologyWe are yet again stuck with our wheels spinning in the mud when it comes to working XMP profiles with the DFI X58-T3eH8. Like the EVGA X58-SLI - which just received a BIOS with working XMP - at the time of this review, the DFI X58 does not support XMP profiles.
