Intel X-25M 80GB SSD Review
by AkG     |     March 2, 2009
Testing Methodology
Testing a hard drive or SSD for that matter is not as simple as putting together a bunch of files, dragging them onto folder on the drive in Windows and using a stopwatch to time how long the transfer takes. Rather, there are factors such as read / write speed and data burst speed to take into account. There is also the SATA controller on your motherboard and how well it works with SSDs to think about as well. For best results you really need a dedicated hardware RAID controller w/ dedicated RAM for SSDs to shine. Unfortunately, most people do not have the time, inclination or monetary funds to do this. For this reason our testbed will be a more standard motherboard with no mods or high end gear added to it. This is to help replicate what you the end user’s experience will be like.
Even when the hardware issues are taken care of the software itself will have a negative or positive impact on the results. As with the hardware end of things, to obtain the absolute best results you do need to tweak your OS setup; however, just like with the hardware solution most people are not going to do this. For this reason our standard OS setup is used. However, except for the XP load test times we have done our best to eliminate this issue by having the drive tested as a secondary drive. With the main drive being a WD 320 single platter drive.
For these tests we used a combination of the ATTO Disk Benchmark, HDTach, HDTune, Cystal Disk Benchmark, h2benchw, SIS Sandra Removable Storage benchmark, PCMark 05 Hard drive tests and IOMeter for synthetic benchmarks.
For real world benchmarks we timed how long XP and Adobe CS3 (w/ enormous amounts of custom brushes installed) startup took, how long a single 4GB rar file took to copy to and then from the hard drives, then copy to itself. We also used 1gb of small files (from 1kb to 20MB) with a total 2108 files in 49 subfolders.
For the temperature testing, readings are taken directly from the hottest part of the drive case using a Digital Infrared Thermometer. The infrared thermometer used has a 9 to 1 ratio, meaning that at 9cm it takes it reading from a 1 square cm. To obtain the numbers used in this review the thermometer was held approximately 3cm away from the drive and only the hottest number obtained was used.
Please note to reduce variables the same XP OS image was used for all the hard drives.
For all testing a Gigabyte PA35-DS4 motherboard was used. The ICH9 controller on said motherboard was used.
All tests were run 4 times and average results are represented.
You will also notice that in a number of benhcmarks the G.Skill SSD is lacking results of is not represented at all. This is due to the fact that we no longer have the drive in our posession and as such could not rerun the tests after we changed our benchmark suite.
Processor: Q6600 @ 2.4 GHZ
Motherboard: Gigabyte p35 DS4
Memory: 4GB G.Skill PC2-6400
Graphics card: Asus 8800GT TOP
Hard Drive: 1x WD 320
Power Supply: Seasonic S12 600W Performance Testing
Latest Reviews in Storage
February 6, 2012
We've been hearing about and anticipating new Intel's Cherryville SSDs for some time now they are finally being released in the guise of the 520 series.  They are built around the same SandForce SF228...
January 23, 2012
Seagate's new Barracuda 3TB is one of the fastest hard drives currently available and it come with plenty of storage space for a reasonable price.   What it can't do is compete on a level performance ...
January 12, 2012
Corsair's Performance 3 256GB SSD showed many enthusiasts that an SSD didn’t need to have “SandForce” in the same sentence as “performance” and that the new Marvell controller was a force to be reckon...
