Review Contents:
OCZ Apex 120GB SSD Review
by AkG     |     March 23, 2009
Internal Impressions
Please remember that opening you SSD will void your warranty.
Just as with every other SSD we have worked with, opening the Apex up to look inside is as easy as removing four corner screws.
As we have said in the past if you plan on doing this, please make sure you are grounded. Taking the top off may not ruin your SSD like it will a regular drive (unless you are in a clean room, in which case your spindle drive may just survive) but a errant static charge can and will fry your precious data into paper weight uselessness. Trust us, you don’t want to hear that zapping sound.
The board layout is exactly the same as the one found on the G.Skill Titan. At one end you have your SATA power and data connectors, with the small raid controller followed closely by the dual I/O controller chips and then two rows of four NAND MLC flash chips. The other side of this PCB has another 8 chips soldered to it (also in two rows of 4); making it for a grand total 16 NAND flash chips
Also like the Titan, the I/O controller chips are JMicron model 602s. As we have said in the past it really is amazing that these companies figured out a way to cram two full working SSDs into such a small 2.5” form factor package. We really would have liked to have seen something else besides an updated and improved JMicron 602 used in the Apex, but the Titan did show that this is a decent and fairly potent combination.
Also like the Titan the RAID controller chip (shown above) is the JMB390 controller chip by JMicron. This controller is a one-lane PCI Express to one-port Serial ATA II Host Controller which supports SATA II Gen2i and Gen2m, as well as Native Command Queuing (NCQ) and Hot Plugging. All in all it is small, low power RAID controller which is a very good fit for devices such as SSDs.
As you can see the NAND chips used in the Apex are same ones as used in the Patriot Warp v2. To be precise they are Samsung K9HCG08U5M-PCB0 which are 48 pin MLC Quad Die Package, 1st gen lead free (ROHS compliant), 2.7V ~ 3.6V, 25 nanosecond NAND chips which have Dual nCE (Dual Chipe Enable control) & Dual R/nB (Dual Ready/Busy Output). This model is rated at a density of 64Gbits or 8GB per chip. Above the model number we can see these were made in the 1st week of 2009 and below it we can see the batch number YCK8D6Q1 (or at least what we assume is the batch number but is described by vaguely Samsung as “Customer List Reference” only).
When looking at these chips we are sure the biggest question on your mind is: “Why is the total capacity rated for only 120GB and not its true 128GB?” We assume the difference is for enhanced endurance as even when this drive is “full” it will still have 8GB of space for the wear level algorithms to work with. To us, losing 8GB for the chance of increased durability and possibly peed is a good trade off.
All in all, OCZ has gone for a completely reference design for the APEX. If you were to place the G. Skill Titan’s PCB along side the OCZ Apex’s PCB you would be hard pressed to tell them apart. The only distinctive characteristic of the OCZ is the QA sticker on the back of the PCB. Of course, you could also tell them apart by the size of the NAND chips used, but we are positive if we had access to a "250GB" OCZ Apex that it would be identical. It is interesting that OCZ only rates their Apex drives for 120 and 250GB when they are obviously 128GB and 256GB. We are also puzzled how OCZ can claim a faster speed for their Apex drives vs. the G.Skill Titan line when they are for all intents the same. For now we are going to give OCZ the benefit of the doubt and assume the difference has to do with custom firmware which squeezes more power from the components. This does make sense as OCZ has shown to have a lot of experience with SSDs and their capabilities.
Latest Reviews in Storage
February 25, 2010
Many people have shied away from SSDs due to their somewhat limited storage capacity and high price for the drives.  Spindle-based hard drives on the other hand have massive amounts of storage space b...
February 11, 2010
In a computing world that is seeing its storage needs rapidly expand, we have seen a quick surge in the capacities of today’s hard drives. While we all know that the recent SSD revolution has produced...
January 20, 2010
As the SSD marketplace expands at a near-breakneck pace, OEMs and manufacturers alike are moving quickly to cover as many price points as possible.  One of the most popular portions of this market doe...
LinkBacks (?)
LinkBack to this Thread: http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/15234-ocz-apex-120gb-ssd-review.html
Posted By Date
iXBT Labs - News Archive September 27, 2009 01:28 PM
[Comp] Warmish FutureSlop OCZ Apex 120gb SATA II 2.5" SSD 369 (+ free shipping) save $130 - RedFlagDeals.com Forums July 28, 2009 02:21 PM
Hardware Roundup - HotHardware July 23, 2009 01:27 PM
RedFlagDeals.com Forums - Hot Deals July 23, 2009 11:07 AM
[Comp] Warmish FutureSlop OCZ Apex SATA II 2.5" SSD 369 (+ free shipping) save $130 - RedFlagDeals.com Forums July 23, 2009 10:46 AM
OCZ Technology | Products | Solid State Drives | OCZ Apex Series SATA II 2.5" SSD July 8, 2009 04:22 PM
» Hardware Round-UP (24/03/09) June 4, 2009 08:52 AM
Review of OCZ SSD Apex Series 2.5 inch 120GB SATA300 OCZSSD2-1APX120G, Review OCZ SSD Apex Series 2.5 inch 120GB SATA300 OCZSSD2-1APX120G - SSD - Page 1 of 2 May 16, 2009 05:16 AM
OCZ Apex 120GB SSD Review May 14, 2009 09:09 PM
techPowerUp! - The latest in hardware and gaming May 13, 2009 05:03 AM
techPowerUp! :: Review Database May 10, 2009 03:08 AM
PCSTATS.com - PC Hardware Reviews and Guides - Get The 'Stats and Stay Informed! April 14, 2009 12:24 AM
OCZ Apex 120GB SSD - PCSTATS - PCSTATS Forum April 13, 2009 11:19 AM
OCZ Apex 120GB SSD - PCSTATS.com April 13, 2009 09:32 AM
OCZ Apex 120GB SSD Review April 10, 2009 03:35 PM
OCZ Apex 120GB SSD Review April 9, 2009 08:39 AM
OCZ Apex 120GB SSD Review @ Hardware Canucks April 9, 2009 07:36 AM
iXBT Labs - Daily Mailbox April 8, 2009 01:11 AM
OCZ Apex 120GB SSD Review : hardware April 6, 2009 11:12 AM
Virtual-Hideout - PC Hardware News & Reviews Est. 1999 April 5, 2009 06:24 PM
OCZ Apex 120GB SSD Review - Madshrimps Forum Madness April 5, 2009 08:44 AM
XSReviews.co.uk - Trusted Hardware Reviews - News | Review - OCZ Apex 120GB SSD April 5, 2009 05:39 AM
OCZ Technology | Products | Flash Media | OCZ Apex Series SATA II 2.5 April 4, 2009 06:35 PM
JonnyGURU.com - Power Supply Reviews and more! - News - OCZ Apex 120GB SSD Review April 4, 2009 07:28 AM
Review: OCZ Apex Series 120GB SSD April 4, 2009 03:32 AM
newest submissions : hardware April 3, 2009 11:23 PM
hardware April 3, 2009 01:56 PM
Darkhorse SSD brand kicks it up a notch - The Inquirer April 3, 2009 07:25 AM
Futuremark - News - Newsarticle April 2, 2009 04:22 PM
